MS3 spring install 6/2/12 - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2013, 08:18 PM   #101
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 10 2012sel Great Standing Member
Thanks for the pics and tips. The stance looks great. Really gets rid of a lot of air gap and I'm looking forward to a fairly even gap all around. I'll try to add to the conversation and document how my installation goes too. After this will be a new rear spoiler and 18" wheels.
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
Old 03-22-2013, 07:58 PM   #102
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
I just installed the Ti Handling Pack rear shocks. MUCH better matched to the ST struts with my MS3 springs. The Ti compression damping wasn't as extreme as the MZ5 rear shocks, but the rebound damping is greater with the Ti shocks. You get more control, smoother ride, and less bounciness.
TORQUERULES is offline
Old 03-25-2013, 01:09 PM   #103
2012sel
2012sel's Avatar
Fan#: 84814
shortening the bump stops?
Did you, or do you advise to, cut off part of the strut bump stops to account for the lowering? If so, how much? Thanks.
Current
Past Rides
2012sel is offline
Old 04-21-2013, 09:59 PM   #104
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
So as far as alignment goes, it seems that no one with these springs did anything? Did anyone get it checked and find it in spec?
Thanks.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 04-21-2013, 10:05 PM   #105
hooligander
Fan#: 103250
What I Drive: 2012 Sterling Grey Focus SEL MT
FF Reputation: 1 hooligander Good Standing Member
Get it alligned!
You must always after any major suspension change
2012 Focus HB Sterling Grey 5 Speed
Mods 18" BBS LM, MS3 Springs, Racing Pedals, Green Filter, Snorkel Delete, Rally Mud Flaps, 3DCarbon Style Wing, Door Sills, Husky Mats, 3M Paint Protection, Lumar Tint..
hooligander is offline
Old 04-21-2013, 10:09 PM   #106
asting
Fan#: 98342
Originally Posted by hooligander View Post
Get it alligned!
Did these springs require the camber arms to get in spec?
asting is offline
Old 04-25-2013, 10:28 PM   #107
asting
Fan#: 98342
So for those that have done springs, I take it
will not work. I rented one without really checking it out, and it seems like this is the wrong type This needs to be in the middle to work, which obviously won't fit with the strut there. I just need to do the front now (rear done).
Edit: and I just read the little pamphlet. One side is a short arm, the other a long arm. Hopefully one will be enough to do just the front.
asting is offline
Old 04-26-2013, 09:22 AM   #108
2012sel
2012sel's Avatar
Fan#: 84814
I got a set of these cheapies from Harbor Freight. Haven't used them yet. Not sure if it's the best tool for the job.
Current
Past Rides
2012sel is offline
Old 04-26-2013, 10:17 AM   #109
asting
Fan#: 98342
That seems to be the type these guys used.
I cut my front springs yesterday, and the rears are installed. If you haven't done yours yet, the rears are easy. I just wasted so much time messing around/trying to figure it out. Just undo the brackets that hold the sway bar to the car (2 on each side, 4 bolts total 13mm). You'll need a deep well socket for the top, and short well for the bottom. Then undo the main bolts that hold the spindle to the control arm. 15mm. You'll have to jack up the spring quite a bit to get the holes to line up/reduce shear force. Then it will slide out and you can lower the jack. With your sway bar free you then push down on the lower control arm and the springs pop out!
asting is offline
Old 04-26-2013, 10:34 AM   #110
2012sel
2012sel's Avatar
Fan#: 84814
The rears do sound easy and the Eibach link will help a lot on the front. Thanks for sharing those.
I found this video that does a pretty good job of showing the basic process for replacing the front springs on a Mazda3 which should be very similar to the Focus. There are lots of videos for the Mazda3 strut replacement which is the same process to replace the springs.
Front Spring replacement video...
http://www.youtube.com/watch?v=7LFm4AS-Lqc
Current
Past Rides
2012sel is offline
