Prep on a full Zetec rebuild for future Turbo? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2012, 01:54 PM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,369, Level 61
Points: 8,369, Level: 61 Points: 8,369, Level: 61 Points: 8,369, Level: 61
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
I am building my engine for turbo implication down the road. for financial reasons it will be about 1 year between getting the car running again from the whole motor overhaul to getting a turbo on it. While I have everything (literally) in pieces and apart are the small things I can do now that will be easier to do now than later?
Like should I take the oil pan to weld in a bung for a return feed and then just plug it so down the road its already there? Things like that which will have minimal cost impact but make life much easier 1 year from now?
Thanks!
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 05-30-2012, 03:16 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,811, Level 100
Points: 51,811, Level: 100 Points: 51,811, Level: 100 Points: 51,811, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
Oil pan and the fitting for the turbo feed is about it , Duratec the fitting for the feed is easy so do the pan now
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-30-2012, 03:40 PM   #3
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 42%
is it advised not to use the oil feed on the block just under the coil pack? (also usually used for an oil pressure feed line...) Can you still T off that and use for an OIL pressure gauge?
Edit: Looks like the prep needed for that is to cut off a foot of the stock coil pack (thats what I have) and cut the mounting bracket. That should be fairly straight forward to do when its turbo time.... End of Edit.
Is there any particular sweet spot on the oil pan? guess as high as possible along any of the sides? Any particular size of the fitting? looks like you have 1/2" ID tubing for the return line.
Looks like this is what you (Tom) have done in the past...
Hatch Nation #42
Old 05-30-2012, 05:19 PM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
no u can use the feed from the head BUT only for the turbo feed from the top. then the feed from the bottom goes to the pan
like so
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-30-2012, 05:37 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
Yes use the feed under the coil and cut off the bolting leg . put the fitting in the pan about anywhere you want , I go twords the top of the pan and use a 1/2 NPT to 5/8 barbed fitting that you can get at any Lowes , home depo , napa etc , I use the same in the STD adaptor fitting for the bottom of the turbo it is also 1/2 NPT
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-30-2012, 06:24 PM   #6
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 42%
Do you make&tap your own "lug"/bung that gets soldered to the pan that has the 1/2 NPT threads? or where can you pick one of those up at?
Edit: Just order one of these... http://lightningmotorsports.com/i-165106.aspx ?
Also with as thin of sheet metal as the oil pan is, should it be welded using a TIG welder or is a MIG ok?
Hatch Nation #42
Old 06-09-2012, 01:48 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 42%
Just got the Bung in yesterday and fit it to the oil pan and drilled out the hole and ground a patch down to the metal. however I went to HomeDepot yesterday to find a 1/2 NPT plug and they did not have any NPT plugs. It seemed like they had everything but that. I am looking for a hex or Allen key plug since I obviously dont have a turbo yet to use the return line.
Guess its off to Lowes or just buy it on line...
Does any other "Thread" type fit in the NPT style fitting?
Hatch Nation #42
Old 06-09-2012, 04:09 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
NPT is the thread style and only a NPT will work and not mess up your threads , try a store like Napa if Lowes doesnt have it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
