Where's the coolant temp sensor on a duratec? - Focus Fanatics
Old 06-18-2012, 09:51 PM   #1
gjm4l
gjm4l's Avatar
Fan#: 93287
What I Drive: 2007 Dark Toreador Red ZX3 S
FF Reputation: 1 gjm4l Good Standing Member
Figures I finally get around to cleaning up the focus, spent all day on it and the next day the check engine lamp comes on heading to work..... Pulled a PO128 code which is a low coolant temp reading. Everything is checking out fine so I imagine it's the sensor. But compared to my last vehicle (a 92' ranger) the duratec is COVERED in sensors and I thought it had to dang many. So can anybody tell me where the coolant temp sensor is? Or excuse me the Engine Coolant Temperature Sensor (ECT) It's nowhere I expected it to be so I'm confused? Appreciate any help! Including if you know something about this code that I don't know
gjm4l is offline
Old 06-18-2012, 11:05 PM   #2
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
The Duratec uses a Cyl. Head Temp. sensor if I remember correctly. It's located between spark plugs 2 and 3. BUT.......if your coolant level is in the ball park then I'll bet your thermostat is kaput. It is not fully closing and the coolant temp is not getting "up to temp" (not sure of the exact temp., but is usually around 170 to 180 deg. F) quickly enough, and the ECM is setting the P0128.
Grumpy is offline
Old 06-19-2012, 05:49 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 267 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
92 Ranger = not Duratec. Those engines didn't appear until 03. Back in 92 you had OBD1 engine controls which used one sensor for gauges, and another sensor for computer input. That caused a few more sensors than are used now on OBD2 systems where you have one sensor that is for the computer, and the computer sends a signal to the gauges.
I would see if someone has a infrared thermometer where you can check the temperature of the radiator, engine block, and upper radiator hose before you dive into a thermostat job on this car. There is also a way to double check the sensor's readings with the electronic odometer. Key off, press and hold the trip odo reset button, turn key on, continue to hold reset button until the odometer reads [test], now each time you press and release the odo reset button you scroll through one of 30 test functions. It will remain in test mode until you turn the key off. You need to look for the one that reads [40 C] or whatever your temperature should be in C at the time. If the car has cooled overnight, then it's likely to be close to ambient temp. If it has not cooled, expect a higher reading. Drive the car in test mode. You should see your engine temp rise to about 95C, then drop down to 80 or so as the thermostat opens. This cycle will continue several times before the engine temp settles above the thermostat temperature of 92C. You should compare your findings with the test mode with those of the infrared thermometer under the hood. I would expect a 10% difference even if things are working right. More than that could be indicative of a problem with the sensor.
You should also check the sensor wiring, and if you are in test mode and you see sudden jumps or drops in temp to 0 or some ridiculously high temp like 200C, then you know there is a problem with the sensor itself.
The thermostat in this car is not a simple task to replace, so that's why I recommend methods of diagnostics first to be sure that the thermostat is what is failed. With a failed thermostat you won't see the cycling of temperature as I wrote about above. The temp will simply slowly climb up.
If you decide that you want to just replace the thermostat, you'll need an intake manifold gasket, and the correct thermostat. You need an inspection mirror to verify whether or not you have a thermostat with a supplemental sensor built into it. The thermostat is located under the intake manifold on the right side of the engine near cyl 1. Follow the lower radiator hose up to the block, and that plastic doomaflatchie is the thermostat. It is built into the housing. Look online at a retailer with pictures like Rock Auto.com, and you'll see what you should be looking for. If you see anything electrical that plugs into the thermostat housing, then you need the more expensive thermostat. I would also suggest purchasing the lower radiator hose whether you need it or not, and a new PCV hose whether you need it or not because those are not expensive and you need to remove the intake manifold to replace those also.
You will experience sticker shock when you see the price on this thermostat- even from a low priced retailer like Rock Auto. I shudder to think what Autozone is charging for this thermostat. To give you perspective, you can purchase your own infrared thermometer for much less than you can purchase even the cheap version of this thermostat that doesn't have a sensor built into it.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 06-19-2012, 05:57 AM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Nevermind, I just checked, Autozone and Rock Auto have similar prices on these parts. RA was $125 for the one with the sensor, and $20 without sensor. The Zone wants $150 and $27 respectively. Shipping would make the cheaper one more expensive to purchase from RA unless your sales tax is high. I already know that intake manifold gaskets are similarly priced- about $25. I don't know about PCV lines or the valve itself.
There, now you don't have to have sticker shock at least not later. Hopefully you don't have the sensor.
Be eclectic.
Old 06-20-2012, 09:04 PM   #5
gjm4l
gjm4l's Avatar
Fan#: 93287
Thanks for the info. I had no idea there was a way to test from the display I'll be checking that out tomorrow. I checked with the infrared and it's running normal, nothing seems to be off so I'm thinking it's the sensor. But either way I have the tstat housing without the extra sensor so glad it's not holy crap expensive when that time comes. On an interesting note I reset the computer to hide/clear the light and it hasn't come back on since? Which is random whether it was the sensor or the tstat..... I will be playing with that nifty feature I had no idea existed tomorrow thanks whynothtinkwhynot!
Oh but what I meant was the Ranger had WAY fewer sensors not to mention easier to trace systems than the focus does. Maybe it's because I've never had a FWD so it's all discombobulated to me but wow is it confusing
gjm4l is offline
Old 10-29-2012, 06:16 PM   #6
TheSteelGator
Fan#: 103127
What I Drive: '04 French Blue ZX3 D23
FF Reputation: 1 TheSteelGator Good Standing Member
Originally Posted by whynotthinkwhynot View Post
... You need to look for the one that reads [40 C] or whatever your temperature should be in C at the time. If the car has cooled overnight, then it's likely to be close to ambient temp. If it has not cooled, expect a higher reading. Drive the car in test mode. You should see your engine temp rise to about 95C, then drop down to 80 or so as the thermostat opens. This cycle will continue several times before the engine temp settles above the thermostat temperature of 92C. You should compare your findings with the test mode with those of the infrared thermometer under the hood. I would expect a 10% difference even if things are working right. More than that could be indicative of a problem with the sensor. ...
Thanks for the great information, whynotthinkwhynot. So... let's say I've driven around in test mode and the temperature reading hasn't gone past 67 C. But my temperature gauge needle is directly in the middle, and I have plenty of heat coming out of the vents.
Ideas?
TheSteelGator is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
