Normal Amp Draw - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-28-2012, 05:39 PM   #1
kreezy84
Fan#: 100724
What I Drive: 2008 Sky Blue Focus
FF Reputation: 1 kreezy84 Good Standing Member
Normal Amp Draw
Hi guys and gals, trying to aquire some information about my 2008 Ford Focus. All the videos I've watched have said that a 50 miliamp draw is the norm for car batteries, but I have also read that some guys get a 1.2-1.4 amp draw out of their Focus. Mine is reading about 1.4, is this the norm or do I need to start trouble shooting a parasitic draw? Thank for your help.
kreezy84 is offline
Old 06-28-2012, 10:29 PM   #2
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
I think that it takes a while for the electronics to 'go to sleep' then there will be much less current flow
15 minutes to 30 minutes?
mikeeshaq is offline
Old 06-29-2012, 12:18 AM   #3
kreezy84
Fan#: 100724
I checked it 3 hours later and got a reading of 1.43 amps, but after holding the leads on there for about 30 seconds the amps dropped down to 200 miliamps, is that a reasonable current draw for these cars? I just purchased this car used and all the electronics, memory, and computer stuff is new to me.
kreezy84 is offline
Old 06-29-2012, 05:28 AM   #4
mikeeshaq
Fan#: 72526
My memory is fuzzy
I think if you happened to open a door to open up the engine hood then some of the electronics may come back to 'life'. Since there is no electrical switch on the hood then leave it open to do testing.
Are you using a DC clamp on ammeter? then that is the best way, then you avoid anything that might trigger the electronics to 'wake up'
But I think 200 ma is close to reasonable
There is more computing power in these present day cars than what went to the moon!
Old 06-29-2012, 10:59 AM   #5
kreezy84
Fan#: 100724
Well, I left the negative cable disconnected during that 3 hour duration. Would opening the door still have that affect?
kreezy84 is offline
Old 06-29-2012, 01:46 PM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
It's not that you had the negative cable disconnected for 3 hours but rather that you 'reconnected the negative cable' when you attempted to measure the current draw when you "held" the leads in series with the negative cable.
As mikeeshaq mentioned a clamp meter would be best to avoiding the possibility of 'waking' something up. You are resetting something (recharging capacitors) every time you break and then make the power connection - with the meter in series. (Radio?, PCM or at least part of the PCM - PAS.....)
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 06-29-2012, 02:08 PM   #7
kreezy84
Fan#: 100724
Thanks for the help.
kreezy84 is offline
Old 06-29-2012, 03:49 PM   #8
mikeeshaq
Fan#: 72526
A DC clamp on ammeter is not a cheap thing to buy [nor easy to find, it has a 'Hall Effect' sensor]
Found one on Ebay from China for less that $100
For certain a_2000_se is correct. Placing an ammeter on the open ground lead will wake up stuff
My memory is hazy
I think
The electronics will go to 'sleep' in stages
Old 12-12-2012, 09:20 PM   #9
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
Just got the most recent flyer advertisement in the mail from Harbor Freight.
You can now get Clamp-On meters cheaply. CEN-TECH #96308 and #95683, $11.99 and $13.99 respectively. Haven't seen the spec's on them yet but maybe one of the two will be good for automotive applications.
60k+ miles.
Old 12-13-2012, 07:53 AM   #10
mikeeshaq
Fan#: 72526
Harbor Freight do have cheap clamp-on ammeters except they are AC not DC
