Warning about K&N Intake - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-02-2012, 02:55 PM   #71
troy-knfilters
troy-knfilters's Avatar
Fan#: 85424
What I Drive: 2000 Ford Taurus SE (FFV) Vulcan
Points 2,234, Level 28
Points: 2,234, Level: 28 Points: 2,234, Level: 28 Points: 2,234, Level: 28
Level Up 56% Completed
FF Reputation: 1 troy-knfilters Good Standing Member
Originally Posted by TboneZX3 View Post
I sent him pics about the other issue too (MAF housing contacting bottom of shield hole) so they have evidence of that too. I haven't heard anything from Troy about it.
Hello TboneZX3 - We had sent you a hardware kit to space out your MAF from the heat shield, in reading the thread it appears you used your own solution. We were waiting to hear back from you on how the parts we sent worked out when we last spoke on 6/12/2012, sorry for the confusion and delayed response.
Were there any other forum members like TboneZX3 with MAF allignment issues? (Heat shield + MAFsensor or housing contact) If so please PM me so I can contact you and document this issue, thanks!
Troy.
Resident K&N Guy - Got a Question about a K&N Product? Let me know - I can help!
troy-knfilters is offline
Old 07-02-2012, 03:08 PM   #72
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Troy.
I appreciate you sending me the hardware kit. However, the hardware kit you sent me (the same as the one in the original kit) would not have worked very well, as there were no washers in there close to the same outer diameter as the rubber studs. IMO, centering the hole properly in the heat shield and including larger studs or spacers (as I used in my solution, documented in post #12 of this thread) are the proper solutions to this, not just throwing more washers at it.
I sent you an email on 6/23 directing you to this thread and my solution in post #12, so you should not have been waiting to hear from me. After that email was sent, I have not received an email from you. As I previously stated, I'm not concerned about my installation as much as those who are buying the kit now and not really aware of the issue. After the modifications in post #12 were completed, my kit fits together perfectly, with no contact between MAF/housing & heat shield.
Hatch Nation #90
TboneZX3 is offline
Old 07-02-2012, 03:36 PM   #73
troy-knfilters
Fan#: 85424
TboneZX3 - I'm sorry for the miscommunication. It seems that you were the only one that experienced this particular issue so we do believe it is an isolated incident, however if anyone else has had this issue please contact me as we must document any common issues. I appreciate everyones patience, thank you again.
Troy.
Old 07-02-2012, 03:46 PM   #74
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I'm not sure how this could be an isolated incident. The two heat shields K&N sent me fit identically, and my MAF housing is no different than anyone else's. I could very easily see how most people would not even notice the bottom of the MAF housing contacting the heat shield.
Please check the email I sent you on 6/12. You will see that I mentioned FF user wantz12, who has also mentioned on the board here that he has the same issue. I also suggested at that time that he contact you.
He mentioned it in this post, which was a reply to my install post on the prior page, where I first mentioned the issue in post #192 of that thread on 6/1 : http://www.focusfanatics.com/forum/s...=K%26N&page=17
Hatch Nation #90
TboneZX3 is offline
Old 07-02-2012, 04:04 PM   #75
nhemti
Fan#: 96686
What I Drive: 2012 Focus Titanium - TMB
FF Reputation: 1 nhemti Good Standing Member
Mine looks just like yours TBone so it certainly isn't isolated. I haven't noticed an issue yet because of it but I am keeping an eye on the filter and checking that it is still seated tightly very regularly.
2012 Focus Titanium | K&N Typhoon Intake | Lights and Siren per NH state law
nhemti is offline
Old 07-02-2012, 04:45 PM   #76
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
My concern from that issue is not that the filter will fall off. My concern is that, since the MAF isn't properly "suspended" in the hole by the rubber mounts, the vibrations from the engine/throttle body will not be properly isolated from the MAF. Also, engine movement could cause a binding situation between the MAF housing and the heat shield. This could cause damage (cracking) to the housing itself in the long run.
Hatch Nation #90
TboneZX3 is offline
Old 07-02-2012, 04:56 PM   #77
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Oh yeah, I forgot to mention. Please contact Troy via PM so K&N is aware that this is not just an isolated incident.
Thanks!
Hatch Nation #90
TboneZX3 is offline
Old 07-02-2012, 05:43 PM   #78
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 124,710, Level 100
Points: 124,710, Level: 100 Points: 124,710, Level: 100 Points: 124,710, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
$5.89 (tax included) for a new housing. Only 6 left in Detroit now LOL
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 07-02-2012, 05:51 PM   #79
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,231, Level 100
Points: 41,231, Level: 100 Points: 41,231, Level: 100 Points: 41,231, Level: 100
Forum Activity 2%
FF Reputation: 2 _RED_ Good Standing Member
This is why we cant have anything nice sonic lol
Only six left haha
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, MBRP Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is offline
Old 07-02-2012, 05:53 PM   #80
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
I'm gonna go order 6. If anyone needs one, I will have them for sale in the sale section for $20.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
