infamous stripped t-55 cam bolt - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-02-2012, 03:31 PM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Maybe.
I'm not going to say one way or the other being I haven't personally tried it.
IMO, ARP's are your best bet. Tried and true.
121,000 members and still no sponsored racing.
iminhell is offline
Old 07-05-2012, 04:46 AM   #12
scoobygms210
Fan#: 88879
What I Drive: 2002 white wagon
FF Reputation: 1 scoobygms210 Good Standing Member
yeah find a local shop that speciallies on bolts i have a place forgot the name close to my job that has every single type of bolt ive ever need from my JDM build mr2 to 6 foot all threads even piping pulgs and stuff they even have grade 10 bolts there its great and cheap i bet i can get cam bolts there for super cheap they always fine the thread pitch and size for me even grade .. use a phone book bro lol by that i mean google
scoobygms210 is offline
Old 07-05-2012, 06:28 AM   #13
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
Points 14,826, Level 78
Points: 14,826, Level: 78 Points: 14,826, Level: 78 Points: 14,826, Level: 78
Level Up 94% Completed
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
infamous stripped t-55 cam bolt????
How did you do that? And why "infamous"?
I never even came close to stripping either of mine, how did everyone here?
Serous question, so I can avoid it?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 07-05-2012, 08:15 PM   #14
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Originally Posted by burke_024 View Post
just like the title says ,im more function than fashion so 40$ on 2 bolts is idk kind of stupid, my question is does any one know the grade and pitch for the bolts im just gonna put some together?
weld on 15mm bolt heds on the ends of the cam gears. then theyll never strip
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-06-2012, 01:33 PM   #15
burke_024
burke_024's Avatar
Fan#: 94039
What I Drive: 2000 focus zx3, almost boosted : )
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 1 burke_024 Good Standing Member
lol nah im goin with arp , i just couldnt figure out the timing on the car ,was on tooth off 18 degrees of some thing was gonna work on it and went to loosen it and the teeth in the bolt gave way , but they have been tightened and loosened about 6 times ,imine being stripped was probably from the worn out t-55 but im going with the 18mm torx head bolt from arp seem a little more logical in design imo
burke_024 is offline
Old 07-06-2012, 03:12 PM   #16
scoobygms210
Fan#: 88879
paying for arp is paying for a name there not head studs there just a bolt that holds on a cam gear at like 50 foot pounds not a big deal if anything i would buy ones from ford not arp if u wanna buy name brand and learn to not strip bolts. ... ive never had a car with torx until this focus but ive yet to strip any bolt even when i did my own timing belt and vavle lash adjust both times no problem with the oem bolt ? and on my mr2 i used oem bolt for like 10 years ? not ever needing to replace anything not even head bolts cus i check them for spec
Old 07-06-2012, 07:43 PM   #17
burke_024
burke_024's Avatar
Fan#: 94039
ya want a cookie ?
Old 07-06-2012, 07:57 PM   #18
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Note how big OD the washer part of the bolt is.........that's for a reason, as is the undercut on backside. Normal washers put all the load close in to the bolt head itself, the big OD and undercut serve to make the loaded area way out on the outside diameter of the washer. That way the high torque used is spread over greater area to clamp much more firmly. A separate washer is not going to duplicate that effect unless more than one used, i.e., smaller OD one under bolt head itself and then bigger OD under it. The pyramid effect would do the same, push the load further out. Or maybe two washers thick instead of just one, either way you go the washers must be grade quality steel just like the bolt or you have wasted your time. Non-hardened washers would simply deflect away from the sprocket to reduce load carrying ability. There's a reason that special bolt is that high priced.......................your engine's durability is most definitely riding on one part there.
FYI, the $7.99 torx set is how you strip them to begin with. Cheap less hardened tip rolls the corners off to damage bolt corners at same time the tip is giving up the ghost. For those cam bolts you should always use the highest quality tip you can find and go out of your way to make sure when you use it you are perpendicular to the bolt head. The hole depth is not such to completely straighten up the tip, if you lean sideways even a little bit the damage is done. Often too, one starts with T50 tip which seems to fit until you realize it's a bit too small, by then too late, you've screwed it up.
amc49 is offline
Old 07-07-2012, 01:00 PM   #19
scoobygms210
Fan#: 88879
cracker plz :-)
Old 07-07-2012, 01:09 PM   #20
scoobygms210
Fan#: 88879
still believe that arp a waste of money if need be buy the oem bolt and learn to use tools if anything ill send u a set of OEM bolts from the junkyard i have like 3 sets that i got there from free lol
