Old 07-03-2012, 05:16 PM   #1
88gt302
Fan#: 100912
What I Drive: 2004 mustang cobra
FF Reputation: 1 88gt302 Good Standing Member
2.3 duratech idle issue (replaced pcv) still rough
working on the car for a friend, and im now stumped. its a 03 focus 2.3 duratech auto, 120k and not well maintained sadly. pcv hose was shot, so replaced the valve and hose a few days back, easy enough. idle is still horrible and intermittent. checked for vacuum leaks, no avail. cleaned iab, maf, tb, ran seafoam, still rough. better than is was before pcv replacement, but still not drivable. there was massive buildup in the manifold from the blowby, and i cleaned as much as i could while i was in there. cleared the CEL and fired her up, it hasnt turned back on but its not holding idle and when revved its sputtering and cant hold a consistent rpm. possible TPS? IAC? or even those vacuum solenoids on the manifold? i dont want to staert replacing everything and still have it not clear up so any help would be appreciated
88gt302 is offline
Fan#: 1
Old 07-03-2012, 05:53 PM   #2
oblivion2kx
Fan#: 61764
What I Drive: 2004 Twighlight Blue 2.3l ZX5
FF Reputation: 2 oblivion2kx Good Standing Member
try replacing the intake manifold gasket, throttle body gasket and clean the maf
A few years ago, I went to the gym for several months and lost 30 pounds. That must be worth about 1% more fuel economy in the city.
oblivion2kx is offline
Old 07-03-2012, 05:57 PM   #3
88gt302
Fan#: 100912
manifold and tb gasket were replaced when i removed it to get to the pcv, and i cleaned the maf twice.
88gt302 is offline
Old 07-03-2012, 05:59 PM   #4
Duratec 2.3
Duratec 2.3's Avatar
Fan#: 22283
What I Drive: 2003,Liquid Grey,Pzev ZX3
FF Reputation: 1 Duratec 2.3 Good Standing Member
What did your cel say? I had the same issue and it ended up being my coil pack on cylinder 1 misfiring, replaced the coil and no more misfiring and smooth idling
Sent from my ADR6300 using FF Mobile
Jalejandro photography http://www.flickr.com/photos/jalejandrophotography
HOTM 4/11
Hatch Nation #60
SoCal Crew #182
Duratec 2.3 is online now
Old 07-03-2012, 08:06 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Buildup in manifold is not due to anything more than the oil breather.
Do you have a code scanner so you can give us the DTC? That would be helpful. There are a lot of things that can cause idle issues. You've worked on a few possibilities. Have you removed the air filter? I know it should be a lifetime filter, but it is possible that it could be damaged or clogged due to damage.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-03-2012, 08:23 PM   #6
88gt302
Fan#: 100912
im working on getting a scanner tonight, ill know what the exact code is then. i guess they took it to a shop and the shop told them the pcv needed to be replaced, and was gonna charge $1200. So thats what i replaced, now im stuck fixing the issue. I'll check the air filter tomorrow just to eliminate it. i'll try and post a pic of the gunk in the manifold, it was absolutely ridiculous how bad it was.
88gt302 is offline
Old 07-03-2012, 08:39 PM   #7
88gt302
Fan#: 100912
88gt302 is offline
Old 07-04-2012, 01:50 AM   #8
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
FF Reputation: 10 GreySkorpion Great Standing Member
Buy-Sell-Trade Rating: (4)
You sure you are getting enough fuel? Replace the fuel filter and to check the operation of the 2 imrc solenoids, switch their position. My right side on was bad and several people say they aren't even sure what the left one controls. Goodluck.
GreySkorpion is offline
Old 07-04-2012, 08:02 AM   #9
whynotthinkwhynot
Captain TMI
Fan#: 18416
Like I said, it's the oil breather that does it, and because of the design of the manifold a lot gets stuck in the lower part, then it oozes up because that's how the air goes. Some people install a filter or catch can in the oil breather for this.
Be eclectic.
