DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
#1 | ||||
That Guy
Exhaust Wrap
So, I've been analyzing the intake/exhaust setup to look for more of the horsepowers. While I do have a some concepts already, I began to wonder about wrap. Heated exhaust flows at a higher velocity and produces a greater scavenging effect and would theoretically open up a fractional amount of power.
Understand that I am not looking for a massive increase. Simply some discussion on the theory by people who may have a bit more experience with it. I figure that when I do my exhaust, it would be relatively easy to wrap near pre-final install. Most of my route to work is smooth flowing, though I may cook a bit on the way home. Pro's - A couple of ponies? Something cool to make your friend lay on the ground to look at? Con's - High cost, minimal gain, frustrating to work with, high cabin temps Discuss. ![]() Edit: Assume a cost of $200 for a 6"x100' roll.
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderating- DURATEC Ti-VCT Performance (2012-2013) / ST Performance (2013) MK3 Focus / ST Focus Sonic's MK3 Crew Group Buy & Hot Deals |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
The Professor
It's not worth it unless you are trying to keep heat off fragile underhood components that run close to your exhaust. I have seen wraps help in turbo applications (help turbo spool faster and keep underhood temps down). In an N/A application they have very minimal advantages except for what I mentioned in sentence #1.
IMHO, they are an antiquated crutch method compared to more modern coatings which are much much superior. Wraps also greatly reduce the life of your exhaust components (stainless or not). So, in my opinion, stay away from them. Stick with coatings. |
#3 | ||||
That Guy
I forgot about the reduced component life, good call.
So, switching to coatings then, is there still pretty much minimal hp advantage in a NA car?
#4 | ||||
I'd pass on the wrap. There are better places to put your cashola.
Interduce Mr. Torsen to the mix |
#5 | ||||
That Guy
Segue for a second - I don't understand the difference between the gold stars and the grey stars above the avatar. I've searched for the info to no avail...
#6 | ||||
Keeping the heat in the pipe does promote better exhaust velocity, however that usually only applies to high velocity exhaust components like headers and turbo down pipes. I do not see any advantage of wrapping the actual exhaust piping on these cars.
Sal 2012 Race Red 5-door SE, 18" Ti wheels, Ti headlights/fog bezels, 20% tint, debadged trunk 2002 Sonic Blue SVT - supercharged (sold) 2008 Vista Blue SE (gone) |
#7 | ||||
That Guy
My thought process is that if you can use the temp to speed up the larger open area that the high velocity components (actually the whole system) would flow smoother. Probably just over-analyzed on my part.
#8 | ||||
That Guy
#9 | ||||
I just recently wrapped my headers. I did not do it for HP gains or better but just so I could eliminate the heat shield and I think it looks cool.
#10 | ||||
That Guy
How do you feel that this has affected your underhood temps?
| Thread Tools | |
| Display Modes | |
