MASS AIR FLOW SENSOR HELP!! Sprayed wrong part. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2012, 02:18 AM   #1
mikewayne
Fan#: 99972
What I Drive: 2002 Dark Blue Focus SE
FF Reputation: 1 mikewayne Good Standing Member
Hi guys, please don't bash me for this, as I obviously don't have no mechanical experience in the auto field.
I thought I was cleaning out the Mass Air Flow Sensor, which obviously wasn't the right part. I unplugged a harness that connects to the Mass Air Flow Sensor. After unplugging the harness, I then sprayed the inside of the connector to clean the dirt. Obviously this wasn't the right spot to "clean."
30 minutes later, the car through a CEL, and starting running abnormal. The car has loss of power and acceleration.
Any ideas? I'm hoping it is just the Mass Air Flow Sensor, because I planned to replace this part anyways. Thanks!
mikewayne is offline
Old 06-16-2012, 04:32 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,557, Level 100
Points: 138,557, Level: 100 Points: 138,557, Level: 100 Points: 138,557, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
What did you spray it with? What was the CEL for?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 06-16-2012, 09:04 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
Pics of the part you sprayed please.
The MAF should be in the air intake tube, and you should've let it dry first. Also, what sort of cleaner did you use? You should've used either electrical parts cleaner without lubricant, or spray MAF cleaner.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 06-17-2012, 12:46 AM   #4
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile No, you didnt spray the right part. The MAF sensor is inside your MAF tube (isnt it labled ontop?). The thing the wires are connected too is what you have to remove. Did you even disconnect the battery before disconnecting the sensor?
How to clean your MAF sensor: All you need is MAF cleaner spray, a screwdriver and a security torx bit (I dont remeber what size.) You will also need a socket wrench to remove the negstive battery cable. First disconnect the negative cable on your battery (the black one). Next disconnect the wiring harness that connects to the sensor. Next use the security torx to unscrew the two screws holding the sensor to the MAF tube. Do not lose the screws. Pull out the sensor. You'll notice it has a long tube like thing that sticks down into the MAF tube. Look inside the sensor towards the bottom, you'll see little metal wires. Thats the part that gets dirty. Itll look black or brown. Spray alittle onto those wires and into the sensor. Shake excesse out and let it sit. The stff will work the dirt away and the should start to look more silver when clean. Make sure excess is shakes out and then let it air dry. Once it looks drive just reverse the steps and put it back in.
Now, to try and correct the mistake you made I would disconnect the battery and disconnect the harness. Let that dry out totally, clean your sensor and then hook everything back up and see how it does. Hopefully itll clear the code and everything will work out thst things are dry and clean.
DrkKnight614 is offline
Old 06-17-2012, 09:50 PM   #5
mikewayne
Fan#: 99972
Will update you guys tommorrow tomorrow. I took Sensor out tonight, cleaned it well with Mass Air Flow Sensor cleaner. Re sprayed the wiring harness with the Cleaner and now letting them both dry over night. I did disconnect the battery before, and letting it sit over night.
Old 06-18-2012, 12:44 AM   #6
DrkKnight614
GO Green
Fan#: 14522
Posted via FF Mobile Why did you re spray the wiring harness?
Old 06-18-2012, 02:16 AM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,684, Level 86
Points: 18,684, Level: 86 Points: 18,684, Level: 86 Points: 18,684, Level: 86
Level Up 67% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
It doesn't matter why and frankly I think more people need to clean electrical connectors in their cars. I've only found a few connectors with grease on them. Majority don't and like to corrode,,, even moreso if you wash your engine.
But yes, post the code the car is throwing. We might be able to save you some money (as in not needing a new MAFS).
OH, you're not playing dumb ...
iminhell is offline
Old 06-18-2012, 11:13 PM   #8
mikewayne
Fan#: 99972
Ok guys, update.
Today I disconnected battery, cleaned wiring harness again, and removed mass air flow sensor and cleaned it and let dry over night.
Plugged everything and no cel! Drives great! Much more responsive!
Old 06-18-2012, 11:46 PM   #9
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,646, Level 94
Points: 23,646, Level: 94 Points: 23,646, Level: 94 Points: 23,646, Level: 94
Level Up 30% Completed
Forum Activity 14%
glad to hear you resolved it.
mikebontoft is online now
Old 06-19-2012, 01:01 AM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 60%
Yay!! That's great news.
Moderator for
Technical Chat
