Very frustrated! - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2012, 01:49 PM   #41
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile How much have you spent? Maybe would of been better of buying a new engine?
DrkKnight614 is offline
Old 06-05-2012, 02:37 PM   #42
cma8302000
cma8302000's Avatar
Fan#: 99700
What I Drive: 2000, silver SE SPORT
FF Reputation: 1 cma8302000 Good Standing Member
[QUOTE=DrkKnight614;4199525]Posted via FF Mobile How much have you spent? Maybe would of been better of buying a new engine?[/Q
I bought this car used a few yrs ago because my 99 ford ranger 3.0 v6 used to much gas going back and forth to work especially I think after putting bigger tires on it....I figured I would get a little economical commuter car...I paid $1900 for it ...I think within the last 2 yrs, I've probably spent well over that on crap for that car....I was really wanting to keep it going because my Ranger is in excellent condition and just turned 91k miles..I try to use it sparingly...depending on the outcome of this major issue with the car, I may just have to use my beloved Ranger as my primary vehicle ....I really like my zippy little car but .......enough is enough......
cma8302000 is offline
Old 06-05-2012, 03:31 PM   #43
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
What I Drive: 2003 CD Silver SVT
Points 1,282, Level 19
Points: 1,282, Level: 19 Points: 1,282, Level: 19 Points: 1,282, Level: 19
Level Up 82% Completed
FF Reputation: 2 B3NN3TT Good Standing Member
Sounds like classic ignition issues to me, and I'll third or fourth the suggestion about plug wires.
Intermittent misfires don't always cause Check Engine Lights or throw codes. You said the plugs and coil pack were replaced, the plug wires SHOULD have been replaced right along with them.
Chances are good now that your continued misfires from bad plug wires have damaged your new plugs, and possibly your new coil pack.
My suggestion - buy 4 new plugs and a NEW set of wires and replace them all at once, start fresh. Pray the coil pack isn't damaged (they are generally a little more robust than the other parts, so you might get off OK).
2003 SVT #2370 Hatch Nation #91 2000 Roush Cougar 2008 Mustang Bullitt #5389 2013 Fiat 500 Abarth
B3NN3TT is offline
Old 06-05-2012, 03:42 PM   #44
cma8302000
cma8302000's Avatar
Fan#: 99700
I just looked at an old receipt...I had plugs , wires and fuel filter all changed at the same time...
Old 06-05-2012, 08:40 PM   #45
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by Mother Focus View Post
X2!! Also check your pcv/hose and booster hose, they collapse over time.
IAC is on the bottom of the intake manifold although I don't think that's the culprit.
Originally Posted by iminhell View Post
What brand sparkplugs?
Motorcraft are recommended and tend to be the best option.
I wouldn't think anything you've replaced would have any bearing on the problem. Not sure who told you to replace all those things but, I would have more caution listening to them.
Has the A/C been serviced?
If not, it might have some bearing of the 'sputter'. Low system pressure can cause the compressor to cycle more often. Possibly often enough that the IAC can't compensate fast enough.
Backfiring and such sorta sounds like you may have a vacuum leak or the cam timing may be off.
Originally Posted by DrkKnight614 View Post
Posted via FF Mobile Ya check the PCV hose, those are a known issue.
...And again pcv hose or booster hose.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 06-05-2012, 09:10 PM   #46
cma8302000
cma8302000's Avatar
Fan#: 99700
[QUOTE=Mother Focus;4200130]...And again pcv hose or booster hose.[/Q
he did find a vacuum leak, but it didn't solve the problem...I will run the pcv and booster hose by him when I call him tomorrow...to late to call tonight...
Old 06-05-2012, 09:11 PM   #47
cma8302000
cma8302000's Avatar
Fan#: 99700
Old 06-05-2012, 09:18 PM   #48
Mother Focus
Fan#: 73292
After that reset the ECU as Drknight suggested.
PTE 6262CEA
Old 06-05-2012, 09:20 PM   #49
cma8302000
cma8302000's Avatar
Fan#: 99700
<sigh> I will...thanks
Old 06-05-2012, 09:39 PM   #50
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
Some of these modern cars use a dual speed fuel pump. I see were you mentioned the "fuel delivery module" was replaced per the recall, but the replacement may be bad or some other issue with fuel flow/pressure.
At higher RPM's the pump should run at a higher rate to increase fuel flow to the injectors. Checking idle pressure would should be easy. If ZETEC uses a dual speed pump, I don't know if there is a speacial procedure to check the higher rate. Another related simple part is the Fuel Pressure regulator.
(Just another item for your check list....)
spiller is offline
