Steeda Short Throw Shifter for 2012 Focus (Now Available) Pics inside - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-21-2012, 03:43 PM   #91
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Just ordered the shifter kit can't wait. Thanks again Brandon!
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
Old 06-21-2012, 04:01 PM   #92
SteedaBrandon
Fan#: 96136
What I Drive: n/a
FF Reputation: 1 SteedaBrandon Good Standing Member
Thanks Dale!
SteedaBrandon is offline
Old 06-21-2012, 04:07 PM   #93
memphiscbrider
Fan#: 86469
What I Drive: 2012 white se
Points 634, Level 12
Points: 634, Level: 12 Points: 634, Level: 12 Points: 634, Level: 12
Level Up 68% Completed
Forum Activity 3%
FF Reputation: 1 memphiscbrider Good Standing Member
Brandon. Can you get the those of us that couldn't get the code to work 10% off still? I tried the code long before it had been two days and it wouldn't work. Thx
Current Rides:
2008 Honda CBR1000RR
2012 Ford Focus SE
memphiscbrider is offline
Old 06-21-2012, 04:18 PM   #94
SteedaBrandon
Fan#: 96136
What I Drive: n/a
Shoot me a PM and I will see what I can do for you. :)
Old 06-22-2012, 06:13 PM   #95
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
Finally installed mine. And to answer my own questions, I did a two part install with the bracket first. My review of that, is it is well worth the $65 in the amount of reduction it gives! However, this should only be for the budget minded as it left a "spongy" feel to throughout all gears. After the full install with the Tri-Ax added, the feel was much more solid! Was there a noticeable reduction with the Tri-Ax? Not really. The bracket really takes the grunt of it all. But for fine tuning, the Tri-Ax is a must have addition!
Also. For those that get the kit and are a bit intimidated by the install instructions for the bracket, there is hope. I successfully installed the bracket without removing a single item. A long phillips will pop the cable off, and rotating the gearbox lever will gain you access enough to turn a wrench. Now one thing I will add, is the instructions were not clear on what flashing to remove from the lever. I would assume if I were to follow all of the removal instructions, I would get a better view of the lever and would understand what flashing it was referring to. But to be clear, it is the flashing on the sides of the lever, where the bolts of the bracket are. I would recommend filing this smooth just in case.
Here is a shot of the space around the lever with everything still in it's place.
Pointing to the bracket with the lever rotated.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 06-22-2012, 06:25 PM   #96
Bwill9886
Bwill9886's Avatar
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Nicely done sir! I like hearing that I wouldn't have to do as much work haha!
Sounds like you confirmed our suspicions as well about the bracket. Thanks for trying that out.
Bwill9886 is offline
Old 06-25-2012, 12:56 PM   #97
Meathead
Meathead's Avatar
Fan#: 97158
What I Drive: 2012 SE 5 speed w/ Sport Package
FF Reputation: 1 Meathead Good Standing Member
Originally Posted by REDFOCZ View Post
This is great!
Here is a picture of the shifter installed
If you use it on the shorts throw you will need to do some trimming, not too bad though
To install the bracket you have to pop of the linkage here
And this is what it looks like with the bracket on
More pics are available apon request
I see you are running the "max throw reduction", just like me!
2012 Oxford White SE 5-speed w/ Sport & Winter Package || Steeda STS | FSWerks Intake | Custom S.S. Catback Exhaust | Aluminum Pedals | Clear Bra Hood Wrap | 35% Tint | Tinted Tails | White Badges
Meathead is offline
Old 06-25-2012, 01:01 PM   #98
Meathead
Meathead's Avatar
Fan#: 97158
FYI, if you are clumsy and drop one of the 2 set screws down into the belly of the car while installing the shifter, they are 5/16"x1/4" and Home Depot has them in stock.
Meathead is offline
Old 06-25-2012, 01:13 PM   #99
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,372, Level 100
Points: 41,372, Level: 100 Points: 41,372, Level: 100 Points: 41,372, Level: 100
Level Up 0% Completed
FF Reputation: 2 _RED_ Good Standing Member
Yep, since the pre production one came out lol
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, Borla Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is offline
Old 06-25-2012, 07:57 PM   #100
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Yo RED, ya busy July 7 & 8? Wanna help me install mine? Taking a run up the canyon with the local Foci too ;)
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
