Very frustrated! - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2012, 11:05 PM   #51
nekoashide
Fan#: 50156
What I Drive: 2010 Ford Focus S
FF Reputation: 1 nekoashide Good Standing Member
Sounds like the EGR Vacuum Solenoid on the firewall. It's supossed to open/close depending on RPM. Mine started going bad and it had a horrible idle/dies when stopped at lights or coming to a stop. No CEL and it was about the only thing i hadnt replaced because it acted just like a vacuum leak.
nekoashide is offline
Old 06-05-2012, 11:54 PM   #52
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Zetec's don't have a fuel pressure regulator and are return less fuel system. EGR possibly, but should do vacuum and hoses check or replace first, which are not much $$$ and is the most common.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 06-06-2012, 01:22 AM   #53
RICHARD2238
Fan#: 88329
What I Drive: 2002 ZTS
FF Reputation: 1 RICHARD2238 Good Standing Member
any luck with it yet let me ask a basic question how long has it been running like this did it start over night or has it been going on for some time ????
RICHARD2238 is offline
Old 06-06-2012, 05:47 AM   #54
cma8302000
cma8302000's Avatar
Fan#: 99700
What I Drive: 2000, silver SE SPORT
FF Reputation: 1 cma8302000 Good Standing Member
It's been going on quite some time...I would bring it to a mechanic and he would change something ..it would still do it , I would wait a while bring it back and he would change something..it would still do it...it's been an ongoing thing....I just can't believe how many things can cause the same symptoms..it's enough to make your head spin...
cma8302000 is offline
Old 06-06-2012, 07:23 AM   #55
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Maybe it's time to go see another mechanic?
malim is offline
Old 06-06-2012, 02:35 PM   #56
cma8302000
cma8302000's Avatar
Fan#: 99700
Posted via FF Mobile
its with another mechanic...not going back to the one i used before
Old 06-08-2012, 04:55 PM   #57
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile Any update on this?
DrkKnight614 is offline
Old 06-08-2012, 06:07 PM   #58
cma8302000
cma8302000's Avatar
Fan#: 99700
last i heard , and I am not rushing the guy is that he has checked everything and replaced parts...He's been online to ford forums and focus forums ( probable even saw this) but nothing he's tried fixed it...he said he thinks maybe the computer?...I think he tried the reset thing you suggested... I haven't heard from him yet today so I dont' know the outcome yet...I will let y'all know when I know....OH YEAH, DID I MENTION MY AIRBAG LIGHT IS ON AND MY HORN DOESN'T WORK... that's another thing that's been going on for a while too but the first issue was happening way before the airbag light came on....Sorry y'all but that particular car is a piece of crap...So, once I get it back a For Sale sign will be going up on it.....I will keep y'all posted...AND THANKS SO MUCH FOR ALL THE INPUT... be back soon.....
Old 06-09-2012, 11:29 AM   #59
DrkKnight614
GO Green
Fan#: 14522
Grab another Focus if you can. Gremlings seem to be the problem.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
Old 06-10-2012, 12:17 AM   #60
agentmaroon108
Fan#: 94633
What I Drive: 2002 snow white ZX3 5-speed
Points 6, Level 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Level Up 11% Completed
FF Reputation: 1 agentmaroon108 Good Standing Member
same issues...
seems like every focus nowadays is having a rough idle problem. i drive an 02 zx3 5 speed. i previously had an '00 zx3 5 speed, but totaled it. it had the same rough idle problem but due to being cross-eyed at the end of its poor life, i had no opportunity to fix this problem at all. anyways, the issue at hand i'm having is that when i come to a redlight or any prolonged stop, the car stalls. it sputters, bucks, and shakes until it eventually stalls unless you constantly give it gas. if i do decide to play the battle and give it gas, it will stay running until i am able to take off and shift into 1st. otherwise, as soon as i decide not to give it any gas, or start to and then stop, the car will either stall or dip down to about 100-300 rpms. it constantly tries to fix itself, and jump back to a normal idling rpm, but usually is unsuccessful. i recently changed the pcv hose in an effort to fix this, as well as running seafoam. neither seemed to change the problem. seems as though there are about 15 different things that supposedly remedy the problem but the main question is where do i start? ive heard egr valve, fuel filter changes, regular oil changes, spark plugs, crankshaft sensor, iacv, pcv, any other vacuum leaks, spark plugs, ecu, replacing the recalled fuel pump and fuel injectors.... to name a few. seeing as things add up quick and half are ford parts, other half aftermarket, im trying to start with the most successful first. i've looked on hundreds of sites, and hundreds of forums but no one has an answer. is this a mythical solution? i really hope i dont have to find out by my beloved focus dying of one last final stall out.... please help!
agentmaroon108 is offline
