My Oil Change Interval Debate Rant - Page 42 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-15-2013, 07:32 AM   #411
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
PandT, thanks for the laugh. That was good.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 05-16-2013, 06:41 PM   #412
ibinubu12
Fan#: 92300
What I Drive: 2012 Focus Hatchback, Blue Candy
FF Reputation: 2 ibinubu12 Good Standing Member
First change at 5,200 (for free at the dealer), second at 11,063, third at 20,964, both done at home with Motorcraft filter and Motorcraft 5W-20 synthetic blend.
Moving forward, 10,000 will be the interval I stick with, or if the oil life monitor tells me otherwise.
ibinubu12 is offline
Old 05-16-2013, 07:51 PM   #413
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,026, Level 33
Points: 3,026, Level: 33 Points: 3,026, Level: 33 Points: 3,026, Level: 33
Level Up 84% Completed
Forum Activity 6%
FF Reputation: 12 dan50 Great Standing Member
You are a brave owner. Ford is unique (I think) in allowing a 10,000 mile OCI in a direct injection engine without specifying synthetic oil. By contrast, Toyota allows a 10k interval only with a full synthetic and with conventional port injection. Non-syn intervals are 5k. Hope Ford has done its homework. On the other hand, this is the group that engineered MFT and the DCT, so what could go wrong?
dan50 is offline
Old 05-17-2013, 06:07 AM   #414
Seriously Focused
Seriously Focused's Avatar
Fan#: 101141
What I Drive: 2012 SGM SE Sport 5 Dr
Points 532, Level 10
Points: 532, Level: 10 Points: 532, Level: 10 Points: 532, Level: 10
Level Up 64% Completed
FF Reputation: 1 Seriously Focused Good Standing Member
I like your oil change "plan" except for one very minor detail :)
I would use a full-synthetic product such as Pennzoil Platinum, Amsoil, or even Mobil 1. Also an upgraded filter might be a good compliment to the synthetic oil as well.
If you asked any other "car guy" they would probably say the same........
Seriously Focused is offline
Old 05-17-2013, 09:01 AM   #415
ibinubu12
Fan#: 92300
As a "car guy" I will not use parts other than Ford Motorcraft, even if Motorcraft costs more. I want the parts approved by the OEM.
And synthetic blend hasn't caused issues with the 10,000-12,000 mile intervals we run in our Escort, can't see paying extra for full synthetic unless I'm going to push the interval out to 15,000 or 20,000, and I won't do that until the warranty is up.
Old 05-17-2013, 09:05 AM   #416
Seriously Focused
Fan#: 101141
You're probably right. I'm probably wrong.
I think that your method is perfect.
Old 05-17-2013, 10:07 AM   #417
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
You might want to consider doing at least one used oil analysis to see how your syn blend oil is holding up to the 10,000-12,000 intervals. Just because your extended OCI hasn't "caused issues" in your Escort, doesn't mean the additives aren't fully depleted at those intervals.
Hatch Nation #90
TboneZX3 is offline
Old 05-20-2013, 04:37 PM   #418
cobrajet429
Fan#: 105085
What I Drive: 2012 candy blue manual SE
Points 122, Level 2
Points: 122, Level: 2 Points: 122, Level: 2 Points: 122, Level: 2
Level Up 44% Completed
FF Reputation: 1 cobrajet429 Good Standing Member
Just took my 2012 in for excess oil use. Service lady told me they recommend 5k intervals 10 for synthetic and that's why I am using oil.. The sticker from my free oil change done by them at 8k says next change at 16k. So service tech checked for leaks. Saw some oil between engine and trans, installed dye. Will see what happens.
cobrajet429 is offline
Old 09-18-2013, 08:11 PM   #419
Arco-Zakus
Arco-Zakus's Avatar
Fan#: 101658
What I Drive: 2014 SGM SE Sport Pkg Sedan 5sp-man
Points 719, Level 14
Points: 719, Level: 14 Points: 719, Level: 14 Points: 719, Level: 14
Level Up 19% Completed
Forum Activity 3%
FF Reputation: 11 Arco-Zakus Great Standing Member
What did happen?
Originally Posted by cobrajet429 View Post
... So service tech checked for leaks. Saw some oil between engine and trans, installed dye. Will see what happens.
Any news you can share?
Arco-Zakus is online now
Old 09-19-2013, 08:46 AM   #420
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
I think I've lost all faith in maintenance minders. My sister-in-law just got done with some major topside engine work on her Equinox after following the maintenance minder faithfully. New cams, chain & guides, thankfully on GMs dime because they had to admit their computer was miscalculating how often she should be changing her oil. Near the end, her car sounded like a Farm-all tractor. So, they've basically told her to ignore the computer and change her oil every 5,000 miles to keep this from happening again.
Lame.
cbdallas is offline
