Fog Light Installation - S Model (with Pics) - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-03-2013, 09:51 AM   #111
redzone
Fan#: 114512
What I Drive: 2013 Blue Candy Hatchback SE
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 1 redzone Good Standing Member
do you think adding a relay is such a manner would cause a volt drop? im sure the relay would have some resistance but i would think it would be very minor.
This is all theoretical for me cause i cant see adding them untill im out of the 3 year warranty which is in 3 years! lol.
well if no one else has tried by then i will find out !
2013 Focus Hatch Se
Blue Candy
Build Date: 03.02.2013
Stock for now
redzone is offline
Old 06-03-2013, 10:00 AM   #112
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
I wouldn't worry about the relay adding a voltage drop, but I don't know what the "trigger" wire for the main headlight relay is.
That said, Chaddz3 has an elegant solution for the 2012 S that would also work for the 2013 SE.
Your method only saves one relay, a switch, and a few splices over his method.
I.e. - if you used his method and left the switch in the ON position at all time (or didn't bother with the switch), the fogs come on when the ignition is running and the parking lights are active.
The only advantage to your solution would be if you ONLY wanted fogs when the headlights are on and NOT when the parking lights only were on. That might be your intention, but I don't think the factory lights work that way (i.e. factory lights, you would have to manually turn them on with the headlights and then off with the parking lights if you wanted to do that).
Tiger-Heli is online now
Old 07-15-2013, 12:15 AM   #113
fmoose
Fan#: 111482
What I Drive: 2012 Kona Blue S
FF Reputation: 1 fmoose Good Standing Member
Could I just tap them into my headlamps without adding a relay? I would only want them on when I have my lights on at night or in the rain.
fmoose is offline
Old 07-15-2013, 08:28 AM   #114
Tiger-Heli
Fan#: 12379
Forum Activity 8%
You can, but I wouldn't recommend it.
However, if you just want them to come on and off with your headlights, you could use the headlight trigger wire to activate the relay and do all your wiring under the hood without needing to install a toggle switch.
Old 08-01-2013, 07:01 PM   #115
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 CunFFS13 Good Standing Member
Absolutely great write up!
I'm looking forward to do this to my 2013 Focus S
CunFFS13 is offline
Old 08-05-2013, 07:36 AM   #116
Tiger-Heli
Fan#: 12379
Forum Activity 8%
Not sure if 2013's have the BCM to bumper wiring installed, but yes, the guide should be a great help overall.
Old 08-11-2013, 09:04 PM   #117
tophe7d
Fan#: 45290
What I Drive: '01 Malibu Blue ZX3 Road Racer
FF Reputation: 1 tophe7d Good Standing Member
The only way to make the 2013 SE BCM run the fogs (assuming you already have a high level BCM to begin with) is to have both the Volvo and DET engineering software to properly reprogram and flash the BCM. You will need a Ford engineer to do this. No if and or buts. Only other option is the previously documented stand alone wiring system and toggle switch. I've been chasing this issue since last Thanksgiving and finally got in touch with the right people to make it happen. As most of you already know, VERY frustrating!!!
Chris Thornton
#70 ITA, Ford Focus ZX3
Midwestern Council Wheel 2 Wheel Member
Salt Creek Sports Car Club Member (Downers Grove, IL)
tophe7d is offline
Old 08-11-2013, 09:09 PM   #118
CunFFS13
CunFFS13's Avatar
Fan#: 117411
Forum Activity 15%
I was thinking in two possibilities
1. Tap the fog lights into the headlamps wire with some kind of relay, so if I turn the HL on the FL will go on too.
2. Tap them to the battery and ground, using a toggle switch.
Warranty issues?
CunFFS13 is offline
Old 08-11-2013, 09:15 PM   #119
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,448, Level 52
Points: 6,448, Level: 52 Points: 6,448, Level: 52 Points: 6,448, Level: 52
Level Up 49% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
An ST owner modified his Foglights to always come on with power, and to switch off with high beams. He bypassed his original switch and harnesses so his custom build relays and harness would be powering his fogs. I would assume this option would work for people that don't have factory fog lights.
If you google search "ford focus constant fog" it should be the top link. He as pictures and a diagram of his relay setup.
https://www.google.com/search?q=ford...hrome&ie=UTF-8
SilverPony2001 is offline
Old 08-12-2013, 08:20 AM   #120
Tiger-Heli
Fan#: 12379
Forum Activity 8%
Warranty issues?
People get confused on warranty issues.
Technically, the dealer can only deny coverage if your action caused the warranty issue.
So if you tap into the HL and you get a HL out warning, the dealer can refuse to fix it or just disconnect your wiring to make the light go out.
Now - in reality - the dealer can look under the hood and see a bunch of quick-splices and CLAIM that that is what caused your oil pump to quit working and deny the claim and then you have to find another dealer or go to small claims court (or escalate it to a regional manager) to prove that it should be covered.
General rule is a warranty is only worthwhile to the level that the company is willing to stand behind it.
Key example would be a road hazard warranty on tires - some places will say if you hit a curb, it was a road hazard and will cover it, and some places will say a nail in the tire was caused by you driving in a construction area and would not be covered.
