sporadic's Turbo Duratec build #2 - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-30-2012, 11:14 PM   #21
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,978, Level 74
Points: 12,978, Level: 74 Points: 12,978, Level: 74 Points: 12,978, Level: 74
Level Up 32% Completed
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Never a dull moment. It's very convenient having a spare motor to mock up things, but I forgot that I don't have any accessories on that spare motor! After I finished welding up the wastegate return and went to mount it on the car I quickly realized the wastegate is hitting the alternator! I could 1) cut and reweld the wastegate routes 2) grind down part of the alternator or 3) grind down part of the wastegate. The wastegate lost.
The side wastegate nipple was hitting the alternator, as well as about 1/8" of the aluminum housing (vac area not the steel exhaust route). This all actually turned out to be a blessing, as I found that part of the diaphragm was pinched between the halves of the aluminum housing. I disassembled the wastegate nearly completely in order to clock the housing so the nipple wouldn't hit the alternator. A bit of grinding later and it fits fine.
Wastegate ground. Please ignore the funky old welds on the manifold.
If only all my cuts were perfect then all the welds would look like this:
Fits now!
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 07-02-2012, 09:51 PM   #22
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
All welding done and parts painted. I paint my welded exhaust parts to keep them from rusting too quickly. Some of my welds from 5 years ago had not rusted yet after painting them. Painted with 1200* grill paint and cured on the grill. The only thing left in Phase 1 should be routing the water lines, mounting everything and checking out the tune. I hope to wrap up tomorrow/Wednesday.
Old 07-04-2012, 11:02 PM   #23
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Turbo is on and no apparent oil, coolant or exhaust leaks. Tomorrow after work I'll do some datalogging and adjust the tune as necessary. I didn't get a chance to drive it today, just let it idle up to temp to check for leaks.
Old 07-05-2012, 12:14 AM   #24
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Its great when there no leaks etc
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 07-05-2012, 05:20 PM   #25
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
The turbo is on and spooling and running fine with zero leaks. This is actually the first time my car has not had exhaust leaking from somewhere.
The bad news is the wastegate spring is only 6psi instead of 8psi, so it wasn't a very exciting drive. The tune is overly rich since dropping from 11psi to 6psi, but I'll touch that up a bit until I get a new spring or boost controller. More pics to follow.
Next project is the house, not the car so it will be some time before I get back to it.
Old 07-05-2012, 10:34 PM   #26
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
I believe I determined I have a 7.2psi spring in the wastegate. I had the spring out twice and I'm fairly certain it was green. HERE is the guide from Tial. I would have sworn the boost gauge didn't go above 6 though, but I guess I was trying to watch a lot of things a the same time.
I'm not sure if I'll go with the 8.7psi or the 10.1psi spring. Probably the 10.1psi...
EDIT: I believe the difference in boost readout is because I have my boost gauge referenced off the manifold and the wastegate gets its pressure off the compressor housing.
Installed photos:
Without manifold heat shield
With manifold heat shield (modified stock heat shield)
Sorry no decent under-car photos. I tried to take some tonight and it just didn't work out. Next time I'm under the car in the daylight I'll take some.
Overall I have to say I'm extremely happy with how smoothly the build went. I am also a firm believer in v-band clamps now!
I've only had it out for one drive to help dial in the tune, so I can't really comment yet on how fast the turbo spools etc. I should have more input after this weekend, and my also post data log info.
Old 07-05-2012, 11:03 PM   #27
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,159, Level 91
Points: 21,159, Level: 91 Points: 21,159, Level: 91 Points: 21,159, Level: 91
Level Up 62% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
do you have your wg referenced to the IM or the compressor housing?
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 07-05-2012, 11:06 PM   #28
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
I put that in an edit above: wg references the compressor housing and boost gauge references the manifold, so the difference there is the pressure drop across the piping/intercooler.
Another guy pointed that out to me. I really should have thought about that.
Old 07-06-2012, 12:15 AM   #29
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
Points 14,826, Level 78
Points: 14,826, Level: 78 Points: 14,826, Level: 78 Points: 14,826, Level: 78
Level Up 94% Completed
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
Did you get ARP studs for the header?
What's the size? 8 X 1.25?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 07-06-2012, 05:08 AM   #30
K26
K26's Avatar
Fan#: 51125
What I Drive: 2006, Red, turbo'd ST
Points 4,983, Level 45
Points: 4,983, Level: 45 Points: 4,983, Level: 45 Points: 4,983, Level: 45
Level Up 17% Completed
FF Reputation: 8 K26 Good Standing Member
Got any video of this man?
FOCUS FACTOR
K26 is offline
