Engine & Transmission Swap The place to chat about any engine and transmission swap.
#1 | ||||
zetec swap
cuzent is doing a zetec swap for a single cam that took a dump, will the stock auto tranny from the single cam work for the zetec engine?
Remove Advertisements |
Fan#: 1
#3 | ||||
So your asking if a Automatic transmission from an SPI will fit that of a Zetec?
Generally I think the forum likes 24 hours between bumps... not 12. I dont know this answer I would imagine if its the same transmission it should swap over. may need some minor tweaks. There is an engine swap section that you may get more input on what is dont to swap. there should be some build threads or how to's in that section also...
2001 ZX3 2.0L Zetec- Hatch Nation #42 Going through Rebuild See "The TICK Build Thread" for details (http://www.focusfanatics.com/forum/showthread.php?t=289168&referrerid=62897) |
#5 | ||||
http://www.focusfanatics.com/forum/s...ight=SPI+Zetec
Some times you have to dig a little in the search.
#6 | ||||
Yes it'll work. You have to swap the harness section that connects to the transmission, but the transmissions are compatible.
Zetec swapped |
| Thread Tools | |
| Display Modes | |
