Serpentine belt tensioner problem - Focus Fanatics
Old 05-16-2012, 08:40 PM   #1
Inforcus
Fan#: 89147
What I Drive: 2000 SE Wagon
FF Reputation: 1 Inforcus Good Standing Member
Hi guys, I have a 2000 Ford Focus Zetec DOHC. All is fine with my car except for the serpentine belt tensioner. In one year I broke three tensioner. I need know if any body here have the same problem or my engine have some poblem or is the Pep Boys tensioner bad quality and I need buy a original Ford Part.
I change the original factory tensioner because broke the ball bering at 77,000k mile. I bought a Peb Boys replacement and it only lasted three months, the tension was broke in two pieces, I place another Pep Boys tensioner and about nine months broke in the same form. What is the problem??? I have fear to drive long distance and return in the top of flat bed. Somebody can help me
Inforcus is offline
Old 05-16-2012, 11:31 PM   #2
stealthzx3
Enthusiast
stealthzx3's Avatar
Fan#: 94260
What I Drive: 2001 Ebony ZX3
FF Reputation: 9 stealthzx3 Good Standing Member
Buy-Sell-Trade Rating: (21)
sorry to hear about that. the tensioners are very common to go bad. i don't know if you bought the brand new, but i never heard of them snapping in two. the only thing i could think of is your belt is too tight, but that's controlled by the tensioner.. odd, very odd indeed.
Focus Revolution
Focus Central
stealthzx3 is offline
Old 05-17-2012, 01:10 AM   #3
emsvitil
Fan#: 50210
FF Reputation: 9 emsvitil Good Standing Member
I just replaced the pulley, the tensioner was fine....
Do you still have the original that you could just replace the pulley on it?
Ed
emsvitil is offline
Old 05-17-2012, 07:23 AM   #4
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Something is out of line... misalignment puts too much strain on the belt, so if you find the belt IS too tight that's probably your issue.
Mile30 is offline
Old 05-17-2012, 07:11 PM   #5
Inforcus
Fan#: 89147
Ok guys, Thanks for your help.
This is the tensioner broken, the other part and belt are missing in the road.
The tree tensioner are broke in the same form and in the same place. I do not know why, but is very peculiar.It is what i desire to know why and correct the defect. Or to eliminate serpentine and to use a individual belt system if is possible.
Any idea or advise.
Thanks
Inforcus is offline
Old 07-22-2012, 11:40 AM   #6
treecarp
Fan#: 99715
What I Drive: 2002 Focus Wagon
FF Reputation: 1 treecarp Good Standing Member
EXACT same problem
Same exact part replacement (Dayco 89318), same results...broke exactly where yours did. Did you ever find a resolution?
treecarp is offline
Old 07-22-2012, 11:12 PM   #7
amc49
Fan#: 96610
FF Reputation: 19 amc49 Great Standing Member
I'm running rebuilt tensioner made from that exact design. They last forever. I'd be looking at belt length issues, if belt was changed at the start of all that breakage and was slightly too long or short (mainly long IIRC) the tensioner can hit the stop repeatedly to break after starting a crack first. That is one of the stiffer spring models I like to rebuild, but the stiffer spring would aggravate the potential problem I just described. The tensioner must not hit or even come close to any stops through its' entire range of movement while in use if the right length belt is picked.
If I had you close I'd buy that broken one for $5. Spare parts, mon..........
amc49 is offline
Old 07-23-2012, 05:09 AM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 267 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Try getting a belt made by a different manufacturer, and also check your belt routing. IDK about the Zetec, but on one of my old vehicles the belt could be routed 2 different ways- one way left slack, and the other way didn't.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-23-2012, 03:09 PM   #9
treecarp
Fan#: 99715
I'm working on a 2002 SE wagon, 2.0L DOHC Zetec with A/C. Definitely routed correctly. Problem began with a shop putting on a serpentine belt that was WAY too short (Dayco 5070665 at 77.56"). How they muscled it on there is beyond me. Needless to say, it completely mangled the factory tensioner assembly. Replaced assembly with above mentioned Dayco, and a MasterPro K060837 belt that's 84.242". Since then, 2 Dayco assemblies have broken, just as pictured above. Have now ordered a Gates assembly. The belt and all the other pulleys are in great shape. So you think the belt may be too long? Anyone know the exact length needed and/or brand/part number? Thanks for any help...this is past frustrating.
treecarp is offline
Old 07-23-2012, 06:33 PM   #10
2003ZTS
2003ZTS's Avatar
Fan#: 45334
What I Drive: 2003 gold zts
FF Reputation: 1 2003ZTS Good Standing Member
Hello,
I replaced mine with that same one, Had 1 year warranty broke at just over 1 year. Mine broke on the back. I was lucky it broke 1 block from home. I replaced with it Motorcraft. The Motorcraft felt much stronger than the Dayco,With the Motorcraft I had a hard time getting it to retract enough to fit the belt on but did it. So far it works well, Some times the Motorcraft part is the best, but they do cost more, But your time is money. Hope you find out your trouble GOOD LUCK!!
Thanks, 2003ZTS
2003ZTS is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
