Engine Pulling - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-28-2012, 10:50 PM   #1
grizz59
Fan#: 99948
What I Drive: 2001 blue se sedan
FF Reputation: 1 grizz59 Good Standing Member
Engine Pulling
I am just about to finish pulling the engine block (2L SOHC) out of my 2001 SE. Just wanted to know if the fly wheel-torque converter bolts are undone thru the hole left after starter is taken out.I can see bolts thru starter hole but not sure how to get at them as the are slightly lower than the hole. Any advice would be appreciated.FYI head is already off the block. Was also wondering if cylinder compression ratings of 160-166 are good or bad ratings.
Thanks Colin
grizz59 is offline
Old 06-29-2012, 07:21 AM   #2
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 274, Level 5
Points: 274, Level: 5 Points: 274, Level: 5 Points: 274, Level: 5
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 2 poppop Good Standing Member
There is an access plate you must remove at the bottom of the block where it meets the transmission.It is held on with two small bolts.It will be hiding behind the cat. converter pipe if you have not taken that off yet.
poppop is offline
