Old 07-03-2012, 07:34 PM   #1
TJN916
Fan#: 100918
What I Drive: 2003 Pitch Black SE
FF Reputation: 1 TJN916 Good Standing Member
Exclamation 2003 SE DOHC 2.3L overheating!
Recently purchased a 03 ford focus SE 2.3L that only has 90,xxx miles on it. Long story shot temp guage showed over heating after a while of city driving but not on freeway. Found coolant was bubbling up considerably and overfilling. Flushed radiator, put new coolant, tried new radiator cap, checked thermostat which does open and close correctly, installed new EGR valve which was corroded and leaking. Still overheats! I'm very frustrated and a friend told me it could be temp sensors or waterpump which are all originals on car. Anys suggestions and would any of those have to do with coolant bubbling and overfilling?
TJN916 is offline
Fan#: 1
Old 07-03-2012, 08:07 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 SCrew 5.0
FF Reputation: 8 Kipp Good Standing Member
remember in the heat that most of the country is having right now combined with sitting around idling in the city (no airflow to radiator) that things will get hot faster than normal. if it's only doing it in the city and not on the highway or what maintaining a decent speed then it could be that. maybe go with a lower temp thermostat and check sensors. if it does start to heat up, roll the windows down and turn on the heater. may be uncomfortable, but will help pull some heat from the motor.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 07-03-2012, 08:09 PM   #3
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Have you heard the fans turning on?
Might be your resistor.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
ctfocusfans.proboards.com
Djzx3 is offline
Old 07-03-2012, 08:12 PM   #4
TJN916
Fan#: 100918
Im almost positive that both fans are turning on. You make a good point though i will double check. Turning on the the heater hadnt help i did try that though. I really appreciate the feedback
TJN916 is offline
Old 07-18-2012, 01:57 PM   #5
doodaa
Fan#: 93881
What I Drive: 49 Ford
FF Reputation: 1 doodaa Good Standing Member
It's the fans.... or something that is supposed to turn them on. Giveaway is the fact that it's fine when you're moving at speed. Plenty of air over the radiator then, slow down and no more air.
doodaa is offline
Old 07-18-2012, 02:50 PM   #6
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
FF Reputation: 5 Miller88 Good Standing Member
It could also be the water pump causing an overheat at only low speeds. If the impellers are worn off, it won't be moving that much coolant at 1200 RPM or whatever you're creeping along at. One you get moving - it's much less strain on the cooling system and the water pump is spinning faster and moving a bit more coolant
2011 Focus SE 5 Speed 26k - Blue Flame Metallic.
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 07-18-2012, 02:54 PM   #7
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Around 90K, I had to replace the resistor, and thermostat, and that fixed my overheating problem.
HN #17
D23 crew-#1
Djzx3 is offline
