Current TSB's for the 2012 Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-20-2012, 03:08 PM   #1
blackcervini
blackcervini's Avatar
Fan#: 74083
What I Drive: 01 Supercharged ZX3, 05 ST
Points 981, Level 16
Points: 981, Level: 16 Points: 981, Level: 16 Points: 981, Level: 16
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 5 blackcervini Good Standing Member
Buy-Sell-Trade Rating: (6)
Thought some of you might need a little help with some of the troubles you are having.
12-05-05 - 2.0L GDI AND MANUAL TRANSMISSION - CALIBRATION UPDATE - VARIOUS DRIVABILITY IMPROVEMENTS - BUILT ON OR BEFORE 2/29/2012
12-05-04 - 2.0L GDI - DTC P0010, P0012, P0013, P0014, P052A OR P054B - VCT OIL CONTROL SOLENOID - BUILT ON OR BEFORE 5/6/2011
12-05-02 - 2.0L GDI - OIL LEAK - REAR UPPER EXHAUST MANIFOLD STUD AREA
12-04-13 - LOW WASHER SOLVENT WARNING MESSAGE MAY NOT DISPLAY ON VEHICLES BUILT ON OR BEFORE 1/14/2012
12-02-17 - STEERING WANDER - BUILT ON OR BEFORE 12/12/2011
12-02-15 - PASSIVE ANTI THEFT SYSTEM (PATS) SPARE KEY PROGRAMMING ISSUES - WITHOUT INTELLIGENT ACCESS - BUILT ON OR BEFORE 2/22/2012
12-01-07 - MESSAGE CENTER DISPLAYING HORIZONTAL LINES - ERRATIC FUEL GAUGE - BUILT ON OR BEFORE 8/16/2011
11-12-13 - AUTOMATIC TRANSMISSION FLUID LEAK
11-11-02 - CRUNCHING OR CREAKING NOISE FROM FRONT OF VEHICLE ON LOW SPEED TURNS AND BUMPS - BUILT ON OR BEFORE 9/9/2011
11-10-01 - INTERMITTENT REMOTE KEYLESS ENTRY (RKE) OPERATION - KEY FOB - BUILT ON OR BEFORE 8/3/2011
11-09-14 - RECREATIONAL TOWING - AUTOMATIC TRANSMISSION - BUILT ON OR BEFORE 7/15/2011
11-09-03 - INACCURATE FUEL GAUGE - DTCS P0456, P008A, P1450, P2196 - CRANK NO START - BUILT ON OR BEFORE 8/3/2011
11-08-11 - FRONT DOOR TO REAR DOOR CONTACT AT THE TOP WEATHERSTRIP
11-08-01 - VISIBLE DEPRESSION IN HOOD SURFACE
11-07-13 - BATTERY LIGHT ON - DTCS MAY ALSO BE PRESENT U012D, U0140, B11DB, U0422, P2610, P06B8 OR U0257
11-05-01 - LACK OF POWER STEERING ASSIST ON VEHICLE START UP - DTC C102D - BUILT ON OR BEFORE 4/19/2011
Two eyes, Two ears, and one mouth. Hint and a half to watch, listen, and then speak.
blackcervini is offline
Old 09-06-2012, 12:29 PM   #2
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2012 White Platinum Ti Sport Hatch
Points 493, Level 9
Points: 493, Level: 9 Points: 493, Level: 9 Points: 493, Level: 9
Level Up 86% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Sweet thread! Thanks a bunch and good job! ... Subscribed!
Please keep us updated when any more current TSB's are released.
noahsfocus is offline
Old 05-12-2013, 06:10 PM   #3
2013FocusTitanium
Fan#: 114498
What I Drive: 2013 Titanium White Platinum
FF Reputation: 2 2013FocusTitanium Good Standing Member
Transmission-related TSBs:
13-4-5 Intermittent transmission clutch shudder on light acceleration
http://www.fordservicecontent.com/pu...sb13-04-05.pdf
13-4-6 Diagnostic trouble code (DTC) P2832 shift fork A performance and/or P2837 shift fork B performance
http://www.fordservicecontent.com/pu...sb13-04-06.pdf
13-4-18 Repeated clicking noise from transmission after opening the driver’s door and/or using the key FOB to unlock the door, prior to starting the engine http://www.fordservicecontent.com/pu...sb13-04-18.pdf
2013FocusTitanium is offline
Old 10-08-2013, 08:13 PM   #4
NemesisPrime
NemesisPrime's Avatar
Fan#: 110427
What I Drive: 2012 FF Ti Hatch, Tux Black, 18"
Points 18, Level 1
Points: 18, Level: 1 Points: 18, Level: 1 Points: 18, Level: 1
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 NemesisPrime Good Standing Member
TSB 13-9-4 - INTERMITTENT TRANSMISSION CLUTCH SHUDDER DPS6 AUTOMATIC TRANSMISSION AND/OR TRANSMISSION FLUID LEAK
This article supersedes TSB 13-4-5, 12-4-6 and 11-12-13 to consolidate previously released information, update the model years, Service Procedure and Part List.
http://www.fordservicecontent.com/Fo...sb13-09-04.htm
2012 Focus Titanium Hatch, Tuxedo Black, Moonroof, 18" Aftermarket
Rapid Spec 401A Vision Group
MFT 8" Screen w/NAV w/Sync Gen2 - V3.6.2
Michigan ASSE - Build Date: 06.xx.2011 #12B37 applied
In the News: http://goo.gl/Zi4F88
NemesisPrime is offline
Old 10-08-2013, 10:17 PM   #5
2013FocusTitanium
Fan#: 114498
New TSB for MyFord Touch
13-10-6 MYFORD TOUCH/MYLINCOLN TOUCH-VARIOUS FUNCTIONALITY CONCERNS - BUILT ON OR BEFORE 8/15/2013
http://www.fordservicecontent.com/Fo...sb13-10-06.htm -
Old 10-08-2013, 10:26 PM   #6
2013FocusTitanium
Fan#: 114498
13-9-4 INTERMITTENT TRANSMISSION CLUTCH SHUDDER DPS6 AUTOMATIC TRANSMISSION AND/OR TRANSMISSION FLUID LEAK
Old 10-08-2013, 10:37 PM   #7
2013FocusTitanium
Fan#: 114498
13-10-NA INTERMITTENT TRANSMISSION CLUTCH SHUDDER TSB DPS6 AUTOMATIC TRANSMISSION
http://www.fordservicecontent.com/Fo...sb13-10-NA.pdf
Old 03-24-2014, 02:23 PM   #8
2013FocusTitanium
Fan#: 114498
Newest TSB on this issue:
Print it before it gets pulled from the internet like some of the others have!
http://www.fordtechservice.dealercon...uage=EN&VIN=no
