new TSB 12-5-5 for manual trans focii - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2012, 11:53 PM   #1
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
I'm going to be doing this update to mine tomorrow as I've noticed a few of the quirks this one is supposed to correct. Cheers
2.0L GDI AND MANUAL TRANSMISSION - CALIBRATION UPDATE - VARIOUS DRIVABILITY IMPROVEMENTS - BUILT ON OR BEFORE 2/29/2012
Publication Date: May 8, 2012
FORD: 2012 Focus
This article supersedes TSB 12-1-4 to update the Title, Issue Statement and Service Procedure.
ISSUE:
Some 2012 Focus vehicles equipped with a 2.0L gasoline direct injection (GDI) engine, manual transmission and built on or before 2/29/2012 may exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F, P2877, P00C6, P0607, P0457 and/or P06B8 and may be accompanied by engine drivability concerns. Refer to the calibration content for additional calibration details.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 78.02 and higher. This new calibration is not included in the VCM 2012.3 DVD. Calibration files may also be obtained at www.motorcraft.com.
Reset the Oil Minder, refer to Workshop Manual (WSM), Section 413-01.
Previously Released Calibration Content
Previously released calibration content contained improvement actions and enhancements to address the following on vehicles equipped with a manual transmission:
Intermittent vehicle speed control inoperative.
Engine no-start with engine coolant temperature (ECT) open circuit faults.
Intermittent no-crank/no-start condition after performing normal Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test (PPT) procedures.
Intermittent false initialization to 21 C (70 F) on the instrument cluster's ambient temperature display upon engine start up.
A/C performance at idle and high engine coolant temperature readings in cold ambient temperatures below 0 C (32 F) on vehicles equipped with automatic grill shutters (AGS).
Oil change minder not lighting up in instrument panel cluster (IPC) when vehicle surpasses 10,000 miles.
Difficulty launching from a stop when not using the accelerator pedal.
Low speed tip-in/tip-out shuffle in 1st, 2nd and reverse gears
NOTE: PLEASE ADVISE THE CUSTOMER THE VEHICLE'S OIL MINDER HAS BEEN RESET AND TO FOLLOW THE RECOMMENDED OIL CHANGE INTERVAL AS DESCRIBED IN THE OWNERS MANUAL.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120505A 2012 Focus 2.0L GDI And Manual Transmission: Check DTCs And Reprogram The PCM, Includes Time To Reset The Oil Change Minder (Do Not Use With Any Other Labor Operations) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
Rat Fink is offline
Old 05-14-2012, 12:44 AM   #2
Kabigon
Fan#: 88299
Points 4,389, Level 42
Points: 4,389, Level: 42 Points: 4,389, Level: 42 Points: 4,389, Level: 42
Level Up 20% Completed
Forum Activity 12%
FF Reputation: 11 Kabigon Great Standing Member
This TSB corresponds to the new FSA for automatic Focuses (new PCM calibration).
Kabigon is offline
Old 05-14-2012, 12:57 AM   #3
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 4,289, Level 41
Points: 4,289, Level: 41 Points: 4,289, Level: 41 Points: 4,289, Level: 41
Level Up 70% Completed
Forum Activity 3%
FF Reputation: 1 raptor1956 Good Standing Member
Sounds like there is some overlap between the manual and automanual...
Brian
raptor1956 is offline
Old 05-14-2012, 09:00 AM   #4
Altis
Fan#: 89540
What I Drive: 2012 Sterling Grey SEL Hatch 5MT
FF Reputation: 1 Altis Good Standing Member
Perhaps I'm just thick today, but why would they reset the oil reminder computer when they're just reprogramming the PCM (yet again)? They aren't putting new oil in, are they?
Altis is offline
Old 05-14-2012, 09:03 AM   #5
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,047, Level 66
Points: 10,047, Level: 66 Points: 10,047, Level: 66 Points: 10,047, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 24%
I think that has to do with the earlier build cars where the initial programming or the previous update didn't actually enable the oil life monitor to alert the driver and the latest update is supposed to, but it needs to be reset first even though it won't coincide with an oil change as apart of the tsb, so the next service would have to be performed normally without it. Then it would need to be reset again at that time.
suss6052 is online now
Old 05-14-2012, 09:54 AM   #6
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
There have been a couple of threads with MTX75 owners complaining about no power when taking off from a stop. These seemed to be random occurrences, but it looks like Ford may have found a solution.
The wording is strange there... How often do you launch a manual transmission vehicle from a stop without the accelerator pedal? It's not like the Focus has gobs of low-end torque and stump-puller gears.
Hatch Nation #90
TboneZX3 is offline
Old 05-14-2012, 09:54 AM   #7
Bimmer-Bob
Fan#: 98064
What I Drive: 2010 BMW 128i; 2012 Focus SE Sport
FF Reputation: 3 Bimmer-Bob Good Standing Member
How is this a "problem?": Difficulty launching from a stop when not using the accelerator pedal.
I would think it pretty much impossible to launch without using the throttle, lol.
Bimmer-Bob is offline
Old 05-14-2012, 11:18 AM   #8
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,299, Level 28
Points: 2,299, Level: 28 Points: 2,299, Level: 28 Points: 2,299, Level: 28
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
I'm one of those.
You should be able to launch manual transmission cars without using the accelerator. That's the first thing you should learn how to do when learning to drive manual or a motorcycle so you know where the clutch engagement point is. I've also had to drive like this due to my left knee being immobilized.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 05-14-2012, 11:26 AM   #9
Bimmer-Bob
Fan#: 98064
Originally Posted by BetaDnB View Post
I'm one of those.
Uh, wrong. No throttle and the engine stalls. Pretty simple.
Old 05-14-2012, 11:30 AM   #10
DaeHanL
DaeHanL's Avatar
Fan#: 90891
What I Drive: 2012 Red Candy SE 5spd
FF Reputation: 1 DaeHanL Good Standing Member
I'm experiencing problems launching from a complete stop as well. Are we to contact the Dealership to have these mods made, or will they contact us? The lag at launch, the rpm drop shifting between 1st and 2nd gear (can't stay in power band), and the AC sucking at idle are my only complaints about my Focus.
NEVER YIELD!
2012 FF5DR SE Sport, 5-Spd, and ALL the 'fixins!
-DaeHan
DaeHanL is offline
