Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 07-04-2012, 04:32 PM   #1
darossi3
Fan#: 83732
What I Drive: 2003, Blue, ZX3
FF Reputation: 1 darossi3 Good Standing Member
Will 225/45/17's fit?
Hey guys im in the market for new tires and right now im running 205-40-17's on 17x7.5's. Im wondering if i can upgrade to 225-45-17 or 225-40-17 for a little bit more grip through corners (occasional auto-x). Will there be any clearance issues? I have eibach pro kit with 2/2.2 drop. Im not really too knowledgeable about tire sizes...so any advice/help would be much appreciated. 2003 ZX3
darossi3 is offline
Fan#: 1
Old 07-04-2012, 06:01 PM   #2
sM17
sM17's Avatar
Fan#: 55991
What I Drive: 2000 Silver ZX3
FF Reputation: 1 sM17 Good Standing Member
I don't know the exact offset on my rims or the width. But they had 225/45/17s on them and the back was fine but the front would rub on the insides of the front fender when I hit a big bump. Other than that everything else was fine. I ended up just going with some 205/40/17s and seemed to fix everything
sM17 is offline
Old 07-04-2012, 06:29 PM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
FF Reputation: 43 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (16)
yes they will, might rub a little depending on your suspension setup, 225/40 would be a better option for less chance of rubbing.
Advocare 24 Day Challenge!
SkyPilot is offline
Old 07-04-2012, 07:06 PM   #4
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
215-45x17 is your best bet w/ a lot more choices
225-40x17 would be great for your autox indever's. Since that size comes only in a race/track only. As far as 225's go, it'd depend on your wheel offset. 215's are a really popular size= a lot more tire choices. 215's are 24.6'' os diameter= little shorter than the 225's 25"-25.1" os diameter, yet a little taller than your 205-40's= 23.9".
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 07-04-2012, 09:40 PM   #5
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
if your wanting a good all around size, 215/40-17 or 215/45-17. I test fit a set of 235/40-17 tires mounted on a set of 17x7.5-40 wheels on a friends zx3 (FRPP) they rubbed on everything!
Posted via FF Mobile
st12131 is offline
Old 07-04-2012, 10:18 PM   #6
A-to-the-J
Fan#: 99555
What I Drive: 2012 Tuxedo Black SE Hatch
FF Reputation: 1 A-to-the-J Good Standing Member
On a 2012 Focus, has anybody tried an 18x9 +35ish offset with a 225/40? or something close?
A-to-the-J is offline
Old 07-05-2012, 10:47 AM   #7
darossi3
Fan#: 83732
Yeah not really sure how offset works either haha.. guess ill have to google it. Ive got my eye on some 215-45-17 michelin super sports though... i dont think i want to go 225 if theres a chance of rubbing and ruining almost 200$ tires.
darossi3 is offline
Old 07-05-2012, 03:30 PM   #8
A-to-the-J
Fan#: 99555
Took the text from Tire Rack and the Picture off another website
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
*Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
