Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 06-09-2012, 08:56 AM   #1
feta_mgp
feta_mgp's Avatar
Fan#: 88210
FF Reputation: 6 feta_mgp Good Standing Member
DCT quirk after 12B37 update
So I had the recalibration done 2 weeks ago exactly and I've been holding off on posting this or checking in with the dealership and wanted to ask if anyone else is having this issue...
So, I'll be driving to/from work or on the interstate with cruise control on (haven't paid attention to whether or not this happens without using CC) and occasionally and for no apparent reason my transmission will kind of hiccup, that's the best way I can describe it. For instance on cruise doing 50 to and from work, my tach sits about 1800RPMs, when these hiccups occur the tach will "spike" up to 2000-2100RPMs and then back down, and I can feel that it almost disengages and I can feel the car slow for that split second and then regain itself and the RPMs settle back to 1800 or so.
It's tough to catch because it happens intermittently (but I'd say a few times every time I drive) and I can't just keep paying attention to the tach.
I tried to snag a video, you can see it happen twice in this video, but it's shaky and I apologize for that, couldn't really help it though.
First hiccup around 0:17-0:18, second around 0:55. Also, pardon the music, didn't bother changing the station when I got in. I'm more of a punk/rock/ska kinda guy.
YouTube Video
2012 SGM SEL Sedan 303a w/o Nav
Job 1 built 6/2011
feta_mgp is offline
Old 06-09-2012, 09:08 AM   #2
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
Sorry, I couldn't really see anything in that video, but, our cars are equipped with "smart" cruise control when equipped with the DCT. Basically the car will use the transmission to downshift momentarily to maintain the set speed exactly, this prevents the car from coasting and gaining extra speed. It talks about it in the manual....I like to hypermile, so I don't use cruise control on hilly areas on the highway because of that. Even very slight inclines can get annoying.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 06-09-2012, 09:53 AM   #3
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
FF Reputation: 2 Bliky Good Standing Member
Yeah, it's subtle because you're at low RPM but I think it's going into 5th either to climb a hill or for slight engine breaking (what you feel when it slows for a second).
Try this: jump on the highway or wherever you can cruise at 50 like usual. Turn cruise control on and swap to S then hit the + button to make it go into 6th and watch to see if it still does it... As far as I know if it's in S+ the cruise control will not up or downshift by itself unless it *really* needs to. If the problem persists I'd say take it to the dealer.
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
- Mods: MazdaSpeed3 RMM, Steeda Rear Sway Bar, Steeda CAI, Steeda Springs, Koni Shocks, ST Struts, FSWerks Stealth Exhaust, Euro Tail Lights
Bliky is offline
Old 06-09-2012, 10:05 AM   #4
TboneZX3
TboneZX3's Avatar
Fan#: 90494
What I Drive: 2012 SE Sport 5Dr, SGM, 5-spd
FF Reputation: 5 TboneZX3 Good Standing Member
RPM looks steady as a rock in the video.
'12 SE Sport 5Dr |╠╬╝|Sterling Grey Metallic|203a|Moonroof|17" Mach/Paint Whls|K&N Typhoon|FFE RMM|Steeda STB, RSB
TboneZX3 is online now
Old 06-09-2012, 12:01 PM   #5
feta_mgp
feta_mgp's Avatar
Fan#: 88210
I'm in Florida, so no hills here, no engine braking for any reason, no upshifting/downshifting, just literally a blip where the RPMs rise about 2-300 and the car feels like it's got no power, as if the clutch is disengaged. I'll try to get a more steady video, but I thought the hiccup at :55 was pretty obvious. It's just literally a split second that the needle moves, so it's tough to catch, but it's there.
Job 1 built 6/2011
feta_mgp is offline
Old 06-09-2012, 09:33 PM   #6
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Ford Focus 2012 SEL Hatchback
FF Reputation: 3 VOLDAR Good Standing Member
Not trying to be an a$$, but do you really call this a "quirk" ? Because this can be caused even by the irregularity of the road or the quality of the gasoline.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
VOLDAR is offline
Old 06-09-2012, 10:51 PM   #7
feta_mgp
feta_mgp's Avatar
Fan#: 88210
I'm calling it a quirk because it's only happened regularly after the newest update. This has NEVER happened to me before, regardless of what gas station I used, what grade of gasoline I used, and where I've driven. I drive the same roads every day of the week, so... yes, I call it a quirk.
Job 1 built 6/2011
feta_mgp is offline
Old 06-10-2012, 07:12 PM   #8
allyy
Guest
Fan#: 95236
What I Drive: 2012 focus
FF Reputation: -3 allyy Poor Behavior Needs Improvement
here is some one that regrets the update
http://www.youtube.com/watch?v=ruRsxa6X3DI
allyy is offline
Old 06-10-2012, 07:28 PM   #9
feta_mgp
feta_mgp's Avatar
Fan#: 88210
I don't regret the update at all, I just have this one issue with it. It seems that after watching that video that maybe these reflashes are inconsistent, mine doesn't grind gears, it used to though. Mine also doesn't clunk at all, and it's only been jerky in low gears once for me, the last 2 flashes have been much more frequent.
Job 1 built 6/2011
feta_mgp is offline
Old 06-10-2012, 07:28 PM   #10
GoShockers
Fan#: 95869
What I Drive: 2012 Ford Focus SE Sport 6-Speed PS
FF Reputation: 2 GoShockers Good Standing Member
I saw the two hiccups. That sucks man. I don't like the update either. Someone said that your car is trying to go back into 5th??!! I sure as hell hope not at your speed. Why oh why can't we have the option of reverting back to the old software... my transmission worked perfectly for me and was as smooth as glass.
GoShockers is offline
