new TSB 12-5-5 for manual trans focii - Page 12 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Focus
Old 06-01-2012, 03:36 PM   #111
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 854, Level 15
Points: 854, Level: 15 Points: 854, Level: 15 Points: 854, Level: 15
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 3 amoosenamedhank Good Standing Member
Just got the car back and this was definitely a much need update.
The main reason I brought my car in was when you use to let the clutch out, occasionally it would just drop in rpms and no matter how much you pressed on the throttle... you couldn't get it moving... then all of a sudden like someone flipped a switch... you take off. Very strange.
Now that the update has been applied everything seems great. Car is very willing to accelerate from clutch engagement.
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 06-01-2012, 03:43 PM   #112
DaeHanL
DaeHanL's Avatar
Fan#: 90891
What I Drive: 2012 Red Candy SE 5spd
FF Reputation: 1 DaeHanL Good Standing Member
awesome man! same symptoms and results here. I'm loving driving this car...finally!
NEVER YIELD!
2012 FF5DR SE Sport, 5-Spd, and ALL the 'fixins!
-DaeHan
DaeHanL is offline
Old 06-01-2012, 03:44 PM   #113
2012BlazeSE
Fan#: 95197
What I Drive: 2012 Yellow Blaze SE Sedan 5spd MT
FF Reputation: 1 2012BlazeSE Good Standing Member
Originally Posted by chang351 View Post
I just got mine done today.
I've noticed some surging when cruising at 65-75, and I was always annoying by the lack of throttle response when taking off in 1st.
(I don't need a lecture from anyone on how they can take off on a 15% grade in 2 gear without the throttle; I don't care. I could take off in 4th with my old F150 with a straight-six. Not the issue).
Yesterday, on my way home from work, it felt like someone wedged a 2x4 under the gas pedal. I could barely keep it up to 60 on the highway, and I had to leave the car slowly rev through each gear change.
An engine restart fixed it, but I had the dealer look at it (I drive 70 miles a day, don't want to be stranded).
No codes, but they applied the TSB. Fingers crossed.
This happened to me once, it almost felt like it was running out of gas. I think I had mine on cruise control then it suddenly started to lose speed. I literally floored the gas pedal and it didn't budge the tach at all, almost like a severly clogged fuel filter. I pulled over, restarted the car and all was well. This happened to me 3 times since owning the car (6months). Took it to the dealer and they couldn't find anything wrong with the car :(
2012BlazeSE is offline
Old 06-01-2012, 03:46 PM   #114
amoosenamedhank
Fan#: 96374
I only have about 20 miles on it since the update but I can see how this will make the car much much more enjoyable to drive. On a side note, since the update it has completely killed the vibration from my MS3 RMM with CS inserts. So that's definitely a plus as well.
Old 06-20-2012, 10:33 PM   #115
jrcook
Fan#: 98525
What I Drive: 2012 Blue Candy Metallic Tint 5D SE
FF Reputation: 1 jrcook Good Standing Member
Have intermittent hesitation as described by multiple members--took to dealer who is unable to reproduce and tell me they don't find any codes in the computer. Apparently won't do the update without the codes being present in the engine computer. As I read this TSB it sounds like the codes may be present or the symptoms may be present or both. Is that correct or do the codes have to be present to get the update?
jrcook is offline
Old 06-21-2012, 08:54 AM   #116
DaeHanL
DaeHanL's Avatar
Fan#: 90891
no codes should be necessary. It's a service update, to help solve issues customers are experiencing. Designed for the exact reason you brought your car in the first place! I would say do one of two things. 1 take it to another dealership, or 2 contact Noemi on here and have the problem escalated. Personally, I think that's BS and I wouldn't want to even give that dealership more dough.
NEVER YIELD!
-DaeHan
DaeHanL is offline
Old 06-21-2012, 09:10 AM   #117
faridk89
Fan#: 100026
What I Drive: 2012 Hatchback SE 5 speed
Points 720, Level 14
Points: 720, Level: 14 Points: 720, Level: 14 Points: 720, Level: 14
Level Up 20% Completed
FF Reputation: 1 faridk89 Good Standing Member
Originally Posted by Bimmer-Bob View Post
Uh, wrong. No throttle and the engine stalls. Pretty simple.
You've never launched just by slowly taking your foot off the clutch?
faridk89 is offline
Old 06-21-2012, 09:13 AM   #118
DaeHanL
DaeHanL's Avatar
Fan#: 90891
I never COULD until the TSB. Maybe when the car was cold, first thing in the morning.
NEVER YIELD!
-DaeHan
DaeHanL is offline
Old 06-21-2012, 09:35 AM   #119
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,237, Level 28
Points: 2,237, Level: 28 Points: 2,237, Level: 28 Points: 2,237, Level: 28
Level Up 58% Completed
Forum Activity 3%
FF Reputation: 12 BetaDnB Great Standing Member
That's done and over with (and has been) and isn't exactly pertinent to the thread.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 06-21-2012, 09:36 AM   #120
DaeHanL
DaeHanL's Avatar
Fan#: 90891
ignore
NEVER YIELD!
-DaeHan
DaeHanL is offline
