My Oil Change Interval Debate Rant - Page 19 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2012, 10:07 PM   #181
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
FF Reputation: 6 craigsfocus Good Standing Member
Originally Posted by 2012silversel View Post
At some point I will need to change my oil, any opinions on what oil I should use and how many miles I should go between oil changes? Oh, I almost forgot, what filter should I use?
I recommend using Amsoil Signature Series Oil. I have had great success with it in my Wife's Infiniti, my old Equinox, and my race cars when I raced circle track. Amsoil oil and filters will be going in my Focus here soon. But everyone has their opinion about engine oils.
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 07-04-2012, 10:14 PM   #182
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
If you want to change your oil with the best, and use the oil safely for the OEM 10,000 mile interval, or one year....here is what I would do.
Amsoil ALM 5W-20
Amsoil EaO34 oil filter
This will give your engine a 5 quart capacity, better mpg, less wear, and peace of mind knowing you can take it for the long run.
and don't pay retail for it. Take advantage of their preferred customer program.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 07-04-2012, 10:30 PM   #183
JL330
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
I have all the tools to install, I've done complete engine swaps, just don't feel like doing anything major.
JL330 is offline
Old 07-04-2012, 11:04 PM   #184
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,963, Level 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level Up 63% Completed
FF Reputation: 1 2012silversel Good Standing Member
Yeah, that was a joke...
5W-20 Mobil 1, 7000 miles, Motorcraft FL-910S
2012silversel is offline
Old 07-05-2012, 08:43 AM   #185
UnleashedBeast
Fan#: 100738
a better off the shelf choice for you....
Mobil 1 Extended Performance 5W-20
Royal Purple 10-2835 oil filter
Take it the full 10,000 miles.
Old 07-05-2012, 10:06 AM   #186
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,733, Level 24
Points: 1,733, Level: 24 Points: 1,733, Level: 24 Points: 1,733, Level: 24
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 Miller88 Good Standing Member
I didn't take the time to read the entire, but I'll add my thoughts on the matter anyway.
I used to run exactly 3000 miles and change the oil. If I was over a bit, I'd freak out and think my engine was going to blow up. Guess I was pretty naive at the time.
When I got my jeep and decided to switch all maintenance / most repairs to ME, I started reading up on oil. My 4.0 is an "old" designed engine with not-as-tight tolerances as modern engines. Anyway, the common theme was that it is safe to run 5000 on synthetic on that engine.
My 2011 Focus' owners manual suggested 7500 miles OCI. At first, I wasn't entirely sure whether or not that would be a good idea. When looking at used oil analysis for this engine, I think 7500 on a synthetic would be entirely reasonable. Maybe even 10!
There's a few reasons why it's able to go 7500-10k miles. First is, it has a larger oil capacity per liter of engine than my Jeep. It's oil capacity is 5 quarts, my Jeep's is 6 ... it has half the engine displacement. Second, as with any "modern" non DI engine, it has tight tolerances and isn't hard on oil. Until recently, I had been doing it at 5000 since I qualified as "severe service".
Since my last oil change, I've had a ton of highway driving, I'm going to try to extend it out to 6500 this change. I need to keep it within owners manual specs for warranty purposes.
Once I get out of warranty, I'm going to do two oil changes a year. One in November switching to 0w-20 and one in may/june switching to 0w-30 - it should be about 6000-8000 per change. Oil filters will be changed haflway through the interval.
Now, DI engines may be a bit different. Since they're new, the affects of using oil longer aren't entirely known. They do tend to be a bit harder on oil and have more fuel dillution. If I had a DI engine and was going to do an extended interval, I'd do a used oil analysis at 6000 to see how the oil is holding up.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 07-05-2012, 10:13 AM   #187
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
As a side note... If you're not already using a larger filter for higher capacity on your 4.0, you can use the filter for Ford small blocks. It cross-references to Motorcraft FL-1A. It looks like you might already be doing this since you mention 6 quarts, but I thought it was worth a mention...
Hatch Nation #90
TboneZX3 is offline
Old 07-05-2012, 10:14 AM   #188
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
You can't beat a UOA for gauging the efficacy of YOUR engine's OCI. It will be interesting to see what the internal monitor thinks of my Amsoil fill. Wonder if it will trigger the "change soon" at all before I chicken out?
Factory fill gets dumped this week @ 3500 miles. Will get UOA at 10K at a max for the new fill. Will base OCI's on the 10K UOA.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 07-05-2012, 11:48 AM   #189
Miller88
Fan#: 73790
Forum Activity 2%
Yup, I've been running the FL-1A since I have done the first oil change!
It's thrice the size of the stock mopar filter ... I think the huge filter caused the oil filter adapter to leak from bouncing around off road with almost an entire quart of fluid! haha. To fill my jeep from empty on an oil change is right around 6.5 quarts.
The last oil change was with Rotella T6 and I ran it 6000 miles. I'm going to change my Cherokee to Supertech synthetic 5-30 in November/December (whenever it starts getting cold). I'll probably have a total of 7000-7500 on it. I'm going to do a UOA then to see how it did!
Aren't the OLM based on mileage, throttle usage, trip length, etc?
Miller88 is offline
Old 07-05-2012, 12:06 PM   #190
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
I really don't know. There may even be a particulate sensor in there that triggers at a certain level.
Or, it could be like the filter change light in my fridge. It alarms regularly(every few months). Of course, it isn't hooked up to anything, so it's only telling me that a certain amount of time has passed since I last reset it
Hatch Nation#163
Watch out for the D
TiStick is offline
