Fuse 63 keeps blowing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-25-2012, 09:24 PM   #1
DarkSpork
Fan#: 81461
What I Drive: 2013 VW GTI
FF Reputation: 1 DarkSpork Good Standing Member
At the start of the day my central locking system worked fine. When I got home I found that my rear hatch release would not work, then found that the central locking system doesn't work at all. So I replaced the fuse and though "great, everything works now". Then I tried opening the trunk with the key and the fuse blew again. So I replaced it, and it seems to be intact (I was able to lock the car with the remote). But, there's obviously a short somewhere (I'm assuming related to the hatch).
I would just live with it and not mess with the hatch to keep it from shorting again, but it's a hassle to get things out of the trunk from the front. So, what should I start checking first to find the short?
Thanks in advance for any help.
DarkSpork is offline
Old 06-25-2012, 09:32 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
The most common area for wiring shorts of the type you describe is in the sill between the rear hatch and body, in between the two hinges. where the wiring harness leaves the body and enters the hatch via a black coloured rubber "umbilical". Age, wire fatigue and not enough harness slack lead to wiring breaks and consequently shorts.
BC_ZX3 is offline
Old 06-25-2012, 10:15 PM   #3
DarkSpork
Fan#: 81461
That black rubber piece is completely intact. I pulled it away from the body and the wires look like new. Is this still where I should be looking? I'm thinking maybe it could be something closer to the mechanism as the latch has never really worked smoothly.
Old 06-25-2012, 10:46 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
You have to "extract" the harness a bit in order to allow a thorough examination.
Pics here: http://www.focusfanatics.com/forum/showthread.php?t=283719
You can also remove the rear hatch trim and check the condition of the rest of the wiring harness for problems. It is possible the fault is also within the release motor itself. Unfortunately that's a non-serviceable sealed part. To test, temporarily disconnect the wiring connector going to the motor and see if the fuse blowing stops.
BC_ZX3 is offline
Old 06-25-2012, 11:19 PM   #5
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
About three months ago I had to repair two broken and three damaged wires in the hatch harness. As my fellow BCer just explained.......you have to remove the hatch trim and disconnect/unclip the harness from the latch and wiper motor and the hatch itself and feed it out of the hatch (you need the slack) and carefully inspect each wire. The damage on mine was about where the harness enters the hatch.....closer to the hatch end of the "bellows". Both bellows' plastic grommets/retainers can be removed (by trial and error "squeezing" them in the right spot......you may already have found this out), and being oval shaped can be passed through the body opening along with the bellows and the harness. I fed the harness down through the hatch and the body openings into the trunk to accomplish the repair. The headliner simply pulls down and away at the weatherstripping enough to give you room.
Grumpy is offline
Old 07-05-2012, 07:10 PM   #6
DarkSpork
Fan#: 81461
Got a chance to mess with it today. As pictured in the link you posted there were wires with broken insulation. Wrapped each one with electrical tape and it works flawlessly now. Thanks a ton.
Old 10-30-2013, 09:21 PM   #7
Dc5Dp
Fan#: 120275
What I Drive: 2000 Red ZX3
FF Reputation: 1 Dc5Dp Good Standing Member
Did you take the hatch off? I cant get my hatch open at all the key wont open it, the button wont open it... any idea how I can even get the hatch open?
Daily -2000 Zx3 Ford Focus Hatch
Racecar - 2003 Turbo Acura Rsx TypeS 370hp 290tq tuned by Chris Miller
Dc5Dp is offline
Old 08-11-2014, 01:53 AM   #8
DarkSpork
Fan#: 81461
Sorry man, no idea. I had to open it using the key, with fuse intact. I know this response is probably too late...
