Steeda Short Throw Shifter for 2012 Focus (Now Available) Pics inside - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-02-2012, 01:11 AM   #111
Bwill9886
Bwill9886's Avatar
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by Duffman355 View Post
Apparently all it needed was more vigorous sanding
You ain't kiddin'
I spent about an hour sanding before it was enough to get the bastard on.
God i hate retention springs. I think i need an additional set of hands here. Who would had thought the bracket would be the easy part?
You are right compared to the bracket though, that stupid spring made the bracket look like a cake walk.
Bwill9886 is offline
Old 07-02-2012, 01:36 AM   #112
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
What exactly are we sanding???
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 07-02-2012, 02:19 AM   #113
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 18,979, Level 87
Points: 18,979, Level: 87 Points: 18,979, Level: 87 Points: 18,979, Level: 87
Level Up 26% Completed
Forum Activity 28%
Activity: 28% Activity: 28% Activity: 28%
FF Reputation: 43 Duffman355 Great Standing Member
The surface oh the plate that the linkage connects to in the engine bay. you install the new steeda bracket right next to where the stock one is. the part is precision engineered to be nice and snug so the surface needs to be smoothed to get the new bracket flush.
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 07-02-2012, 10:53 AM   #114
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Yes, and for those who removed the battery and intake, it shouldn't cause you too much strain. It just takes time.
However, I did this newmission's way and didn't remove anything. While I think overall it was a MUCH shorter job, bending over and reaching to sand a part you can't even really see puts a strain on a few body parts after a while.
I'm also probably exaggerating my sanding time. I think it was more like a half hour max. Eventually you should be able to slide the bracket on most of the way and then tighten the two screws enough to pull it to the proper position.
Btw, forgot to give a shoutout to SteedaBrandon! Don't hesitate to contact him guys!
Old 07-02-2012, 03:31 PM   #115
4d4jacklee
4d4jacklee's Avatar
Fan#: 50596
What I Drive: 2013 Black ST1
Points 837, Level 15
Points: 837, Level: 15 Points: 837, Level: 15 Points: 837, Level: 15
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 4d4jacklee Good Standing Member
I've had my shifter on a couple of weeks now and the feel has improved greatly. It was a bit sluggish, with a lack of crispness at first, but I was just realizing today, it's become a nice clean shift now.
I had to use a c-clamp to squeeze the Steeda adapter bracket over the stock linkage, and then elongate the beefier of the two holes on the hold down plate to install the allen screws.
The only unsolvable problem I had, was getting the shifter lollipop off the stock linkage. I CAREFULLY tried every center punch, Phillips head screwdriver, pry tool combo I had, NO DICE! I finally just two hand popped it off.
I'm taking the car to Willow Springs this Sunday, and letting her rip, so we will see!
4d4jacklee is offline
Old 07-02-2012, 08:05 PM   #116
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Oh boy that was fun. I don't know how you guys could get your hands in there without removing the air box and battery. I have know idea what the punch, phillips screwdriver does for ya cause it didn't do diddly. I just pryed it off. Very minimal sanding to get bracket on fit was nice and snug like it should be. So far so good. Still have to do the inside work yet.
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
Old 07-02-2012, 10:42 PM   #117
Bwill9886
Bwill9886's Avatar
Fan#: 93444
I put the trans into 2nd gear which gave me the best access (could see most of the linkage) and just reached down in the space between the engine and battery.
Odd the phillips didn't do anything for a few of you. It took a little effort (at an off angle because I didn't remove anything) but it popped off second try.
Old 07-02-2012, 11:56 PM   #118
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
Forum Activity 28%
Yeah i was able to pry it off no problems with nothing but a flathead actually.
Randomie's Lover #8
Old 07-03-2012, 12:27 PM   #119
mustang0
mustang0's Avatar
Fan#: 96079
Well after the test ride last night, I really like the way it shifts. Also with the MS3 motor mount everything seems more connected and solid. Now I just have to get that shift knob finished and installed. Or just order the cool colored Blox one.
http://i1265.photobucket.com/albums/...NL__SS500_.jpg
mustang0 is offline
Old 07-03-2012, 02:36 PM   #120
SteedaBrandon
Fan#: 96136
What I Drive: n/a
FF Reputation: 1 SteedaBrandon Good Standing Member
Guys, feel free to post up reviews of your shifter on the product page. Your feedback would be greatly appreciated. :)
http://www.steedafocus.com/parts/201...w-shifter.html
SteedaBrandon is offline
