Anyone in Rochester, NY area? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > North East Fanatics
North East Fanatics Serving the Connecticut, Maine, Massachusetts, New Hampshire, New England, New York, Rhode Island, and Vermont regions.
Old 05-15-2012, 08:02 PM   #1
reefboarder
Fan#: 99073
What I Drive: 04 cloud9 white zts
FF Reputation: 1 reefboarder Good Standing Member
Need a little point in the right direction here.
Have an 04 zts 2.3l, need new exhaust soon and really want the fswerks stealth for the 2.3 duratech.
This exhaust would eliminate the second catalytic converter, leaving my car throwing a CEL for the o2 sensor.
I know you can have the second o2 sensor deleted I just dont know of anyone to do it, and cant really afford to buy the flasher from fswerks to do it myself.
If anyone knows anywhere in the area that can do that it would be a great help.
I am in farmington about a 20minute drive to the rochester limits.
reefboarder is offline
Old 06-12-2012, 10:50 PM   #2
reefboarder
Fan#: 99073
Alright here's another?
Do Nys inspections pick up an O2 sensor that has been tuned out?
Has anyone had success with the dummy sensors?
Old 07-12-2012, 01:29 AM   #3
Citoriplus
Citoriplus's Avatar
Fan#: 100455
What I Drive: 2012 Titanium Hatchback
Points 187, Level 3
Points: 187, Level: 3 Points: 187, Level: 3 Points: 187, Level: 3
Level Up 74% Completed
FF Reputation: 1 Citoriplus Good Standing Member
As far as I know the NYS inspection is only concerned with any safety or EPA related codes the ECM has stored in it.
It also looks for recent erasure activity.
In other words you can't use a code scanner to erase an error code then get the car inspected 10 minutes later.
I'm not sure if they would work on a car, but they have been selling and using O2 eliminators on Harley's and other bikes to fool the ECM into thinking its there and working properly.
The plugs are the same because the O2 sensors are the same ones used on all cars.
Check with a couple of the aftermarket fuel management device makers or dealers, like Fuelmoto, for Harley's.
Many if not most sell the O2 eliminators and should be able to tell you if they will work for you.
2012 Focus Titanium w/handling package, stick shift, MFT, Sony radio, Moonroof in Tuxedo Black.
2012 Lincoln MKZ Hybrid (wife's car) all the bells and whistles also in Tuxedo Black.
2007 Harley Davidson FXSTC Softail Custom, in Vivid Black.
Citoriplus is offline
Old 07-12-2012, 01:41 AM   #4
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
Dummys don't work with nys inspections. Comes up as readiness not complete. You will not pass.
Sent from my SGH-I777 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
Old 07-12-2012, 01:43 AM   #5
1hotfocus
1hotfocus's Avatar
Fan#: 82813
To the OP, I don't think there's an o2 sensor past your second cat iirc so it wouldn't cause a cell if you remove your secondary cat and ad a cat back. If there is an 02 after your second cat then you need to do the spark plug fouler mod and have your 02 sensor hooked up and working. Gl
Old 02-04-2013, 05:11 PM   #6
BlackJack35
BlackJack35's Avatar
Fan#: 87842
What I Drive: 2009 Ebony Black Focus SES
FF Reputation: 1 BlackJack35 Good Standing Member
Any one got a 08-11 SES around here? Looking to trade with your rims for my black SES rims. Need the original color for trade in.
Let me know, thanks!
BlackJack35 is offline
Old 02-04-2013, 09:10 PM   #7
loc0gring0
loc0gring0's Avatar
Fan#: 85659
What I Drive: not enough spaces to list all
Points 5,305, Level 46
Points: 5,305, Level: 46 Points: 5,305, Level: 46 Points: 5,305, Level: 46
Level Up 78% Completed
FF Reputation: 1 loc0gring0 Good Standing Member
Buy-Sell-Trade Rating: (17)
theres no 02 sensor past the 2nd cat so there for you car take the 2nd cat off with no cel.. I did it on my saleen
3 focus supercharged
1 turbo
20+ fsvt
04 saleen n2o weekend warrior
loc0gring0 is offline
Old 02-05-2013, 09:30 AM   #8
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
I had the secondary shut off with a tune on my previous focus when it was turbocharged, and it never gave me an issue with NYS inspections.
but like others have said, if you don't have an o2 sensor mounted downstream (after) the second cat, you won't have any issues.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 02-05-2013, 10:57 PM   #9
Citoriplus
Citoriplus's Avatar
Fan#: 100455
Points 187, Level 3
As long as the ECM doesn't think there is a problem it won't spit out an error code.
NYS inspections check the ECM for the serial number and Check Engine error status and history.
If there is no errors and there is no history of errors within some, unknown by me, time frame the car will pass without a problem.
So putting an eliminator on the line to fool the ECM or reprogramming it to ignore one that's been removed so it will not throw an error, will get the car passed the inspection.
Just heaven help a lot of us if some fool in Albany decides to change the law to mandate some new kind of visual and electronic inspection to verify the installation and proper operation of all the factory installed systems mandated by the EPA.
My 07 Harley is gonna get me at least ten years in the pen for that.
It stopped being EPA legal within a month of my getting it home.
