The TICK build thread - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-01-2012, 09:49 PM   #11
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
SPOON!!!
Been wondering when you were going to post some pics since you been asking a ton of questions lately. Looks like it's getting together quite nicely, keep the updates coming!
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 06-02-2012, 11:20 AM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,384, Level 61
Points: 8,384, Level: 61 Points: 8,384, Level: 61 Points: 8,384, Level: 61
Level Up 78% Completed
Forum Activity 36%
Activity: 36% Activity: 36% Activity: 36%
How many versions of the zetec block castings were there??? Just the normal and the SVT? I am finding it fairly difficult to locate some of the smaller small parts like the righjt size freeze plugs (my block only has a total of 2 expansion plugs, the SVT Zetec bloc appears to have 6...). The oil pick up gasket that came in the Fel-Pro lower gasket kit is no where close to the right gasket.
Wonder if I have a rouge block or not.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 06-02-2012, 04:16 PM   #13
FLYLOW
FLYLOW's Avatar
Fan#: 34077
What I Drive: Gen Coupe Rspec
FF Reputation: 4 FLYLOW Good Standing Member
Buy-Sell-Trade Rating: (7)
subed
FLYLOW is offline
Old 06-02-2012, 04:46 PM   #14
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 53%
I have no idea about the blocks being different for zetecs. I know the SVT has differences but are very similar to a zetec.
Moderator for
Technical Chat
Old 06-04-2012, 11:50 AM   #15
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 36%
Name that gasket
I got the Fel-Pro lower gasket kit from C-F-M I have already installed the rear main (along with its gasket)
I have also identified in the above image (from right to left) the PCV/oil seperator gasket, oil pick up gasket, front main seal, oil pump gasket.
I have not gotten to the point on using the other 4 gaskets. I am guessing that the large paper gasket is for the water pump. This remains the large black and small brown rubber o-rings and the ridged white plastic o-ring.
Also in regards to the oil pick up. Right now there is a soft green gasket recessed in the top of the tube, this is the gasket I was expecting in the kit... do I remove this gasket and use only the full paper gasket?
Thanks!!
Hatch Nation #42
Old 06-10-2012, 05:05 PM   #16
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 36%
Well made some progress this weekend. Got some sensors installed on the block, got the second freeze plug installed, have the rear main seal on. I also worked on the SVT exhaust Manifold and cut off the tabs for the heat shield and ground them down.
The big hole is from removing this pipe...
Trust an exhaust shop to weld in a pipe for an EGR and have it stick in the exhaust runner 1" and be a huge obstruction. I am going to get a piece of 1/8" stainless steel stock bar and heat it up cherry red and bend it to a nice little patch. Then take it to a weld shop who knows what there doing put a patch on and then put on a EGR bung taken from a stock manifold. Like the picture I found below...
Hatch Nation #42
Old 07-14-2012, 05:35 PM   #17
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 36%
Did some work this weekend and did a fit check of the EGR tubes that picked up last week.
Painted the Exhaust to EGR valve tube in high temp black paint after prep. And painted the coil pack / bracket using POR-15.
However have one problem... the EGR tube does not quite fit as I thought it would with the SVT header. Guess the header still comes further out which pushes out the tube it self.
Should I cut the tab off the EGR tube? Sucks that I painted and did the fit check after it was all painted and now might cut a tab off...
Hatch Nation #42
Old 07-14-2012, 05:49 PM   #18
Polak
Polak's Avatar
Fan#: 92908
What I Drive: 03 Pitch black SVTF
FF Reputation: 1 Polak Good Standing Member
Loving the build so far, doing everything right. It's going to come out great
Polak is offline
Old 07-15-2012, 09:05 AM   #19
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Nice build, I like where this is going
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 07-15-2012, 06:07 PM   #20
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
dont cut the tab. if anything go thethe hardware store and get a stainless sleeve and a long enough bolt that will fit for now. when it come time for the intake manifold you may ahve to adjust things again for the egr tube.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
