Ignition barrel with no led! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 06-19-2012, 07:20 PM   #11
Rememo
Rememo's Avatar
Fan#: 95534
What I Drive: Was 2012 Focus. Now 2013 Impreza.
FF Reputation: 3 Rememo Good Standing Member
Originally Posted by BetaDnB View Post
The problem I personally have is there are no defining features to help guide you, which any other car I have driven has had.
Yup... they could have at least made the ignition barrel slightly concave so the key would fall into the slot. This is the first car I've owned (out of many), that forces me to look where I'm putting the key. Maybe one time out of fifty I'll hit it the first time.
Rememo is offline
Old 06-19-2012, 07:49 PM   #12
meattooth
meattooth's Avatar
Fan#: 97031
What I Drive: 2012, candy blue, se hatchback
Points 1,574, Level 22
Points: 1,574, Level: 22 Points: 1,574, Level: 22 Points: 1,574, Level: 22
Level Up 74% Completed
FF Reputation: 5 meattooth Good Standing Member
I had trouble when I first got mine it seems they really tuck it up in there behind the plastic on the back of the steering wheel. I do find myself feeling it out with my finger before I jab the serrated Rambo knife at it ( or laser cut key).
meattooth is offline
Old 06-19-2012, 10:07 PM   #13
A-to-the-J
Fan#: 99555
What I Drive: 2012 Tuxedo Black SE Hatch
Points 940, Level 16
Points: 940, Level: 16 Points: 940, Level: 16 Points: 940, Level: 16
Level Up 40% Completed
FF Reputation: 1 A-to-the-J Good Standing Member
It's not really a problem for me, it's just somewhat of an inconvenience factor. Every car I've owned has had an illuminated ignition barrel. It was just strange for a new 2012 car to not have one.
A-to-the-J is offline
Old 06-20-2012, 04:46 AM   #14
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
If you really need a light to find the keyhole, just turn your dome light on. It's really not that big of deal to just tilt your head to look. Or you can just sit in your car and practice inserting the key and, eventually, muscle memory will take over to where you can insert said key without looking or having the need for light. Just sayin'.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 06-20-2012, 06:46 AM   #15
MKorn
MKorn's Avatar
Fan#: 97610
What I Drive: 2012, SE, Sport, 5MT, Hatch -Silver
FF Reputation: 1 MKorn Good Standing Member
I agree that it is not an easy task and does take some effort unlike every other car i have driven.
The trick i use is to hold the tip of the key near the end of my index finger and use the tip of my finger to find the slot ... then just slide the key the rest of the way down my finger into the ignition.
MKorn is offline
Old 06-20-2012, 07:53 AM   #16
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
John, it's more than just a slight head tilt in this car. At least the way my seating and controls are adjusted. MKorn, I'll give that a shot.
Posted via FF Mobile
BetaDnB is offline
Old 06-20-2012, 08:43 AM   #17
Rememo
Rememo's Avatar
Fan#: 95534
I contacted the seller for dimensions of the part. According to my measurements, the outer diameter of the "trim" area is 44mm, and the outer diameter of the ignition barrel is 30mm.
Here are the dimensions of the part:
"Part one is the LED board. The dimensions are ext. 50mm int. 34mm.
Part two is the ring that is illuminated by the LEDs. The external diameter varies from 34mm where it fits into the circuit board up to 41mm on the front face. The internal diameter is 32mm."
So I really doubt that the LED portion would fit, but the second part would.
Now that I really looked at it, I have to agree with BetaDnB, it looks like Ford forgot to install a ring. Looks pretty bad actually...
Rememo is offline
Old 06-20-2012, 09:35 AM   #18
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
If you turn your steering wheel 1/4 turn to the right when you park, your ignition slot will be visible from your seated position. Of course, this doesn't do much for you in the dark, but it might help you in daylight.
Hatch Nation #90
TboneZX3 is offline
Old 06-20-2012, 10:51 AM   #19
spazzboy
spazzboy's Avatar
Fan#: 99648
What I Drive: 2012 Platinum White SEL Hatchback
FF Reputation: 1 spazzboy Good Standing Member
What would help is if the ignition area was concave. This would allow the key to "drop" in towards the center, and past the little gate covering the opening.
As it is, you must stab the key in the general (flat surfaced) area, hoping to land a critical hit, just to be able to start the car.
spazzboy is offline
Old 06-21-2012, 07:46 AM   #20
ic0der
ic0der's Avatar
Fan#: 99386
What I Drive: 2012 S Ford Focus
FF Reputation: 1 ic0der Good Standing Member
I think Titanium was Ford's top priority that made them forgot about this in other trims
Toys:
2012 Focus 1.6L Ti-VCT 128HP European Model(S)
ic0der is offline
