Turbo Installation Advice? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2012, 05:06 PM   #1
zetecfocus
Fan#: 96880
What I Drive: 2000 Silver ZX3
FF Reputation: 1 zetecfocus Good Standing Member
Guys I need some general installation help for a turbo install. I wanna stay low with the boost for now because I'm sticking with stock block (5-10 PSI) I most likely would be using a universal kit off Ebay as well...First couple questions:
1. EGR block/stop?
2. Battery relocation?
3. MAF relocation?
4. Thermostat replacement?
5. New oil pan?
6. Injector upgrade?
7. Down pipe bracket?
8. Coil pack modification?
9. Power steering cooler lines?
10. ECU chips and misc. electronics hook-ups to ECU?
Email: pacdesigns03@aol.com
zetecfocus is offline
Old 05-14-2012, 07:14 PM   #2
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Don't!!!!!! Save your money for quality parts, recommend reading some sticky threads in top of this section, many questions you have will be answered.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 05-14-2012, 07:57 PM   #3
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
Buy-Sell-Trade Rating: (4)
I was planning to do a cheap build but some bird in the sky told me to buy a kit which I did. I went with FSWERKS and I'm pushing 12 psi on factory block.
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 05-14-2012, 09:17 PM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
1. EGR block/stop?
**Delete and turn off in tune
**No need to
3. MAF relocation?
** Move the MAF to a 3 inch blothrough piping
** 180 out of a 96 Contour 2.0 Zetec
5. New oil pan?
**Use your pan and weld in a Bung
** 42lb will get you by , 60 will give you room to grow for about the same cost as 42lb
** All depends on your down pipe
**Stock coil is fine
** moves easy at the bumper and at the engine leave it there
**SCT XCAL and I can do your custom tuning
I also have to agree buy a good kit of my DIY and work with good parts from the start
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-15-2012, 09:12 AM   #5
zetecfocus
Fan#: 96880
Okay, thanks guys. Only thing I have to ask is; why is it worth spending like 2-3k more for similar parts? For instance, the FS werks kit isn't even complete, actually quite half-assed...and it's like 3k?
Old 05-15-2012, 09:29 AM   #6
zetecfocus
Fan#: 96880
3. MAF relocation? (More specifics?)
4. Thermostat replacement? (Necessary?)
5. New oil pan? (Threading won't work?)
6. Injector upgrade? (Necessary for like 6-7 PSI?)
8. Coil pack modification? (I meant the bracket?)
Thanks for all the insight.
Old 05-15-2012, 12:03 PM   #7
zetecfocus
Fan#: 96880
FSWerks: no BOV, no fuel pressure gauges or regulator, no manifold, no dump pipe, no oil feeds lines(maybe it doesn't need them because it's a hybrid turbo?), no turbo timer, no turbo boost controller, no catch tank, and no boost or oil pressure gauges
Please tell me how I can justify a kit without these parts? Do I not need these parts?
Old 05-15-2012, 12:04 PM   #8
zetecfocus
Fan#: 96880
I don't know shit about turbo's so maybe I'm way off...please show me light gentlemen?!
Old 05-15-2012, 12:33 PM   #9
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
FSWerks: , no fuel pressure gauges or regulator, no manifold, no dump pipe, no oil feeds lines(maybe it doesn't need them because it's a hybrid turbo?), no turbo timer, no turbo boost controller, no catch tank, and no boost or oil pressure gauges
I'm not sure what you're looking at but the kit from fswerks seems pretty complete to me.
I think you're confused on what you need here. The Bosch Diverter Valve is what the non ricers call a "BOV". Most turbo kits don't come with gauges, those you purchase separately. It appears by the pictures they have an adapter to use the stock exhaust manifold. The phrase "dump pipe" is typically used for the pipe that routes the external waste-gated exhaust gas. Since this is an internally waste-gated turbo, no need. Every turbo needs an oil feed, and if you look at the picture, it shows both oil/coolant lines. It as states "Water line kit" in the description. Since the turbo is water cooled as well, there is no need for a turbo timer. I don't see a boost controller so I'm guessing they intend for you to run spring pressure. However boost controllers are cheap. Is a "catch tank" suppose to mean an oil catch can? If so, also not a typical part you see in a turbo kit. For your last point, once again, gauges typically don't come in turbo kits. All they would do is jack up the price of the kit and force you to buy a certain gauge.
I also see an EGR block off plate in the picture as well.
Source:
● Garrett GT28 turbo with custom modifications
● Garrett GT28R, GT28RS and GT2871R (Optional)
● Internal wastegate actuator
● Stainless steel downpipe with o2 sensor fittings
● Powder coated plumbing with bead rolled ends
● 3 and 4 ply silicone connecting hoses
● Stainless steel hose clamps
● 42lb. Bosch fuel injectors
● Water line kit
● Bosch Diverter Valve
● Custom MAF housing
● ITG Maxogen air filter
● FSWERKS / SCT X3 ECU flasher
● Custom FSWERKS ECU programming
● Free dyno tuning session - call for details
● Front mount intercooler
For $3,295, I think this is a pretty damn good deal.
amoosenamedhank is offline
Old 05-15-2012, 01:35 PM   #10
zetecfocus
Fan#: 96880
Like I said, I don't know shit about turbo cars. Thanks for all the feedback, you basically cleared up all the questions. I guess next thing would be; do I need anything else for this kit to bolt on?
