FSWERKS race header for my D23 PZEV? (Questions/tune) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-11-2012, 09:28 PM   #1
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
Talking FSWERKS race header for my D23 PZEV? (Questions/tune)
I've read the basic bolt on's thread, but it didn't help much with my questions.
http://www.focusfanatics.com/forum/showthread.php?t=192525
I want to put the race header from FSWERKS onto my 2.3l, I know I need a new flex pipe and cat, along with a o2 sensor cheat for CT emissions.
My questions are, why do I need the o2 sensor cheat and why does the header only have one bung hole on it, When there are three o2 sensors for this PZEV model?
Also, is this header going to fail visual inspections? If so is there a trick to it? Maybe a heat shield? Or do I need to wrap it anyways for heat?
And what is involved in the tune? I have the OE Exedy fly/clt kit, with the Weapon R intake, and the exhaust done in 2.5 diameter trubenz piping from the cat under the car, back.
Thanks, Hopefully Tom can stop by for the Tune questions, since I would probably buy it from him.
Djzx3
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 05-11-2012, 09:54 PM   #2
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Or what's up with these OBX race headers that I see? They cost about half the price of the FSWERKS one, and I can count atleast 2 o2 sensor holes?
Which makes more power is a factor for me, in that sense, how's the Weapon R header too? Anybody use it?
HN #17
D23 crew-#1
Djzx3 is offline
Old 05-12-2012, 02:03 PM   #3
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Hey I dont have the fswerks or the obx but they r the same primaries size if I was u I would buy the obx but is ur call and about the o2 bungs there is only one cause u will need to diactivate. The other 2 with a tune and the o2 sensor cheater is because u take one o2 sensor out off the cat so the cheater make the ecu think the cat is still there
Posted via FF Mobile
koke'sfocus is offline
Old 05-12-2012, 02:41 PM   #4
Klondike
GreyRice WOoT!
Klondike's Avatar
Fan#: 25991
What I Drive: GI, '07 zx3 LG
Points 33,169, Level 100
Points: 33,169, Level: 100 Points: 33,169, Level: 100 Points: 33,169, Level: 100
Level Up 0% Completed
FF Reputation: 53 Klondike Excellent Standing Member
Buy-Sell-Trade Rating: (26)
im running the obx header, the extended bung needs to be cut off and welded straight to bottom of bung, 1 bung for 02 sensor other for wideband, top bung isnt need with tune, that ones plugged into collector at bottom. had mine for a few months now, great shape still, unwrapped, looks good, the hangar brackets are ueless as well, i cut em off
Focus Nation
Focus Revolution
Chrenron 1 of 3
Velveeta Lover Shell#1
LOTH 00!
Klondike is offline
Old 05-12-2012, 10:10 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,954, Level 74
Points: 12,954, Level: 74 Points: 12,954, Level: 74 Points: 12,954, Level: 74
Level Up 26% Completed
Forum Activity 99%
Heres some options for you.
IMO the Fwerk's header is the best.
2 to monitor the before & after the convter.
Also, is this header going to fail visual inspections? If so is there a trick to it? Maybe a heat shield? You could take two stock 23 heat shield's & mod them to work= hide the header. Or do I need to wrap it anyways for heat? You could wrap it, but a official knowing what to look for, a header can't hide. The best flowing oem manifold/cat= a 23 ST manifold
If your inspector's know what to look for= yes it will fail then.
A tune will help out= turn off the rear o2 senser & egr, etc. A tune really helps out = makes your car more drivably, smoother.
Djzx3
I run a Fwerk's header & tune w/ rear o2 senser & egr delete. The oem 23ST manifold/cat is the best flowing oem manifold. If you inspection= opening the hood, a header can't run & hide.
felixthecat is offline
Old 05-13-2012, 12:10 AM   #6
K26
K26's Avatar
Fan#: 51125
What I Drive: 2006, Red, turbo'd ST
FF Reputation: 8 K26 Good Standing Member
I am installing a turbo next week so my fsw header will be up forsale when it comes off. I had a second bung welded into the setup. had it put in the flex protion. Have my wideband in there. Its only a about 2 years old. FSW header is the way to go IMO if you want the best header for the 2.3. Its a copy of the cossie. I was impressed with it. but its turbo time lol
FOCUS FACTOR
K26 is offline
Old 05-13-2012, 01:41 AM   #7
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
FF Reputation: 4 VEGAS Good Standing Member
i run OBX header with 1 O2 and Need to get Wideband O2 Sensor for acurate reading. Per Turbo Toms advice. The tune will turn off O2s you do not use.
VEGAS is offline
Old 05-13-2012, 04:18 AM   #8
K26
K26's Avatar
Fan#: 51125
^ Yes, if tom tunes it for you he always turns the second o2 sensor off. You can turn your pzev to a non pzev by deleting all that stuff. by getting a tune they can clear them all for you and make sure nothing else is wrong. Make sure you get a wideband.
FOCUS FACTOR
K26 is offline
Old 05-13-2012, 08:56 AM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,848, Level 100
Points: 51,848, Level: 100 Points: 51,848, Level: 100 Points: 51,848, Level: 100
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Correct I can turn off the rear o2`s and EGR among other things for you in a tune and you get FREE tune updates as you add more NA mods
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-15-2012, 04:29 PM   #10
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
So which o2's get removed? The two that plug up on a bracket on the trans?
And Tom, do I need to get a wideband and knock gauges for you to tune it?
HN #17
D23 crew-#1
Djzx3 is offline
