IROC turbo build continues - Page 39 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 08:20 PM   #381
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
sounds like flywheel teeth are missin
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-11-2013, 08:59 PM   #382
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,537, Level 100
Points: 52,537, Level: 100 Points: 52,537, Level: 100 Points: 52,537, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
Need to make sure your bendix isnt staying engaged , if it isnt loosen your starter bolts just enough to have some one rotate the starter as much as he can and hold it why you tighten the bolts , try both directions see if it gets quiet , bendix first
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-11-2013, 11:14 PM   #383
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
What I Drive: 03 svtf
Points 13,954, Level 76
Points: 13,954, Level: 76 Points: 13,954, Level: 76 Points: 13,954, Level: 76
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 5 hardSVT Good Standing Member
Buy-Sell-Trade Rating: (7)
What's the bendix?
Flywheel looked clean on install
Had the starter tested and it passed
RIP SVT
300hp mazdaspeed3
Rocco's built turbo zetec mine now!
hardSVT is offline
Old 06-12-2013, 12:51 AM   #384
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
Rocco is this how you had the boost controller setup?
RIP SVT
300hp mazdaspeed3
hardSVT is offline
Old 06-12-2013, 01:03 AM   #385
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Thats how I had it set up. Just make sure the EBC is zero on all settings. Then you can start upping the settings. With the new turbo, you might have to go with the other set up. When I first installed the Comp , even at zero it was makeing like a minimum of 18 psi boost. With the other set up I could dial it down to 11 Psi. And we had it as high as 23-24 iirc. Try both ways to see which you like better.
And as far as the starter , just get a new one. That`s the original , with how many miles are on the car ??
iroc34 is offline
Old 06-12-2013, 01:10 AM   #386
iroc34
iroc34's Avatar
Fan#: 69289
OH , the bendix is the gear on the starter. When cranking, that gear / bendix
shoots out towards the flywheel and engages the ring gear to turn the engine over. If it is shooting out and the engine cranks and starts, it might be hanging up and spinning as fast as the running motor. Which sounds terrible. Also take the charged battery with you to the parts store, and have it load tested. Thats really the only way to test a battery...
iroc34 is offline
Old 06-12-2013, 02:33 AM   #387
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
that's not how I set mine up.....I plugged the air hole from the turbo and left one of the ports of the solenoid open to atmosphere. top port of wg goes to a vac line teed off of the intake then into the solenoid. and bottom port goes directly into the intake manifold port that the pcv hose used to go into. works great for me. I set bc to 10 psi and sure enough it holds it there
FF MODERATOR
RIFF CREW
Old 06-12-2013, 02:34 AM   #388
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
is there an advantage of using the port from the turbo
FF MODERATOR
RIFF CREW
Old 06-12-2013, 09:40 AM   #389
iroc34
iroc34's Avatar
Fan#: 69289
Well, the Comp didn't have the port on the turbo. I hooked that line up to a port on the pressure side tubing. Just before going into the throttle body. Same idea. This setup, according to Turbosmart, is to get maximum boost from your turbo system.
iroc34 is offline
Old 06-12-2013, 11:39 AM   #390
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,159, Level 91
Points: 21,159, Level: 91 Points: 21,159, Level: 91 Points: 21,159, Level: 91
Level Up 62% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
you should be getting boost reference off the IM not the comp housing. both will operate just fine and wont hurt any thing but getting it from the IM will accommodate for any boost loss through the IC and IC piping. you will usually see 2 more psi on gauge just by switching ref from the comp housing to the IM
Tim
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
