Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 12-16-2012, 01:21 AM   #61
revnull
Fan#: 95972
What I Drive: 2012 5 Door
FF Reputation: 1 revnull Good Standing Member
Hi SaToX,
Looking at the type 2 install for my 2012 SEL, I'm still a bit confused. In addition to the DB-ALL and the XKLOADER2, will I also need a "smartstart" module? The "Vehicle Application Guide" section on page 2 of the install guide seems to refer to the remote start functions only being available via the "D" (Data-to-Data) port of the DB-ALL. Confusingly, there also seems to be Wire-to-Wire connections to start/ignition directly on the DB-ALL 14-pin and 12-pin connectors.
My Shopping list currently contains:
http://www.amazon.com/gp/product/B0047Q9AXG/
http://www.amazon.com/gp/product/B001XTZBHO/
Thanks in advance!
revnull is offline
Old 12-16-2012, 08:34 PM   #62
SaToX
Fan#: 94321
What I Drive: 2012 White Titanium Hatch
FF Reputation: 3 SaToX Good Standing Member
I believe what they are saying towards the Data-to-Data on the 3 x lock is that there is no manual input to trigger it. Only reads it through the data of the car.
Sorry not to sure on what you are asking about on the Start / Ignition connections. I do see that the Gray feeds back the the Yellow/Red through a diode to prevent feedback?
Your shopping list is complete, you don't need a Smart start module. That is optional if you want to be able to start you car with your phone once you have installed the unit. ( Mind you there is subscription fees with smartstart)
SaToX is offline
Old 12-17-2012, 12:52 AM   #63
revnull
Fan#: 95972
I think I understand. The DB-ALL is listening on the HSCAN for the 3xlock to trigger the start?
At the time I was thinking that if I needed a separate start module, why would the DB-ALL have wires to the ignition? I think I get it now.
Side question... does the DB-ALL typically come with the protection diodes and 12v relay or will I have to source those separately?
Very cool! I think I'm going to pull the trigger on this one. Maybe even document the process and post it here.
revnull is offline
Old 12-17-2012, 08:00 AM   #64
SaToX
Fan#: 94321
You have to hook it up to start and ignition because it turns those circuts on when the car goes to start.
No the DBALL does not come with the diodes, relay or fuses you will have to source those out. Radio shack most likely or any electronics repair shop
SaToX is offline
Old 12-27-2012, 08:35 PM   #65
alfack
Fan#: 91684
What I Drive: 2012 sterling gray Titanium sedan
FF Reputation: 1 alfack Good Standing Member
Thanks for the tip. I did it today. Works like a charm! :)
I had a friend that works at car toys flash the firmware, but didn't realize you would need to plug it back into the computer to program part 2, so I ordered the cable and created an account at idatalink.
alfack is offline
Old 12-28-2012, 07:52 AM   #66
SaToX
Fan#: 94321
Yea the two part programming and having to create an account with Idatalink is the down side, but still nice to have :) I've been loving it all this week with our weather we've been having.
SaToX is offline
Old 12-28-2012, 04:50 PM   #67
alfack
Fan#: 91684
Does one of the programming options prevent the motor from turning off when you open the door? If so, it's not intuitive to me which one it is. Thanks
alfack is offline
Old 12-29-2012, 08:16 AM   #68
cougardave
Fan#: 93864
What I Drive: 2012 sterling grey titanium
FF Reputation: 1 cougardave Good Standing Member
I tried a couple of things but couldn't get it to not shut off either. Any insight if it is possible or not would be great.
cougardave is offline
Old 12-29-2012, 12:32 PM   #69
cougardave
Fan#: 93864
I just noticed that the one touch windows have stopped working since install. Anyone else have this issue?
Old 12-29-2012, 02:20 PM   #70
revnull
Fan#: 95972
While waiting for a clear day to install, I stopped by the Radio Shack and picked up the following. If you don't mind, can you please confirm that I have the correct parts?
12VDC SPST Relay:
http://www.radioshack.com/product/in...ductId=3020762
6amp Rectifier Diode:
http://www.radioshack.com/product/in...ductId=2062591
As always, thanks!
revnull is offline
