Duratec/PSEV Instrument cluster swap? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-01-2004, 03:06 AM   #1
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 26,532, Level 97
Points: 26,532, Level: 97 Points: 26,532, Level: 97 Points: 26,532, Level: 97
Level Up 19% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
Has anyone swapped the cluster on the 2.3l PZEV?
I've wanted a tach since the day I got my ZTW, but the only reports I've found are for the Zetec and have even swapped one of those myself. I know it's plug and play for the most part, if you're not worried about the mileage or warning lights for ABS if the old car had it and yours doesn't.
I'm thinking it may be the same on the PZEV, but would like to hear from someone with first hand experience. What mostly worries me, is the mileage reading being accurate. The parts guy at Downtown Ford said that all I have to do is order it and they'll enter my current mileage at the factory before sending it to them. The guy said he called his supplier of the cluster and that was it! It sounds a little too simple to be right, doesn't it? I have a feeling that the ecu will check with the cluster when it is installed and first started up, and if the mileage is even only one mile off, it will store an error code and my car is now "mileage unknown". I would do the tach upgrade, if I was sure this won't happen, or know exactly how this can be done PROPERLY!
BTW, I've asked a bunch of dealers if and how it can be done and got a different answer each time!
Thanks all.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 11-01-2004, 05:26 PM   #2
P0WeRbyDuratec
P0WeRbyDuratec's Avatar
Fan#: 2109
What I Drive: 2012 WRX Limited
FF Reputation: 1 P0WeRbyDuratec Good Standing Member
Re: Duratec/PSEV Instrument cluster swap?
Thanks all.
i've heard it being done for a duratec b4, it should be as easy as having the right face and hooking up a couple extra wires
P0WeRbyDuratec is offline
Old 11-01-2004, 08:23 PM   #3
aero_student
Fan#: 1979
What I Drive: '03 Focus ZX3 PZEV
FF Reputation: 1 aero_student Good Standing Member
you have to order it using the vin off of a car that has a tach.
MarcyMotorsport:CAI, balanced 11.6:1 motor with ranger crank, cosworth flywheel, tumble flap delete, supertec valve springs, crane cams, clutch master stg I clutch, protoype MarcyMotorsport 2.5" exhaust, FC throttlebody, Quaife, svt bumpers and brakes, full energy bushings, etc.
aero_student is offline
Similar Threads
Instrument Cluster Home-repair defleppardsg General Technical Chat 17 01-05-2015 07:38 AM
Instrument Cluster & Running Lights 09bullitt General Technical Chat 8 01-17-2010 04:37 PM
Instrument cluster ?'s wesleyn Ford Focus & General Car Chat 2 02-03-2009 01:23 AM
Replacing OEM Instrument Cluster 01BlueZX3 MK1 Interior Mods & Upgrades 9 06-02-2006 01:25 AM
Instrument Cluster Swap hendu33 MK1 Interior Mods & Upgrades 6 09-11-2003 12:41 AM
