Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 06-23-2012, 05:09 PM   #1
Areanense
Fan#: 94269
What I Drive: 2002, black, focus svt
FF Reputation: 1 Areanense Good Standing Member
ABS / Traction control not working
04 svt 100000miles. abs and traction control not working and light on. i already replace the abs fuse. any ideas what possible can be?
also, check engine light on, with front right speed sensor. what does the speed sensor? because my speedometer is worknig.
thanks
Areanense is offline
Old 06-23-2012, 07:37 PM   #2
00exploder
00exploder's Avatar
Fan#: 93022
What I Drive: 01 pitch black ZX3,
FF Reputation: 2 00exploder Good Standing Member
There should be a ring with teeth on the inside of your front hub. Somewhere in that area will be the speed sensor. It will have an electrical connector. Check sensor for damage. Sometimes road debris can mess them up. If it looks ok then try cleaning the sensor first. Sometimes metal shavings/brake dust keep them from working. Clear the code and give it a try. If code comes back replace the sensor. When the speed sensor doesn't give a reading or gives an improper reading to the computer often it sets TC/ABS codes.
I break bones and laugh
Hatch Nation #7
00exploder is offline
Old 06-23-2012, 08:48 PM   #3
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
FF Reputation: 22 6SPD_soul Great Standing Member
Find a way to check the DTC, it'll tell you which corner is having a problem and then you can inspect things more closely. It likely is a problem with a wheel speed sensor, probably not any issue with a sensor itself (they're in a sealed environment). Far more likely to be a wiring issue due to corrosion/NJ weather and salted roads. I've had it happen three times with my car and the sensor itself has never been the issue, it's the wiring and connections that are exposed to the elements and susceptible to damage.
EDIT: 00exploder, I didn't intentionaly shit on your parade, it's been my experience that the sensors themselves don't give problems.
6SPD_soul is offline
