Go Back   Focus Fanatics > Model Specific Discussions > MK2 Focus
Old 07-21-2012, 01:00 PM   #131
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
FF Reputation: 10 mac.mogul Great Standing Member
Originally Posted by CREWZIN View Post
Also the car didn't come with Daytime Running Lights (DRL) so there's a string of bright white LED's that I ran from headlight to headlight right under the FF badge. Got it in there now I have to find a way through the firewall to get to the interior fuses.
There is a pass-through on the driver's side where the fuses and harnesses run. Its right behind the interior fuse box.
http://i50.photobucket.com/albums/f3...l/91c45a03.jpg
it passes through right behind the driver's side strut, so if you've got skinny arms it shouldn't be a problem to reach.
http://i50.photobucket.com/albums/f3...l/1e011d9d.jpg
http://i50.photobucket.com/albums/f3...l/daa3fcce.jpg
2011 SES 5spd #006 >> SR #213
Join the cause! 3 Door Fords for America! facebook.com/3DRS4US
If you're not going to do something right; Don't do it at all.
mac.mogul is offline
Old 07-21-2012, 01:57 PM   #132
CREWZIN
CREWZIN's Avatar
Fan#: 80454
What I Drive: 11 Focus, 01 PT Cruiser, 87 Vette
FF Reputation: 1 CREWZIN Good Standing Member
Appreciate that. Now I have a couple choices to run the wire through.
Thanks.
PT Cruiser Links Moderator.
Public Service Officer, Citrus County Sheriff's Department
CREWZIN is offline
Old 07-22-2012, 09:36 AM   #133
CREWZIN
CREWZIN's Avatar
Fan#: 80454
Can only work for a little bit at a time because off the heat but I manages to get all the wires together and ground the black wires to the frame and drilled a hole through the place where the clutch would have fit. Easier than I thought as you can actually see where it comes out from the engine compartment. Put the two ends of the hot wires together into one long wire and passed that thought to the inside of the car right next to the fuse box. Quit there as it's already about 92 degrees and the car was in the sun. Next step is to attach the hot wire to either the running light fuse or the fog light fuse depending on when I want the LED's to light up. Decided not to use an ignition fuse so the LED's are on all the time. That was my original intention but changed my mind.
Might just pull the car into the garage and finish up today to get it done. If I do, I'll have pictures up later.
CREWZIN is offline
Old 07-22-2012, 10:58 AM   #134
CREWZIN
CREWZIN's Avatar
Fan#: 80454
OK, finished. had to connect them to a spare fuse that comes on with the ignition so they will be on anytime the ignition is on, like DRL's. Really bright outside the garage so I'll have to take a couple other shots at dusk or at night.
CREWZIN is offline
Old 07-22-2012, 06:20 PM   #135
CREWZIN
CREWZIN's Avatar
Fan#: 80454
A couple pictures at dusk.
CREWZIN is offline
Old 07-22-2012, 06:42 PM   #136
SteezMuffin
SteezMuffin's Avatar
Fan#: 99549
What I Drive: 2009 Sterling Grey Focus SE
FF Reputation: 2 SteezMuffin Good Standing Member
That is sick looking! Love to see it in the dark with the headlights on
SteezMuffin is offline
Old 07-22-2012, 06:51 PM   #137
CREWZIN
CREWZIN's Avatar
Fan#: 80454
7:50pm here. Still dusk. Will wait till dark and post again.
Hard to get at night with other lights. Looks like LED's reflect off lower bumper making two rows.
CREWZIN is offline
Old 07-22-2012, 11:47 PM   #138
cristobal313
cristobal313's Avatar
Fan#: 77426
What I Drive: Murdered 08 Focus
FF Reputation: 1 cristobal313 Good Standing Member
mustache
SES #002
Sign up in the SES registry
cristobal313 is offline
Old 07-23-2012, 11:08 AM   #139
SteezMuffin
Fan#: 99549
Now if the bulbs in the headlights and fogs just matched. Still really sick IMO
Old 07-23-2012, 11:28 AM   #140
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
FF Reputation: 2 Snyper Good Standing Member
I'm really caught in the middle with this. One minute I love it, the next I don't. It's definitely new and creative, so good for you. If I were to do it, I'd keep the LED simply under the headlights, rather than the grill. At least, I think I would.
How hard was it to do?
Snyper is offline
