The TICK build thread - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2013, 01:11 PM   #41
200two-zx3
200two-zx3's Avatar
Fan#: 108491
What I Drive: 2002 blue zx3
FF Reputation: 2 200two-zx3 Good Standing Member
Originally Posted by Magus2727 View Post
Got the header welded up.
Use a MIG welder with Argon to go the welding. While welding the header patch the setting was a bit hot so did blow through a few small areas. was able to weld up the holes and used my Oxygen Acetylene torch to reheat and flow the weld to require less grinding.
I was able to get the EGR bung flown quite nicely and requires no real grinding. Could not get the patch as nice looking so has required more grinding.
I got the patch welded up on to the top side to take care of the large hole. I still have a little bit of grinding. that can be seen on the first image. I also need to grind down the inside, runner a little where the patch went. The two locations where I blew through the header has some blobs of weld on the inside that I want to grind down. Need to get one of the flex attachments to a dremmel so i can get the 3-4" into the runner and grind it down.
Unfortunately the oil pan was not as good.... it was fine when I did the MIG welding but worried that I did not have good flow or completely sealed off between the bung and the flange I think I ruined the pan.
I think I overheated the metal while I was flowing the metal. After getting the "slag" off I found the following.
I don't think this is salvageable. In my free time I may try to weld it up. But I plan on getting a pan from Tom. I think this welding may need to be done by a TIG or someone with a lot more experience than my self.
Very nice thread also nice job on the build you'll surely enjoy this engine
I am wondering what the bung is for on the oil pan?
Claim not, dynos prove all!
200two-zx3 is offline
Old 02-03-2013, 01:28 PM   #42
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,708, Level 62
Points: 8,708, Level: 62 Points: 8,708, Level: 62 Points: 8,708, Level: 62
Level Up 86% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Thanks!
Bung on the oil pan is for an oil return feed so when I eventually turbo it.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 02-03-2013, 01:37 PM   #43
200two-zx3
200two-zx3's Avatar
Fan#: 108491
Thanks!
Ok that's what I was thinking but I try not to ass~u~me lol
It was a good try tho you'll get it
Old 02-03-2013, 01:40 PM   #44
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Well that's also what I get when trying to use a rose bud cutting tip to do braising. Along with using unknown rods that I inherited along with the welding setup. Will most likely just leave the MIG weld alone next time.
Hatch Nation #42
Old 02-11-2013, 01:10 PM   #45
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Got a new oil pan from a local member... there was some surface rust so after getting the hole for the new bung I decided to tackle the rust. I may have gotten a little carried away... its to bad that the pan is steel, it all polished up, perhaps I should just clear coat it?
Tax returns are done and getting back more than expected, so will be using that to take care of some more of the engine rebuild to get a number of things done.
Plans with tax returns:
Get more POR-15 paint
Will be getting wheel bearings pressed out, and use POR-15 to paint knuckles.
Get bung on oil pan professionally TIG welded and paint with POR-15
Get Titanium Exhaust wrap and silicon spray to wrap header
ARP Head studs
Plans with a 3rd pay check in May:
Pulley Kits (all new belts, tension and idler pulleys)
ARP Cam Bolts
Hatch Nation #42
Old 02-22-2013, 11:35 PM   #46
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Ordered the ARP Head Studs. Will have those on Tuesday. Thank you C-F-M.
Ordered POR-15 paint (1 Pint - Black) have it on Friday of next week
Got the bearings pressed out and working on cleaning up the knuckles. Spent a good 3-4 hours with the wire wheel and rust remover. Got them cleaned up and they are ready for paint when I get it next weekend. and then in 2 weeks have the bearings pressed back in with new Timken bearings and new spindles.
Got the Bung TIG welded in. Had enough paint to paint the inside of the pan where the heat bubbled the powder coat.
Going to Auto Rama tomorrow might get some ideas or find shops that can help with my build.
Will have to get the exhaust wrap at a later date when I got more $$$
Hatch Nation #42
Old 02-24-2013, 01:38 PM   #47
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Got the painting done early.
Plan on getting a sheet of the silver/gold reflective material with the pressure sensitive adhesive on the other side. To put that in the small section of the pan that the exhaust routes directly under.
I will have to update this post with my "clean" knuckles. I spent a good deal of time with a wire brush and rust remover. Need to clean up the mounting features and the mask them off in preparation to the paint.
Hatch Nation #42
Old 03-09-2013, 12:43 PM   #48
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Got more paint last week and preped the front knuckles:
Before Paint:
After paint:
The chili cans were just the perfect diameter and only can in the pantry...
The shop that i use to do my machine work is closed on Saturday and with me doing the painting on Friday, it will be next Friday when I am able to get the new bearings and spindles pressed in.
Hatch Nation #42
Old 03-13-2013, 09:32 PM   #49
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
I sold some old school books back to Amazon, so was able to get some stuff early....
Got Gold foil to line the oil pan where the exhaust routes under. I will be wrapping the flex pipe and cat pipe with exhaust wrap also. so this is a little extra to just try to prevent heat soak while at idle.
Got a fiber glass kit to attempt to patch / repair my front bumper along with doing the mod to install two gauge locations in the "coin" tray. I already have the 2" PVC. So I can work on this while I am waiting on other things.
Got a 2" x 50' roll and a 2" x 15' roll of DEI titanium to wrap the header along with the stainless steel wire ties. Whats the best way to make sure I can get a good tight wrap on the header? any way to attach it to something? I do have the motor out I can mock up the head on the block and attach the exhaust manifold and work on the wrap attached to the motor but out of the car....
I also was able to get the bearings and hubs installed in the knuckles faster than expected. I believe I still need to adjust the retaining clip to make sure the opening is in the correct location.
Hatch Nation #42
Old 03-13-2013, 10:16 PM   #50
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,979, Level 83
Points: 16,979, Level: 83 Points: 16,979, Level: 83 Points: 16,979, Level: 83
Level Up 26% Completed
Forum Activity 2%
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
Good to know I'm not the only one who ones to crazy lengths to clean and make parts people hardly ever see look great!
FocusFest 11' "Best in class" Oct'11 HOTM FITF'12 "Best Show & Shine" July 12 ROTM
instagram @360DSGNS
zx360 is online now
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
