How do I keep my brake discs from rusting? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-05-2012, 10:01 PM   #1
Jlarson909
Jlarson909's Avatar
Fan#: 96421
What I Drive: 2012 Tuxedo Black Focus SE
FF Reputation: 1 Jlarson909 Good Standing Member
Im thinking about getting some rims that show a bunch of brake disks/drums.
I hate seeing cars with a great set of rims but then a rusty disc behind it.
I live in minnesota so this happens a lot in this climate. Any help is appreciated!
-J
Jlarson909 is offline
Old 07-05-2012, 10:06 PM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,249, Level 67
Points: 10,249, Level: 67 Points: 10,249, Level: 67 Points: 10,249, Level: 67
Level Up 50% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 26 suss6052 Great Standing Member
-J
Disks that get a light coating of surface rust are better than disks that are too hard and warp easily. I'd rather have to do a quick run around the block to clean them up rather than having to replace warped rotors like on the older Taurus my Father had, as well as the disk/drum set up on my grandmother's car.
suss6052 is offline
Old 07-05-2012, 10:34 PM   #3
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,082, Level 34
Points: 3,082, Level: 34 Points: 3,082, Level: 34 Points: 3,082, Level: 34
Level Up 22% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
As noted, the portion of the disc that contacts the brake pads can rus, but should clean up quickly with a few brake applications.
The rotor "hat" (the part with the bolts that attach to wheels) or brake drums can be painted with a high temperature coating found in hardware stores and used for gas grills. It will provide a flat black finish and won't burn off with high brake temperatures.
Careful not to get the coating on the area contacted by the pads, though.
dan50 is offline
Old 07-05-2012, 10:39 PM   #4
TehMark
TehMark's Avatar
Fan#: 87530
What I Drive: 2012 Blue Focus Titanium Hatch
Points 1,684, Level 23
Points: 1,684, Level: 23 Points: 1,684, Level: 23 Points: 1,684, Level: 23
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 1 TehMark Good Standing Member
You'll pretty much need new rotors if you want ones that aren't going to look totally rusted. The ones ford uses rust as a "feature"
TehMark is offline
Old 07-05-2012, 10:50 PM   #5
Sideswipe
Sideswipe's Avatar
Fan#: 99685
What I Drive: 2012 Red Ford Focus
FF Reputation: 1 Sideswipe Good Standing Member
Yeah im having that problem also. The orange is so ugly and i just dont want it to happen. I dont really understand that stuff. How is it formed? and can it be prevented?
Sideswipe is offline
Old 07-05-2012, 10:54 PM   #6
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 37%
Iron when exposed to oxygen generates iron oxide aka rust. If you put more nickel or other alloying agents you can increase the chance that it would remain free of rust, but the alloying agents can cause the disks to be more prone to becoming out of round and causing pulsations through the pedals that are not related to the antilock braking system.
suss6052 is offline
Old 07-06-2012, 12:58 AM   #7
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,789, Level 78
Points: 14,789, Level: 78 Points: 14,789, Level: 78 Points: 14,789, Level: 78
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 18%
FF Reputation: 16 Elizabeth Great Standing Member
You do NOT want to put anything on the rotors which would keep them from getting the rust. As any coating would also make your brakes worthless for stopping!!
Even overspray of tire shine onto the rotors is a terrible error, as that will kill your stopping power.
The rotors only look rusty after a rain anyway. (or a washing) so what is the big deal?
As for the rest of the parts behind the wheel, you can coat them with any antirust stuff you want, as long as it does not get on the part of the rotors the brake pads run against. (and remember the whole rotor can get really HOT...)
Elizabeth is offline
Old 07-06-2012, 01:03 AM   #8
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,777, Level 100
Points: 36,777, Level: 100 Points: 36,777, Level: 100 Points: 36,777, Level: 100
Level Up 0% Completed
The only way to stop the rust is to never let your car sit over night. Drive it non stop.
TheGlassMaker is offline
Old 07-06-2012, 07:06 AM   #9
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
Not quite. Steel rusts. Nickel doesn't. Steel is harder than nickel. The less nickel in the rotor, the more rust you'll have, the longer the life and less likely to warp. More nickel in your rotor means less susceptible to rust, but more to warping. You're options are deal with it or buy cheap rotors that will warp in no time. The brakes rub the surface rust off during the first, maybe second stop.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 07-06-2012, 07:08 AM   #10
SterlingArcher
Fan#: 100651
What I Drive: 2012 SE hatch, Sterling Gray
FF Reputation: 1 SterlingArcher Good Standing Member
Tirerack has a variety of rotors with painted hats in a wide range of prices. Living in Massachusetts, I feel your rusty rotor pain, and I've always had luck with a good set of replacement rotors. As others indicated, a quick trip around the block will take care of any rust where the pad meets the rotor, and painted top hats will take care of the rest.
SterlingArcher is offline
