flooded? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-29-2012, 08:11 PM   #1
burke_024
burke_024's Avatar
Fan#: 94039
What I Drive: 2000 focus zx3, almost boosted : )
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 1 burke_024 Good Standing Member
flooded?
got the head back on my car had problems figuring out the spark order it started up but roughly i used the timing pin and bar turned the crank shaft clockwise till it hit tdc then used the bar to time the cams ,pretty sure i got it dead on but now it wont start back up all the plugs have spark and when i pulled em out they were covered in black soot (rich) and covered in gas all pistons are wet from gas and compression is at 120 across ,they all built 60 to 80 pressure initially then built in 3-4 repititions to 120 , with all that said is it possible to flood a fuel injected vehicle?
burke_024 is offline
Old 06-29-2012, 08:59 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
U can flood it but only really if u start it with your foot all the way down on the gas pedal
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-29-2012, 09:01 PM   #3
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
The car won't start right if u don't have the plug wires in order. One to four starts from passenger side motor mount to drivers side
FF MODERATOR
RIFF CREW
Old 06-29-2012, 09:14 PM   #4
burke_024
burke_024's Avatar
Fan#: 94039
ive tried every combo from every picture i can find and nothing but its getting fuel and its getting spark the plugs are gapped at .042 motorcraft copper cores ,i think im going to recheck the timing tomorrow and see if maybe it jumped a tooth or two
edited: how would the car run if the maf was "accidentally" put in backwards (airflow wrong way ) ?
also got a code for the head temperature sensor high input?
Old 06-29-2012, 09:25 PM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
it would fire but run like shit if not timed correctly
FF MODERATOR
RIFF CREW
Old 06-29-2012, 11:11 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You say you got 120 cranking compression but then you said 3 to 4 which tells me a proper compression test wasnt done
You should install th compression tester and spin the engine 4 compression strokes (4 stroke engine) the engine has a rythem to it could them to 4 and let off , whats the compression?
Do you have largr injectors , larger MAF , if so do you have a tune in for these ?
120 is low if it was a proper 4 , check timing again
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-29-2012, 11:25 PM   #7
burke_024
burke_024's Avatar
Fan#: 94039
they are green top injectors and mustang maf housing with pro-m maf , it ran before this just fine all i did was get the head cleaned and checked out , i dont care about retuning it ,it is already tuned for the setup,but im just curious why its flooding it ,and compression test was done exactly like you said if you read the initial post i said "they all built 60 to 80 pressure initially then built in 3-4 repititions to 120" meaning first comp. 60- 80 ,the next few grew to 120 ,on ALL four cylinders,if thats a lil bit clearer for ya
Old 06-30-2012, 05:52 PM   #8
burke_024
burke_024's Avatar
Fan#: 94039
no more input tom ? :/
Old 06-30-2012, 05:56 PM   #9
burke_024
burke_024's Avatar
Fan#: 94039
btw you forgot to say to open the throttle plate up all the way
