Infra-Red Focus RS replica/conversion build! - Page 22 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-11-2012, 07:41 PM   #211
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by Newkleus View Post
Are you doing the interior, engine and transmission as well?
well, not to RS spec no. I'm going to strip the seats and make bolsters from scratch and re-upholster in a similar pattern to the stock SVT interior. but that's probably a project for next year. As far as drivetrain, I'm not planning to stick with a 4cyl in it....but I don't want to count my chickens before they hatch.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 10-14-2012, 09:03 PM   #212
hurtinfocus
Fan#: 835
well. long story short the car is not painted. I spent almost 6hrs working on it and it's still not ready. by making sure ALL of the old paint was off, I sanded through the gelcoat in some spots and exposed small pinholes in the fiberglass flares.....and everytime I fill the ones I find, and go to sand the filler down, I expose more. So I'm continuously chasing these pinholes before I can paint. I've got the driver side I THINK ready. I sprayed it with SEM rattle-can filler primer instead of buying a whole quart.....and the passenger side MAY be currently in it's last skim-coat of filler I HOPE.
Looks like the next chance I have at proper weather is wednesday. It's probably best I didnt paint today, as it ended up being way too humid anyhow.
but, I snapped some pics anyways:
Here's how the hatch/boot came out (realized I didn't take many pics of it)
(I still have to finish shaving the emblem from the trim piece)
and the car after 21hrs of sanding, first all in 320 until the mistake-paint was gone, then again in 600 wet for prep.
I did also re-mask off the rear quarter window openings and the windows on the doors....but no pics of that. Still have to mask the roof, finish repairs on the rear flairs, and THEN maybe I can paint wednesday. If this doesn't come out good, I'm seriously setting the car on fire and claiming the insurance and getting out of the focus game.
Old 10-14-2012, 09:15 PM   #213
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 05 Slowbaru Outback
FF Reputation: 2 Kevastator Good Standing Member
It is going to turn out awesome! I think it's incredible that you are doing this all on your own!
Kevastator is offline
Old 10-17-2012, 11:05 PM   #214
hurtinfocus
Fan#: 835
UGH...this car is totally fighting me every step of the way. Basically, everything I work on for myself comes out like shit while work I do for other people always goes smoothly.
So, I have the whole car prepped....I go to start spraying....I get to the third coat of color after two light coats, and start to get the SAME GOD DAMNED LIFTING SHIT happening again. I don't know WHAT THE is going on, but it's god damned annoying. It was nowhere near as bad as the last time, so I just waited a little extra time between coats and did 3 more coats to kind of try to level it out and hide it since last time this happened wetsanding with 600 seemed to make the issue WORSE. Anyways, to sum things up.....I said it and continued with the paintjob.
Here's the shit I'm talking about:
so I figured since it's not metallic it could possibly hide in the clear.....so I banged on a crap-ton of clear in three coats (two real heavy) and got it done.
I did however put a couple runs in it....so I'll have to let it harden up for a few weeks (might just wait until spring) to go ahead with wetsanding them out and buffing it.
probably going to leave the car sit for a week before attempting to put the glass back in and get into re-assembly.
Old 10-18-2012, 06:47 AM   #215
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
What I Drive: 2003 Red SVT
FF Reputation: 1 Dads03SVT Good Standing Member
Have a friend that paints cars and i found it strange....but he add's the cars color to the clear to kinda tint it before he sprays the clear says later on it helps keep the clear from turning hazy or white. Always wondered does that work.
I wanna try and do my rear bumper myself.....this red really fades bad.
After you sprayed the color how long did you wait to spray the clear?
Dads03SVT is offline
Old 10-18-2012, 09:14 AM   #216
hurtinfocus
Fan#: 835
usually about 10-12mins between coats using medium hardener in the clear.
process is:
prep surface with 600grit wet
clean with wax/grease remover meant for paintwork
spray one even coat of primer sealer
wait 8-12 mins (wait for it to "haze" or dull, that's when it's ready)
spray light coat of base color (should still see the gray coming through)
wait 8-12 mins (again, waiting for it to dull out/haze)
spray a good even coat of base color
spray a light misting of clear, it should look speckled and orange-peely
wait 10-15mins (when you touch the tape from masking and it feels like tacky glue without being wet or stringy when you pull your finger away, it's ready)
spray a HEAVY coat of clear....you move fairly slow and steady getting good coverage. if a spot starts to look white, it's going to run in the next 10-30secs and make you swear.
wait about 20mins, again check the tape nearby for tacky-ness
spray a second HEAVY coat of clear.
let dry :)
Old 10-18-2012, 04:07 PM   #217
sicskate
Fan#: 102301
What I Drive: Peugeot
Points 145, Level 2
Points: 145, Level: 2 Points: 145, Level: 2 Points: 145, Level: 2
Level Up 90% Completed
FF Reputation: 1 sicskate Good Standing Member
Not the way I would have painted it.
I would have done a drop coat.
10mins
Medium coat
10mins
Drop coat.
10 mine
Mist of lacquer
5mins
Heavy lacquer.
But that's in a booth.
sicskate is offline
Old 10-20-2012, 04:54 PM   #218
hurtinfocus
Fan#: 835
snapped some pics of the driver side and then pulled all the masking off
Old 10-29-2012, 09:24 AM   #219
hurtinfocus
Fan#: 835
so yesterday my dad came over and helped me put the rear glass in, and then I started re-assembling.....
still fighting with the passenger side fender though so front clip isn't on yet
Old 10-29-2012, 09:33 AM   #220
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
It will be nice to see a red RS rep for a change! I am glad that you didn't give up on it, that looks amazing!
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
