Complete Strut Assembly Opinions and experience - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-22-2012, 09:59 PM   #1
WingsVK97
WingsVK97's Avatar
Fan#: 45744
What I Drive: 2001 Red ZX3
Points 101, Level 2
Points: 101, Level: 2 Points: 101, Level: 2 Points: 101, Level: 2
Level Up 2% Completed
FF Reputation: 1 WingsVK97 Good Standing Member
I've got an '01 ZX3 with noise coming from my front suspension. After having already done the stabilizer links (which were completely shot, but didn't get all the noise) I believe it's my strut bearing.
I'm researching it and have seen the option of doing an entire strut assembly instead of just the bearing. This seems much more safe since there's no spring compressor involved, but is it over doing it? I've got 85k on this car and don't know if I need the whole thing. I'm going to do the math on how cost effective it is to do the whole assembly vs removing the struts, buying parts, and having a shop do the replacements, but I'm curious to see if anyone has done this same thing already. I know there's an alignment in here too.
Tire Rack has KYB, Advance has Monroe, and AutoZone has Gabriel. Thoughts?
WingsVK97 is offline
Old 05-22-2012, 10:45 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
You should have replaced your struts (and shocks) about 20K miles ago. The strut assembly can be removed in one piece. You then use a spring compressor to remove the upper mount and bearing. The process is safe and straightforward with basic hand tools and a spring compressor you can borrow or rent from major chain auto part stores. It's false economics to not change the bearing and mount when replacing the strut. KYB GR2's are very good OE replacement struts/shocks and also make good bearing and upper mount kits.
Geezer is offline
Old 05-23-2012, 09:51 AM   #3
superfordzx3
Fan#: 96939
What I Drive: 2006 blue ZX3
FF Reputation: 3 superfordzx3 Good Standing Member
If you have a shop do it, most (MOST) of them will charge you about the same, cause the complete setup is more expensive, but there is less labor to simply swap it out then take it all apart, ect... My personal opinion is to do the direct swap with the complete unit that way you know everything is new and together out-of-the-box. Yes, things can still have problems that way, but for the most part, its fine. But If your gonna do it yourself, go ahead and save the money and just buy what you need.
superfordzx3 is offline
Old 05-23-2012, 09:56 AM   #4
Veetoe157
Fan#: 82653
What I Drive: 2007 Pitch Black ZX5 SAP SES
Points 890, Level 15
Points: 890, Level: 15 Points: 890, Level: 15 Points: 890, Level: 15
Level Up 90% Completed
FF Reputation: 1 Veetoe157 Good Standing Member
I highly recommend changing out the entire assembly; you suspension will only be as good as your weakest link, so changing only the strut bearings might eliminate the noise you hear, but it will only be masking the problem.
Veetoe157 is offline
Old 05-23-2012, 10:13 PM   #5
WingsVK97
WingsVK97's Avatar
Fan#: 45744
Points 101, Level 2
How about brands? Mainly, is there anyone I should strongly avoid?
Old 05-23-2012, 11:34 PM   #6
Geezer
Fan#: 1427
KYB GR2's (aka KYB Excel's) are a very good, reasonably priced, OE replacement shock. personally, I'd avoid Gabriels, Monroes, etc. The KYB's cost about the same as those (or even less) and are much better. If you want to spend a little more Koni Strts are getting great reviews as well.
Geezer is offline
Old 05-24-2012, 09:00 PM   #7
WingsVK97
WingsVK97's Avatar
Fan#: 45744
Points 101, Level 2
Any experiences with Moog or Raybestos strut assemblies?
Old 05-24-2012, 10:58 PM   #8
Geezer
Fan#: 1427
The first question I have is when did either one start making stuts and second where did you find them. Neither has been in the strut/shock business....until now????
Geezer is offline
Old 05-25-2012, 07:00 AM   #9
WingsVK97
WingsVK97's Avatar
Fan#: 45744
Points 101, Level 2
Rock Auto has both showing for my year. Price is right where I want as well. Not
to doubt the craftsmanship of Koni or KYB, but they strike me as a performance hardware. My car is just transportation, but I do care what I put on it.
Old 05-25-2012, 08:21 AM   #10
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
I would bet its a rebadged part from another shock maker. Both companies have really pushed into the aftermarket parts business, offering relabeled stuff for many applications they don't actually manufacture parts for.
KYB is likely the best at this price point.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
