Fog Light Installation - S Model (with Pics) - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-13-2013, 06:53 PM   #71
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
I think I might just cut a slot in my covers and do a LED strip similar to the Fiesta.
Those should be able to run just by splicing the parking lights right?
like this:
http://www.focusfanatics.com/forum/s...&postcount=968
but don't like the look of those exposed ones.
thejordan is offline
Old 01-13-2013, 07:29 PM   #72
Chaddz3
Fan#: 96992
What I Drive: 2012 Ford Focus S Ingot Silver
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 17 Chaddz3 Great Standing Member
LED's don't draw nearly as much power as incandescent bulbs do, so splicing an LED strip in the parking light circuit shouldn't be a problem.. just make sure to solder the splice so it doesn't corrode from being exposed to the elements, and if you can find it, use meltable wall shrink sleeving on the splice to seal it good. Something like ES2000 sleeving if you can find it. Meltable wall sleeving is basically shrink tubing with a layer of hot glue inside that seals exposed copper so it can't corrode.
Chaddz3 is offline
Old 01-13-2013, 07:55 PM   #73
thejordan
thejordan's Avatar
Fan#: 107706
Yeah I know to solder and shrink-wrap ;)
Just want to do a little something to the covers until I can come up with the patience and money to do the full fogs. Then tackle the HIDs and projectors.
Thanks for the quick response Chad.
Old 01-17-2013, 03:20 PM   #74
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
Talking Fog Light install next Wednesday by dealer
Hi,
I was already pretty far along before I found this thread. My dealer is helping me put Fog Lights in my 2013 SE Sedan I bought from them last week.
They have ordered the lights, the bezels, the harness, and the switch. They will put it all in for me, and their expectation is that it will go to work. Now that I've found the thread, I know enough that if it won't work, I should ask them to program the BCM to know the lights are there.
I just looked, and fuse slot 75 in my BCM has a fuse already, and the manual says it's the Fog Lights. So, I'm pretty stoked in believing this is going to work!
I'll let you all know and even post up pics when I get 'r done!
OPsDad is offline
Old 01-17-2013, 05:53 PM   #75
Chaddz3
Fan#: 96992
Originally Posted by OPsDad View Post
Hi,
Sounds like your install should go alot easier than mine did. It is a whole lot easier if you already have a compatible BCM. I'm curious as to what the dealer install of this actually costs, if you could be kind enough to post that info after all is said and done, kinda would like to compare it to my solution cost wise.. Thanks.. and good to hear it should go smoothly for you.
Chaddz3 is offline
Old 01-17-2013, 07:51 PM   #76
thejordan
thejordan's Avatar
Fan#: 107706
+1 on the info/cost. I can get parts for close to dealer cost and want to do this.
From what I've read, all 2013 SE have the same BCM. I'll double check my fuse box when I hardwire my radar detector this weekend.
Old 01-17-2013, 10:41 PM   #77
2012Tuxedo
Fan#: 95249
What I Drive: 2012 Black sedan
FF Reputation: 1 2012Tuxedo Good Standing Member
Then solder the crimp area.. use only as much solder as is needed to secure the terminal to the wire and DON'T get any in the socket part...
WHERE DID YOU LEARN THIS? you dont solder a crimped termination in an assemble, EVER. Per J-STD-001 (the standard for the entire electeronics industry) You either ternimate a wire by crimp or solder, never both. Trust me on this, I have spend the last 5 years working for Lockheed Martin Missiles and Fire Control building/inspecting harness assemblies for missile systems. Never even in class 3 assemblies do you crimp AND solder.
2012 Ford Focus S 2.0/5-speed
1994 Ford F-150 5.0/AODE/3.08s
1969 Ford F-100 360FE/NP435/3.25s
1968 Ford Mustang coupe -Project
2012Tuxedo is offline
Old 01-17-2013, 11:59 PM   #78
Monkeygrits
Fan#: 47691
What I Drive: 2013 Focus SE Hatch
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 1 Monkeygrits Good Standing Member
Hi,
Sweet! Ill be waiting for your results before i finish my aftermarket switch.
2013 Ruby Red Focus SE Hatch
2009 Vivid Red Mercury Mariner Premier
2003 Azure Blue Mustang Mach 1
Monkeygrits is offline
Old 01-24-2013, 02:04 PM   #79
OPsDad
OPsDad's Avatar
Fan#: 108661
I am sorry to have to put up a "no joy" report here.
All the parts came in, the dealer installed, and no light. They hooked the unit up to the BCU and it refused to allow them to "tell" the BCU that the fogs were there. They couldn't (or wouldn't) completely reprogram the BCU (as others have stated here) so they refunded me all the unused parts (switch and harness) and only charged me labor for the install of the light units. I have since wired the lights using a tap-a-fuse in the slot for rear wipers (none on a sedan, but the circuit and fuse are there, 15amp) and it is only on when ignition is in the "run" position, so my fogs are like driving lights, which is how I use them anyway. All is fine with me, but it would have been cool to have them be like "factory". Strange company, this modern day FoMoCo.
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 01-24-2013, 03:07 PM   #80
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 993, Level 16
Points: 993, Level: 16 Points: 993, Level: 16 Points: 993, Level: 16
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 6%
FF Reputation: 4 Tiger-Heli Good Standing Member
Agreed, but if it makes you feel any better, Dodge and GM are at least as bad on things like this, if not worse !!!
Tiger-Heli is offline
