60mm Throttle body from UK on 09 Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 07-02-2012, 01:23 PM   #1
jedigesus
Fan#: 100853
What I Drive: 2009 Ford Focus Black
Points 238, Level 4
Points: 238, Level: 4 Points: 238, Level: 4 Points: 238, Level: 4
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 jedigesus Good Standing Member
I have an 09 SES with duratec 2.0. I purchased a 60mm throttle body from the uk, designed for the duratec engine of a fiesta. It is nearly identical to the focus throttle body and bolted right up with ease. However, when I start the engine it immediately cuts the throttle and idles down to 1000 rpm. I am able to rev for about 1 second when I start the engine then the throttle becomes completely unreponsive. Any ideas on how to get the cpu to accept this new tb.
jedigesus is offline
Old 07-02-2012, 03:21 PM   #2
daveyboy
daveyboy's Avatar
Fan#: 61480
What I Drive: 06 Mustang GT, 09 Focus SE
FF Reputation: 7 daveyboy Good Standing Member
This is interesting. I wish I knew I would put one on my car
Hard work never hurt anyone, but why take a chance
Originally Posted by ranger_mclaren View Post
Wheel gap is like a vagina the more fingers you can fit in the worse it is.
daveyboy is offline
Old 07-02-2012, 04:45 PM   #3
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
What I Drive: 08 Black Coupe 14 fiesta ST
Points 6,234, Level 51
Points: 6,234, Level: 51 Points: 6,234, Level: 51 Points: 6,234, Level: 51
Level Up 43% Completed
FF Reputation: 4 focusZX505 Good Standing Member
you will have get the car programmed to work with it. i doubt it's a bolt on this or that it'll help at all for the 600 your spent
FOCUS REVOLUTION
FSWERKS
MASSIVE SPEED SYSTEMS
SCSCC #320
focusZX505 is offline
Old 07-02-2012, 05:16 PM   #4
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,191, Level 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Level Up 21% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
I wondering if it has something do to with the US vs UK ecu. The US ECU might not be compatible with it unless you get a tune.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 07-02-2012, 06:54 PM   #5
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
there's also the possibility that the tps may clip in fine, but could be different pinout. Are you throwing any codes now?
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 07-02-2012, 07:01 PM   #6
PSUrivie
PSUrivie's Avatar
Fan#: 67329
^good point!
PSUrivie is offline
Old 07-03-2012, 02:31 PM   #7
jedigesus
Fan#: 100853
Points 238, Level 4
I will re-install and check codes then report back. Thanks for the ideas. The tps was actually backwards. The pins were still on the bottom and lined up perfect, but the plastic slide peice that was supposed to slide into the slot on the clip was on the opposite side. I shaved this down to allow the tps clip to slide on easier. I will add some pictures soon to better explain this. If I have to get it reprogrammed, how would I go about this. Is there a unit I can buy that will do this?
Old 07-03-2012, 10:13 PM   #8
daveyboy
daveyboy's Avatar
Fan#: 61480
Have you tried resetting or relearing the throttle body? If it is possible. I know a lot of cars you can reset or relearn the electronic throttle bodies, VW comes to mind first and there are others. Or just re set the adaptives so the computer relearns every thing
daveyboy is offline
Old 07-04-2012, 09:28 AM   #9
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
You prolly have to repine that connector ill bet the wires are different
Posted via FF Mobile
Old 07-04-2012, 12:55 PM   #10
jedigesus
Fan#: 100853
Points 238, Level 4
I found this diagram, looks to be for the tps connector of a fiesta st150. http://www.photostand.co.za/viewer.p...8s2d6zhj0u.jpg
Does anyone have one for the 09 focus to compare it to. I have also requested a wiring diagram for the new tb from pumaspeed. I will go throw the tb back in there and see what code it puts out.
Also, does anyone have an idea how to do what daveyboy is talking about here:
