2012 170whp on a mustang dyno - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-01-2013, 12:10 PM   #91
Picoletray
Picoletray's Avatar
Fan#: 110541
What I Drive: 2013 Sterling Grey HB SE
FF Reputation: 1 Picoletray Good Standing Member
Originally Posted by NickCornell View Post
More mods = less mpg, generally. Intake will be more power, but more air, thus increasing air fuel ratio and lowering mpg
Sent while Slideways
I've seen varying opinions regarding factory paper versus the CAI or even drop in K&N, so that may or may not happen. Is the same true of the exhaust? Does that increase fuel ratio? I believe it just decreases resistance, and increases the decibals/HP/TQ.
Picoletray is offline
Old 03-01-2013, 06:38 PM   #92
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,914, Level 76
Points: 13,914, Level: 76 Points: 13,914, Level: 76 Points: 13,914, Level: 76
Level Up 66% Completed
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
I would say exhaust in theory shouldn't negatively affect it since it's in essence making the car "exhale" easier
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 03-03-2013, 09:42 AM   #93
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,126, Level 96
Points: 26,126, Level: 96 Points: 26,126, Level: 96 Points: 26,126, Level: 96
Level Up 78% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Not only does it exhale better, the reduction in pumping losses actually helps it inhale better as well. Generally speaking, an intake allows more air which requires more fuel (less mpg) while an exhaust can increase the scavenging effect and reduce pumping losses (more mpg).
In a strictly mpg-oriented vehicle, I would go with the K&N drop-in, snorkel delete, and a custom cat-back exhaust. The main reasoning for that is the fact that the less you spend on mods, the less you have to make back in fuel savings to cover the cost.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 03-03-2013, 09:55 AM   #94
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,216, Level 41
Points: 4,216, Level: 41 Points: 4,216, Level: 41 Points: 4,216, Level: 41
Level Up 33% Completed
Forum Activity 11%
FF Reputation: 6 RonMaiden Good Standing Member
Too big of a diameter exhaust kills back pressure on NA cars and reduces lowend power and I've seen dynos on more than a few small engines and I've seen overall power losses and maybe a bit of gain at the end of the power band but that's about it. So that power you killed on the lowend just made you car slower.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 03-03-2013, 10:35 AM   #95
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 53%
That isn't necessarily true. You are correct to a small degree in regards to Bernoulli's Principle, but what you are actually trying to refer to is the collector. That is why I stated a 'cat-back'. For a cat-back exhaust, diameter is actually more of a diminishing-gains scenario than a power-robber because the collector is staying the same. And this will vary depending on the rest of the system as well.
If you are tuning your exhaust you are mainly going to be concerned with the collector. That is where you can have 'too large' of piping. It can also be too-long, too-short, too-small, etc.
As for back pressure...
Back pressure is an enemy to exhaust. The closer to zero, the better the exhaust will flow. An engine is simply an air pump, and by saying that back pressure is necessary you're stating that an air pump will work better with the exhaust partially covered. There are numerous articles available to be read, and I can't deny that I used to believe this myth also.
As for power gains/losses, exhaust is an overly simple yet extremely complicated subject. The best exhaust for power is not the same as for mpg or even for sound. To tune an entire exhaust for mpg then negates the cost-saving that the engine will have.
September '13 ROTM
2014 FiST-
Old 03-18-2013, 03:17 PM   #96
furiousmonk3y
Fan#: 111373
What I Drive: 2012 Ford Focus White HB SE
Points 24, Level 1
Points: 24, Level: 1 Points: 24, Level: 1 Points: 24, Level: 1
Level Up 47% Completed
FF Reputation: 1 furiousmonk3y Good Standing Member
Has anybody actually checked their mpg after installing and intake only? or exhaust only? or both?
furiousmonk3y is offline
Old 03-20-2013, 02:21 PM   #97
XlarXlar
XlarXlar's Avatar
Fan#: 111735
What I Drive: 2013 PB Ford Focus
Points 246, Level 4
Points: 246, Level: 4 Points: 246, Level: 4 Points: 246, Level: 4
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 2 XlarXlar Good Standing Member
So I was wondering if the dyno sheet you have in the first comment is with just the intake and exhaust installed or if it is with the other modifications you list in your signature?
Also I was wondering what the STS Kit is that you list in your modifications? Is it a turbo?
Thanks and your car looks good
XlarXlar is offline
Old 03-20-2013, 02:31 PM   #98
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,241, Level 67
Points: 10,241, Level: 67 Points: 10,241, Level: 67 Points: 10,241, Level: 67
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 26 suss6052 Great Standing Member
STS= Short throw shifter in this case, i.e. a shift kit that lowers the length of the shifter and the throws between gears.
suss6052 is online now
Old 03-20-2013, 02:38 PM   #99
XlarXlar
XlarXlar's Avatar
Fan#: 111735
Points 246, Level 4
Ah ha, That makes sense.
A gain of 22 hp and 20 TQ is quite good for just adding an intake and exhaust! I'm going to have to look more into modifying mine
XlarXlar is offline
