High Temperature Warning - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2012, 06:19 AM   #31
GhiaFan
GhiaFan's Avatar
Fan#: 50498
What I Drive: 2007 Panther Black Focus 1.6 Ti-VCT
Points 15,220, Level 79
Points: 15,220, Level: 79 Points: 15,220, Level: 79 Points: 15,220, Level: 79
Level Up 74% Completed
Forum Activity 6%
FF Reputation: 13 GhiaFan Great Standing Member
Might be worth checking if there is problem with the Active Grille Shutters
GhiaFan is offline
Old 10-08-2012, 06:36 AM   #32
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
Originally Posted by Superd View Post
The coolant cant physically heat up and cool down in such a short period of time so it sounds like a faulty temp sensor. Should be an easy fix for the dealer.
Not always. If the thermostat is sticking sometimes (opening at a higher temperature than normal), it can give this illusion of overheating/rapid cooling as well.
However, a faulty sensor or grill shutter issue posted above is more likely.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 10-08-2012, 08:38 AM   #33
HammerStriker
HammerStriker's Avatar
Fan#: 86553
What I Drive: 2012 Ignot Silver Hatchback SEL
FF Reputation: 1 HammerStriker Good Standing Member
Thanks for the reply's.
Just to clear things up... My car runs perfect. No problems what so ever, even when I get this spike. No burning smell, no weird noises, no heat if I turn off the A/C. I do get an ozone smell from the A/C, but this always happens when I idle for a bit.
Last time I took my car in, the dealership told me they replaced some items, but when I questioned them further they admitted they didn't do anything. It seems they had some ideas what the problem was, but couldn't replace anything since they couldn't replicate the warning. I was pissed to say the least. Then they tried to charge me for a week of a rental car since they couldn't charge anything to Ford.
I like the idea of a faulty fan, it makes the most sense. I'm going to try my luck with a different dealer (benefits of living in a big city), and see if they can reproduce the over temp.
Can a dealer charge Ford for repairs based off of my video, or do they have to do it in their shop?
HammerStriker is offline
Old 10-08-2012, 10:18 AM   #34
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Originally Posted by HammerStriker View Post
So, its been a few months since I first starting having this problem, and I'm still having it...
Hi HammerStriker,
I want to do some research and see how I can help. Drop me a line via PM with your VIN, preferred servicing dealer, mileage, and daytime phone number. I'll start investigating.
Originally Posted by Hodge Podge View Post
...Last time I saw something comparable was in a truck that had thrown the belt on the water pump (ZERO water circulation and no cooling fan). Think this can be partially ruled out in your case though...So my question/suggestion is, when the overheat light comes on, does your fan sound like a tornado in a trailer park? It should still be at max if the gauge is anywhere above normal, and if not, that may be your culprit.
Originally Posted by unfocused1 View Post
If they replaced the sensors, then anything that remains should be checked out. Regardless of probability. Including the engine...
Originally Posted by joninsd84 View Post
I had high temp warning too. It turned out it was faulty fan. The fan would switch on only when my coolant temp needle hit red line, however turn off as soon as it falls below the red line...
Originally Posted by dbenney View Post
this car is not overheating IMO. If it was I doubt it would still be running. This seems to be an electrical issue. I have never seen an engine in the red come down once its there. When the temp gauge goes to the red, does it run any differently? is there a bubbling sound coming from the coolant reservoir? Is any coolant coming out the overflow tube? Any abnormal steam, sounds, smells or car actions(other than gauge)?...
Originally Posted by SulavT View Post
I had a same exact problem, getting the Engine Temp High, Stop Safely signal, I went to the dealership and problem was somebody left the degas valve lose while changing the oil...
Thanks for chiming in with helpful suggestions, guys! The more information, the better.
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 10-08-2012, 10:55 AM   #35
Edbro
Fan#: 98994
What I Drive: 2012 SEL
FF Reputation: 1 Edbro Good Standing Member
Crystal
The problem is this kind of stuff shouldn't be diagnosed remotely on an Internet forum. We need the dealerships to step up to their responsibilities.
Edbro is offline
Old 10-08-2012, 01:30 PM   #36
SulavT
Fan#: 93904
What I Drive: 2012 Oxford White Sedan SE
Points 641, Level 12
Points: 641, Level: 12 Points: 641, Level: 12 Points: 641, Level: 12
Level Up 82% Completed
FF Reputation: 1 SulavT Good Standing Member
Originally Posted by suss6052 View Post
Probably means the cap was loose on the over flow or de-gas bottle and therefore allowing pressure and coolant to leak out, but its not exactly a clear statement of such.
Yeap that's what I meant to say, I'm not to good with car terms and plus thats what the technicians had wrote on their report.
SulavT is offline
Old 10-08-2012, 02:06 PM   #37
HammerStriker
Fan#: 86553
Hi HammerStriker,
Crystal
Thanks Crystal, I sent you my info. Let me know if you need further information.
That is not the problem I am having in this thread. I was specifically asking for the help she's providing. Please find a Ford rant thread, there are plenty to choose from. Thanks.
Old 10-08-2012, 02:10 PM   #38
HammerStriker
Fan#: 86553
this car is not overheating IMO. If it was I doubt it would still be running. This seems to be an electrical issue. I have never seen an engine in the red come down once its there. When the temp gauge goes to the red, does it run any differently? is there a bubbling sound coming from the coolant reservoir? Is any coolant coming out the overflow tube? Any abnormal steam, sounds, smells or car actions(other than gauge)? If they wont fix it i say pound it long n hard and when they have to replace the engine you can say..."I told you there was a problem".
That is my whole thought process. I've had my share of clunkers that overheated. This is not exhibiting any of those traits. That's why I just keep driving like nothing is happening. It is very worrying though.
Old 10-08-2012, 02:38 PM   #39
Edbro
Fan#: 98994
I said nothing against Crystal. I was echoing your sentiments that the dealer is falling short. You said the dealer told you they replaced stuff and they didn't and that you were pissed. So telling me not to rant is a bit of the pot calling the kettle black IMO.
Edbro is offline
Old 10-08-2012, 03:01 PM   #40
HammerStriker
Fan#: 86553
I didn't read it like that...
