Dome lights - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-03-2012, 09:12 PM   #41
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,265, Level 67
Points: 10,265, Level: 67 Points: 10,265, Level: 67 Points: 10,265, Level: 67
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
FF Reputation: 26 suss6052 Great Standing Member
Originally Posted by dbenney View Post
ok... ill take another look. I jsut looked through the manual today when there were a few things i couldnt figure out, and dont remember seeing it.
From page 164 on version 5 of the owners manual:
"Unlocking the doors/two-stage unlock
1. Press and release to unlock the driver’s door.
Note: The interior lamps and turn signal lamps will illuminate.
2. Press and release again within three seconds to unlock all the
doors. The turn signals will flash.
The remote entry system activates the illuminated entry feature; this
feature turns on the lamps for 25 seconds or until the ignition is turned
on.
Two-stage unlocking may be disabled or enabled by simultaneously
pressing the and controls on the transmitter for four seconds
(disabling two stage unlock allows all vehicle doors to unlock
simultaneously). The turn signal lamps will illuminate twice to indicate
that two-stage unlock was enabled or disabled.
The unlocking mode will
be applied to remote entry, keyless entry and intelligent access (if
equipped).
Two-stage unlocking may also be disabled or enabled through the
message center if this is an available message center option or by your
authorized dealer. Refer to Message center in the Instrument Cluster
chapter.
If equipped with an IA key, when two-stage unlocking is disabled,
intelligent access at the driver’s door results in an unlock of all doors
(not just the driver door)."
suss6052 is online now
Old 09-03-2012, 11:47 PM   #42
biglar412
Fan#: 99568
What I Drive: 2012 Blue Candy SE Hatch
Points 23, Level 1
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 biglar412 Good Standing Member
My dome lights will not come on with 1 or 2 presses of the remote. Had the car to the dealer for the grill shutter harness recall, I told the service manager about the dome light. He took the keys to all the Focus on the lot and found one that did not light as well. He will look into it and have an answer for me the next time I come in.
biglar412 is offline
Old 09-04-2012, 04:58 AM   #43
Sonicbluz
Fan#: 100495
What I Drive: 2012 Sonic Blue Focus s
Points 152, Level 3
Points: 152, Level: 3 Points: 152, Level: 3 Points: 152, Level: 3
Level Up 4% Completed
FF Reputation: 1 Sonicbluz Good Standing Member
Good luck and please let us know what you find out. I told the service person about the same thing, he just looked at me like I was crazy and said "That makes no sense" He said I could leave it there ... but I don't live very close so just for that it wasn't worth it. I did find out through experimenting that if I push unlock, then lock, then unlock again on the key, the dome light will come on. I do a lot of night driving so the dome light comes in handy, when it works. Don't want to sound like a whiner, aside from the dome light I love the car and have had no other problems with it.
Sonicbluz is offline
Old 09-04-2012, 06:32 PM   #44
Altis
Fan#: 89540
What I Drive: 2012 Sterling Grey SEL Hatch 5MT
FF Reputation: 1 Altis Good Standing Member
While we're discussing bizarre, haunted electrical behaviours while using the remote... my mirror signals don't flash when unlocking, the first time... they do the 2nd time or when locking. Honestly, I'm lost for words...
Altis is offline
Old 09-04-2012, 10:40 PM   #45
jeffv
Fan#: 103406
What I Drive: 2012, blue, focus
FF Reputation: 1 jeffv Good Standing Member
Dome lights not turning on
I have tried every combination of suggestions on this page and my dome lights still do not consistently turn on when I unlock the doors with the remote or open the door. Sometimes it works, other times, only the ambient lighting goes on.
Just out of curiosity, a question for those experiencing the same problem, did you at some point disconnect the main battery terminal?
I disconnected the terminal to reset the date. It was one day ahead and I read that I needed to disconnect the terminal to fix the date. This worked in fixing the date but I wonder if it somehow messed up the lighting?
jeffv is offline
Old 09-04-2012, 10:43 PM   #46
jeffv
Fan#: 103406
Do you have the link to the other thread that you reference? Thanks!
jeffv is offline
Old 09-05-2012, 03:23 AM   #47
Sonicbluz
Fan#: 100495
Points 152, Level 3
No, never disconnected the battery terminal.
Old 09-05-2012, 05:10 PM   #48
Focus YBTC
Focus YBTC's Avatar
Fan#: 97107
What I Drive: 2012 Yellow Blaze Tri-Coat Titanium
Points 653, Level 13
Points: 653, Level: 13 Points: 653, Level: 13 Points: 653, Level: 13
Level Up 6% Completed
FF Reputation: 1 Focus YBTC Good Standing Member
We're definitely talking about trying this only in low light correct? Because the 5th printing of the 2012 Focus manual doesn't specifically mention it but I think that due to a light sensor, the dome lights only come on in low light. The ambient lights are the same and along with the dome lights will not come on if the dome light "off" switch is activated. If that's the case, if only checking them after dark and they're still intermittent, I think your FoFo needs some dealer attention. I did "reset" my car unintentionally as I had an incident where the whole car was dead and I put pressure on the + battery cabling and power came back. It didn't affect my interior lighting though.
Focus YBTC is offline
Old 09-05-2012, 06:22 PM   #49
jeffv
Fan#: 103406
Thanks for the reply. I tried it last night in an empty parking lot that was pitch dark and the lights did not turn on when the door was opened (only the ambient lights went on). I have also tried this in daylight with the lights turning on so I don't think it's a sensor issue. Also, I have tried this with the auto headlights on (control knob turned to the full clockwise position) and with the headlights completely off (control knob turned to the full counter-clockwise position)
I agree that it might be time to visit the dealer with the FoFo :-). My fear is that this is intermittent, which is the "kiss of death" when bringing a car to a dealer for repair. What I mean by this is that unless the problem can be duplicated in front of a service representative, it is highly unlikely that they will find anything wrong and simply state "working properly".
jeffv is offline
Old 09-05-2012, 07:01 PM   #50
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 593, Level 11
Points: 593, Level: 11 Points: 593, Level: 11 Points: 593, Level: 11
Level Up 86% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
I just went and checked my car out again.
when the Off button is blue the dome lights work with the doors. When the button is amber, the dome lights do not turn on.
Now I also believe that sometime the dome light wouldn't turn on until I hit the unlock button the second time. Everytime I checked tonight the light came on the first time. However I did set the door locks to unlock all doors at the same time. So I don't know if that changed or affected anything.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
