Old 07-02-2012, 11:55 PM   #1
noelliam77
Fan#: 100882
What I Drive: 2002 ford focus zts
FF Reputation: 1 noelliam77 Good Standing Member
2002 focus zts P0122 reading Please help
I am new here and in need of focus help. I have a 2002 ford focus zts. I had a problem with an a violent shaking idling car and went about it the wrong way by first changing spark plugs, ignition coil, fuel filter and ultimately finding out it was a pcv valve hose that was old and pierced.
Now that it was fixed, I have a new issue with a check engine light and the car is jumping as it drives into gears. I have an error of P0122 and i have changed the throttle positioning sensor with no change in performance.
any suggestions?
noelliam77 is offline
Fan#: 1
Old 07-03-2012, 08:30 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
What I Drive: 2001 Red ZX3
FF Reputation: 82 BC_ZX3 Excellent Standing Member
Check the TPS wiring and ensure you installed the TPS correctly. See below.
P0122 - Throttle Position (TP) Circuit Low Input
The TP sensor circuit is monitored by the PCM for a low TP rotation angle (or voltage) input through the comprehensive component monitor (CCM). If during key ON engine OFF or key ON engine running the TP rotation angle (or voltage) changes below a minimum calibrated limit, the test fails.
Causes:
TP sensor not seated properly
TP circuit open to PCM
VREF open to TP sensor
TP circuit short to GND
Damaged TP sensor
Damaged PCM
A TP PID (TP V PID) reading less than 3.42% (0.17 volt) in key ON engine OFF, continuous memory or key ON engine running indicates a hard fault.
BC_ZX3 is offline
