Massive Crower cams installed 2009 focus, VIDEOS!! - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 10-02-2012, 09:59 PM   #41
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,940, Level 74
Points: 12,940, Level: 74 Points: 12,940, Level: 74 Points: 12,940, Level: 74
Level Up 23% Completed
Forum Activity 99%
Originally Posted by budpln View Post
destroying America..
There are a lot of other issue's & people doing that already, but I'm not going into that.
felixthecat is offline
Old 10-03-2012, 07:01 AM   #42
budpln
budpln's Avatar
Fan#: 89951
What I Drive: 2008 red ses
Points 2,655, Level 31
Points: 2,655, Level: 31 Points: 2,655, Level: 31 Points: 2,655, Level: 31
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 budpln Good Standing Member
we should start a thread lol
budpln is offline
Old 10-07-2012, 06:39 PM   #43
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
I like sounds go man. cant wait to see dyno #
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 10-29-2012, 12:50 PM   #44
staticsword
Fan#: 75360
What I Drive: 2009, black, ford focus, SES, coupe
FF Reputation: 1 staticsword Good Standing Member
Hey guys, sorry I have not been on here in a while. Got some pm's about the cams, i thought i would update you all on them thus far. So I have had them since May, the car runs fine as of right now, it still idles a bit rough but not to bad since i changed the stock idle to 950rpm. The car will stall on idle now and then, maybe 2-3 times a month so nothing major and only when the car first starts. As for a tune, I have been through hell and back trying to get the car tuned for the cams. Ran into a million issues with sct software, my datalog lists are super out of date and will not show anything that me and tom need to tune it, had serious issues were the wrench light on the car would keep coming on when tom sent me new tunes. It had to do with the files being corrupted or somthing, not sure. We have spent hours on the phone with SCT, pretty much in the end just refused to help us and said it was our problem. As of right now I pretty much gave up on tuning the car for now, since it does run ok, im sure it would be a lot better with a proper tune. I am currently runing my Fswerks tune, which was made for all my other mods, minus the cams. I am going to contact Tom soon I think and see if I can get things going again. The major problem is that I do not have a wideband which limits what I can really tune for, since I do not have the $$$ to buy one right now (at university). Do you guys think there is any danger to running these cams without a real tune for them? They are only stage 1
staticsword is offline
Old 10-30-2012, 01:31 PM   #45
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
As long as your timing is good, your a/f ratio is acceptable, theres no pre-detonation and you don't over-rev I don't see why it would be an issue. But thats just my .02
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 10-30-2012, 02:08 PM   #46
staticsword
Fan#: 75360
I am assuming the timing is good, I had a shop install them, so hopefully they got it all right. The car is an auto, so there is not really a chance to over rev. My car is def running a bit rich I think, you can smell the exhaust/gas. Also how would I know if there is pre-detonation? Not sure what that means, im not that great when it comes to the technical stuff with cars haha still learning
Old 10-30-2012, 02:52 PM   #47
Gettysburg150
Fan#: 97408
Being that you have had the cams in for a while and it hasn't come apart I'd also assume that the timing is ok. Rich is def much better than lean. Lean will melt pistons, rich makes less power and uses more fuel but is safer. Pre-detonation is when the mixture starts burning before the piston reaches top dead center on the compression stroke and will break things, I think ignition timing being advanced too far causes this. I think it will usually cause a knock under load. (Someone correct me if I'm wrong please.) Overall I think the car would be ok to drive from what you describe its just not going to be the most efficient or make the best power.
Take what I say with a grain of salt, I'm just going off of what little car stuff I know and by no means am I a performance builder or tuner.
Old 10-30-2012, 03:18 PM   #48
Baldurs390
Baldurs390's Avatar
Fan#: 86071
What I Drive: 2009 black ses
Points 3,635, Level 37
Points: 3,635, Level: 37 Points: 3,635, Level: 37 Points: 3,635, Level: 37
Level Up 90% Completed
FF Reputation: 4 Baldurs390 Good Standing Member
this is on my list of mods... wish there wasnt tuning issues but only time will tell
FRPPFSWERKSDDMMassiveTruBenz
Baldurs390 is offline
Old 11-26-2012, 12:20 PM   #49
staticsword
Fan#: 75360
The tuning issues were due more to my car having a weird ECU number, it did not really have anything to do with the actual cams. I also do not have an A/F guage so that really limited me in what could be tuned. I am going to get one for christmas and then start trying to tune my car again, I will let you guys know how it all goes after I get the proper tune and guages in my car.
Old 11-26-2012, 07:31 PM   #50
Baldurs390
Baldurs390's Avatar
Fan#: 86071
i love the way your car sounds :)
