oil consumption - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 02:57 PM   #31
Kabigon
Fan#: 88299
Points 4,379, Level 42
Points: 4,379, Level: 42 Points: 4,379, Level: 42 Points: 4,379, Level: 42
Level Up 15% Completed
Forum Activity 9%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by IH84DZ View Post
If you used the super-duper top shelf AMSOIL with the proper viscosity but changed it every 10,000 miles because AMSOIL's testing said it could be done I'd tell you "Claim denied, you should go talk to AMSOIL"
AFAIK, the oil life monitoring system may indicate an oil change interval of up to 10,000 miles.
Kabigon is online now
Old 11-19-2012, 03:04 PM   #32
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,040, Level 66
Points: 10,040, Level: 66 Points: 10,040, Level: 66 Points: 10,040, Level: 66
Level Up 98% Completed
Forum Activity 24%
The owners manual quotes a maximum interval of 12 months/ 10,000 miles as the maximum reccomended oil change interval from Ford, if the OLM does not indicate that the oil needed to be changed before this point this was the point at which you should change it if going by the iOLM vs the manual.
suss6052 is online now
Old 11-19-2012, 04:27 PM   #33
IH84DZ
Fan#: 101801
What I Drive: 03 CD silver SVT 5 door
FF Reputation: 5 IH84DZ Good Standing Member
Doing what the book says or what the vehicle says is different than using a number the oil maker says you can get away with. That's all I meant
IH84DZ is offline
Old 12-11-2012, 05:56 AM   #34
Karenj
Fan#: 107190
What I Drive: Ford focus 1.8 sport 2007 blue
FF Reputation: 1 Karenj Good Standing Member
I have a ford focus 1.8 sport which iv owned for 3 months. When purchased it had "apparently" just been serviced. However was running jagged very juddery . I took it back and it was given new spark plugs and seemed fine. Two weeks later the oil light came on an I checked the dip stick to find it was dry as a bone ??! I replaced the oil and the light went off it was running fine .... Until 3-4 weeks after that I check the oil once again and it is empty :/ I don't do excessive mileage nor is it leaking the cap is clear of any sinister gunge .... What is wrong with this piece of shite please help ?
Karenj is offline
Old 12-11-2012, 10:45 AM   #35
IH84DZ
Fan#: 101801
Anyone's guess because you are going on someone's "word" that it had been "serviced". Don't panic until you've done a proper oil consumption test.
IH84DZ is offline
Old 12-11-2012, 10:50 AM   #36
Karenj
Fan#: 107190
Posted via FF Mobile
It is stamped in the book as being serviced and when I got the spark plugs changed it was that very garage I used as I wanted them to clarify that it had been serviced.
I bought a 5 letter oil two weeks later and used nearly half to re fill the oil and this morning I have used the rest of that same bottle of oil to refill again.
I between I have probably done 1000 miles
Karenj is offline
Old 12-11-2012, 03:05 PM   #37
IH84DZ
Fan#: 101801
Consider the possibility someone stamped a book without doing the work. Sure sounds like it's losing oil but there are types of leaks that only occur when the engine is running so it's possible the oil is leaking but you don't see a puddle under the car.
Until a pro does a proper consumption test and inspection there is no practicality in speculating how the oil is being lost.
IH84DZ is offline
Old 12-11-2012, 03:17 PM   #38
flingwing1969
flingwing1969's Avatar
Fan#: 91700
What I Drive: 2012 white platinum Forcus SEL 303A
Points 1,131, Level 18
Points: 1,131, Level: 18 Points: 1,131, Level: 18 Points: 1,131, Level: 18
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 2 flingwing1969 Good Standing Member
FWIW:
I just changed the oil this weekend (9700 miles).
I would extrapolate the oil consumption to be 1 quart per 8000~10000 miles.
Changed oil the last time at 18k - 3rd time since new - 7k and zero oil use.
2012 Focus SEL 303A, moon roof, etc
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
1974 Dodge W300 Power Wagon dump truck
2002 Kubota B-21 tractor-loader-backhoe
flingwing1969 is offline
